November 24, 2024, 07:55:36 am *
Author Topic: Model 09t-5 can't use Library anymore  (Read 6452 times)
Leon
oosterom@msn.com
« on: January 03, 2008, 12:24:52 am »
Downloaded the 09t-5, with the previous versions my pc running under Windows XP Pro would not show any artwork as wallpaper. Instead what showed up was a solid coloured background instead of the picture I usually use as wallpaper. Presssing the "I" would not bring that picture back. Now with the 09t-5 the artwork does show properly but now something annoying is happening: once I choose an album to play XX will start playing but when I then minimize XXhighend and open it again by clicking on the icon the programm won't allow me to browse through my library again. I can stop the playing but nothing else. Only after shutting down XXHighend and start it up again I can make another selection. Any idea what could cause this?
regards
Leon
« Reply #1 on: January 03, 2008, 04:59:21 am »
Hi Leon,
How long does it need to be minimized in order for it not to work anymore ?
Are you sure you waited long enough for the disks to spinup again (if spun down) ? This can take 10 seconds or longer easily ...
Note that the way it works may make you think the disks are spinning, which especially is so when you make use of a Galery which is on the boot disk (say, C:) while the data is somewhere else (like F:). In the mean time however, the data disks spun down long ago, no matter you needed them to play (innocent). If you now want to do anything real with the library (better : the data) all stalls until the disks spin. With my example of the Galery on C: this does not count for the Library Tab and just browsing through there, so all seems to be alive.
Leon
oosterom@msn.com
« Reply #2 on: January 03, 2008, 07:43:27 am »
Thanks for your quick response, I have galleries and data on the same external disk and I waited long enough. I found however what was causing the problem. I had a little programm running called "rocketdock". This seems to be interfering with minimizing and reactivating again. After shutting that programm down, XXhighend operates as it should be. Thanks again and keep up the good work.
Regards
Leon
