November 23, 2024, 09:26:23 pm *
Author Topic: Stop W10 Services button in Settings  (Read 6335 times)
« on: November 21, 2015, 01:32:37 pm »
All,
Here is a forgotten Tooltip Text in 2.03 on the new Button in Settings (Services and OSD section) - Stop W10 Services :
(here shown from within the [ H ] (Help) Area where all ToolTips appear for more comfortable reading)
« Reply #1 on: February 10, 2016, 01:25:59 pm »
The other day I tried activating this button (RAM-OS) but ran into problems and had to reboot. Must one have the LAN button active in order to use this button? If so, maybe it's time to try that RDC connection again?  Happy
« Reply #2 on: February 10, 2016, 02:09:09 pm »
Hi Brian,
No bells start to ring on this side of the line.
It can very well be true though that I myself only used that button (in Activated state) with the LAN Off only (Keep LAN - Not Persistent). So if you're saying that you activated this button while you your "Keep LAN" is not activate in the first place ...
Are you ?
If so, what "problems" did you run into ? and especially : when ? (like in start or Playback or stop of Playback).
Maybe I'm indeed doing something "impossible" in that (combination) situation.
Page created in 0.146 seconds with 19 queries.
