April 05, 2025, 10:55:59 pm *
Author Topic: Avoid Laptop Dual Boot while 2 OSes  (Read 4519 times)
doublelife
« on: November 19, 2015, 11:32:42 am »
With 2.03, and to run 2 different builds of W10 on a laptop with one HD (say 10074 and 10565), to avoid dual boot on the same HD, can I just use an external SSD or do I need more than that (eg RAM?).
Thanks
PC  i7 / W10 10074 (x64) / hyperthreading ON (12 cores) / 32GB RAM / XX - OS on separate dedicated 256GB SSD - XXHighEnd: 2.03 / Engine#4 Adaptive / 4096 / Q1=14  / xQ1=10 / Q3,4,5=0/1/0 / SFS=4-120 / Straight Contiguous / Clock Resolution = 1.0  / Scheme 3-5 / 16x Custom / Peak Extend = OFF / Unattended / Minimize OS / Phase Alignment = OFF / XTweaks = 43, 100, 1, 1, 1 > 24/768 NOS1a 75B async USB DAC driver v1.0.4 1ms > KGSSHV Carbon amp > Stax SR-009
« Reply #1 on: November 19, 2015, 11:42:41 am »
Hi Paul,
If you can make your laptop boot over USB ... Yes;
Just create one SSD (or HDD) with the one OS and another SSD (HDD) with the other OS. Or a dozen.
This is not related to RAM as such anywhere. And, might you feel that this could boot from RAM (like our famous OS-RAM subject and the HDD for that) - no. Or virtually no, because a boot from RAM over USB takes 20 minutes (I'd say at least).
What also will work is boot from an USB flash drive (USB pen). Mind you, normal OS and nothing "from RAM".
But your PC/laptop must be able to boot from USB.
If there's an USB3 connection, try to avoid that because usually that does not work.
Anyway, if you can appoint the USB device concerned in the BIOS as (first) boot device, you're good.
PS: I will split these posts to a new topic.
Page created in 0.024 seconds with 19 queries.
