Tore
« on: November 22, 2015, 12:11:36 am » |
the login from XXHighEnd is not working. I get this message: Failed
I have tested with two different Tidal accounts, in MinOS and NormalOS.
In Tidal Settings-Streaming i choose Flac + Phasure NOS1
Tore
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^3 -> Phasure NOS1a B75 G3 -> Blaxius^2.5 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #1 on: November 22, 2015, 03:26:49 am » |
Hi Tore,
Is XXHighEnd Activated ? If so, is it possible to post a screen shot of that message ?
Thanks, Peter
« Reply #2 on: November 22, 2015, 08:34:08 am » |
Maybe you are attempting this from Windows 10 ?
Tore
« Reply #3 on: November 22, 2015, 10:28:41 am » |
Yes, from W10
Tore
« Reply #4 on: November 22, 2015, 10:37:19 am » |
That probably won't work because you did not setup the normal HTTP scheme stuff. But I don't know myself !Please keep in mind the general idea : General Set Up. You can still post that screen shot and answer the question about XXHighEnd activation. Ok ? Peter
Tore
« Reply #5 on: November 22, 2015, 10:41:05 am » |
XXHighEnd 2.03 is activated
First message box : Tidal - Failed
Next message box: Initialize Tidal - Tidal could not be Initialized (failed on creating Tidal Login Data)
Tore
« Reply #6 on: November 22, 2015, 11:02:54 am » |
Tore, I looked back in our emails, and it looks like you never finished that http stuff. Look here again : Windows 10 Tutorials - Make Internet Explorer available. So if you don't do that then you just can't have an Internet connection, and this is necessary ... And it is NOT the idea at all (see previous post). I could also say : if someone likes to have a SQ deteriorating Internet Connection it is a bit up to him how to achieve that. I mean : next up is your complaint that SQ is not good. And I really am not going to do anything about that. So it must go different ... follow the "rules" so to speak, or find better other means yourself. Btw, I am still not sure this http stuff is your problem because the first error message tells me nothing. This is why I'm asking a screen shot of it. Otherwise we will solve it anyway !  Peter
Tore
« Reply #7 on: November 22, 2015, 01:12:30 pm » |
Make Internet Explorer Available : when I follow that guide I get this message when I push "Set associations" : To change your default apps, go to settings>system>default apps (see screenshot) Internet is up but I have to do this steps after every reboot.
Internet is OK but I get this messages when I try to logon to Tidal from XX 2.03 (see screenshots)
« Reply #8 on: November 22, 2015, 01:38:43 pm » |
Thank you for your efforts Tore. Time to hop over to email and more in-depth stuff.  Peter
« Reply #9 on: November 22, 2015, 04:55:22 pm » |
Solved, and it was my bad; A small file lacked from the Install. When others are going to use Tidal : Please see at the bottom in the Download for XXHighEnd 2.03; There is an XXHighEnd-203a-Addendum.rar to additionally download/unzip to your XX folder. That solves this problem. Regards, Peter
KnB
« Reply #10 on: December 29, 2015, 08:27:02 am » |
Got the same problem as Tore had, same messages. (2.03a with the addendum file, and on 2.04)
Using win 7 ultimate.
Edit: red "xxhighend" text changes to grey during login attempt,
Phasure system: XXHighEnd stealth Mack III LPS PC, Xeon scalable 14/28 - Lush^2 Blaxius^2 - NOS1a/G3 75B Dac - Orelo mkII speaker
Win 10 14393 - XX 2.11 - min OS - RAM drive - Music on LAN - Adaptive 4096 - Allow format change - Core 3/5, low, Real time - Clock res 15ms XTweaks 52,10,1,0,1 - Boost at xxhighend startup - SFS 10.19/10.19 SC - Incl garbage - Copy to xx - Always clear proxy - Use remote desktop Use touch facility - Stop desktop/remaining/wasapi services - Keep LAN - Use remote desktop - OSD text - Show as wallpaper - Q1,3,4,5,xQ1;14,1,1,1,10 Prosessor set to 20 cores - Driver 1.04; USB buffer 16ms
« Reply #11 on: December 29, 2015, 08:51:55 am » |
Hi Kjell Narve,
I think you were not XXHighEnd activated, as you only obtained a Code for it 2 hours after your message ? Am I right ?
Regards, Peter
KnB
« Reply #12 on: December 29, 2015, 10:36:12 am » |
I am activated, at least everything indicates that.. Received code yesterday. (Followed the procedure for activation etc) But by some reason text goes from red to gray during the login progress, not sure if that indicates anything..
Error message pops up instantly when pressing logon button,
Edit:
« Reply #13 on: December 29, 2015, 10:41:44 am » |
Forgot to respond to the Title Bar "issue" : No, that is normal. That happens when the window is not the active window.
I don't know what your issue can be. So a very silly question : Do you know your Tidal email and Password correctly ? You can easily forget it, if it has been some longer ago when you obtained it for the first time. I mean, you never have to enter it anywhere ... And if you think it is OK, how do you confirm (test) that ?
KnB
« Reply #14 on: December 29, 2015, 11:01:47 am » |
Yes, password and login details was the first thing I checked, all OK. But the message pops up without delay at all, I assume with wrong logon details it takes a few millisecond to verify.
