« Reply #75 on: January 20, 2016, 06:09:53 pm » |
Man what a work!!  Thank you so much.....
toddn
« Reply #76 on: January 20, 2016, 06:36:39 pm » |
That's awesome Peter! Quite a comeback considering the drive saga  So now on to that surprise announcement  I'm looking at this ATX linear power supply: http://www.hd-plex.com/HDPLEX-Fanless-300W-ATX-Linear-Power-Supply-with-Modular-ATX-Output.htmlBut don't want to pull the trigger if you've got something related up your sleeve! Todd
W10-10074 XX HighEnd 2.03 PC -> i7 3930K AS Rock MB W/ Dexa Neutron Star & linear PS supply mod. For Processor Clock, Hyperthreading On (12 cores) @430MHz (!), 16GB, Windows 10 Pro 64 bit Insider Preview build 10074 Samsun SSD, XXHE on 2GB RAMDisk (IMDisk), music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS W10 = .14(max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / W8 Scheme = Core 3-5, W10 Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive 2GB RAMDisk (IMDisk) / UnAttended (Just Start) / All Services Off / Keep LAN - *Not Persist* / WallPaper Off, W10 Running Time Off / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600* / -> USB3 (Silverstone W/Dexa Neutron Star Clock & Linear PS> *Clairixa USB* -> Uptone Regen w/ Dexa Neutron Star & linear PS -> 24/768 Phasure NOS1a 75B (BNC Out) async USB DAC, Driver v1.0.4b (*4ms*) -> Blaxius BNC interlink -> 8 channels of Hypex NCore 400's -> DYI BD Orphean Horns w/ qty-3 custom 15" open baffle bass drivers and qty-8 12" open baffle subwoofers per channel
« Reply #77 on: January 21, 2016, 12:44:47 am » |
Hi Peter, I also receive a notice from UPS  I don't know what to say... So I will say nothing But thanks ! You know Alain
« Reply #78 on: January 21, 2016, 01:22:37 pm » |
Received!! Thank you Peter. I'll let you know when I get it working
Best regards, Juan
« Reply #79 on: January 21, 2016, 01:26:38 pm » |
Ha ! Btw, I hope that people have seen this small Tutorial : Unboxing the RAM-OS disk. Also : be careful please with trying things yourself without knowing the outcome. It is better to ask (forum please !), plus I need/like to add more "tutorial" later today. Regards, Peter
« Reply #80 on: January 21, 2016, 01:36:29 pm » |
Thanks Peter, I just opened the envelope with the ram-disk and the usb Clairixa. I´ll wait to work with it until I know what and how to do. I guess that would be nice if we wait a few days until more people receive the shipment and we can work together, meanwhile we can study your tutorial when it gets ready.
« Reply #81 on: January 21, 2016, 02:00:21 pm » |
I should receive mine tomorrow  I will let it get to temperature before I do anything and use a "toaster" (dock with vertical hole to insert either a 2.5 or a 3.5 hdd. Very practical ! Will let know of course how it is going Eager to get it ! But will put my reading glasses to check the documentation (OF COURSE) Alain
« Reply #82 on: January 21, 2016, 02:21:49 pm » |
Alain and all,
Well, I thought I could overdo it by warning people about the cold, but it sure would be true that such an actually frozen HDD should warm up first (just let it be in the living room). With us too a batch which arrived Tuesday had been in some unheated storage at -7C overnight and the morning after and the things are literally frozen. Not good to start using them in those conditions (me thinks).
« Reply #83 on: January 21, 2016, 04:24:48 pm » |
Damn!!! I missed the UPS delivery. Hopefully they'll try to redeliver tomorrow.
« Reply #84 on: January 21, 2016, 04:31:00 pm » |
Get your car and search for the bastard ;-)
« Reply #85 on: January 21, 2016, 04:38:23 pm » |
 haha Mani, admit it; at 10:30 am you were just still sleeping.
« Reply #86 on: January 21, 2016, 04:59:10 pm » |
Hi Peter, I always wait until a component gets to room temperature... I even used to do that with ice cream, but someone took me apart and talked to me...  Alain
« Reply #87 on: January 22, 2016, 02:36:49 pm » |
Mani, I was just reviewing all the (non)deleveries and only see now that the package - as far as I can see - will not be redelivered but was dropped at the closest-by UPS access point. See in your UPS email. Not sure how "normal" this is ... Peter
hbrew
Steve
« Reply #88 on: January 23, 2016, 05:29:41 am » |
Got the RAM OS disk today, sooner than expected! Have 10586 running in RAM. Haven't setup the others yet. Instructions worked just fine and had it running in 30 minutes or so. Setup TCP/IP and loaded DAC USB driver. In normal mode got some errors during playback: Fail! TEMP ERROR B, Error during Playback Initialization BUFFER TOO LARGE and one other. These went away in MinOS. Haven't tried Unattended yet. I was getting great sound before with the ASRock Fatal1ty MB and 8-core CPU I just built. May be at the end of the road for my dual DAC. I think I did get some refinement running the 10586 OS in RAM. I thought perhaps going from 4 cores to 8 was more an improvement and this a final refinement to my system as it now stands. Great sound no matter! Thanks Peter! OK, spoke too soon so I had to edit this. Unattended mode does it for me! Amazing presence and depth. Was amazing before I thought now even better. So I won't be sending my disk back  Read some stuff from a few years back -- bit perfect, etc. Who cares? If it sounds better that is all that matters. What am I missing? Day 2: RAM OS is outstanding! I must have been fatigued from driving and not in the mood to hear. Very glad to have the RAM OS disk!
« Last Edit: January 24, 2016, 06:39:44 am by hbrew »
XXHE RAM OS disk as of 2016.01.22 using Win10586
Player1: SuperMicro X11SPM-F, pre-owned Intel 6152 Gold Scalable 22 cores (set to 20), 6x8GB, Corsair GS600 ATX PS, 2.5-inch SANDISK Plus SSD for RAMOS - remains after booting, M.2 Kinston NV2 1TB NVME PCIe 4.0 Gen 4x4 3500MB/s music disk (or use external via Ethernet); cannot use M.2 NVMe SSD as boot device with CSM legacy boot so used a 2.5 inch SSD for booting; using onboard USB3.0 to DAC with good results but haven't tried my Silverstone USB card. Use KVM with 15 inch "portable" display once booted. AMAZING SENSE OF REALISM
Player2 (retired): ASRock Fatal1ty X99M Killer/3.1, was i7-5960X 8 cores changed to a pre-owned E5-2699v3 18 cores (set to 14), 48GB 2400MHz DDR4 RAM, RAMOS Win10586 on 120GB M.2 SSD, music files over LAN, ASUS GT210 Silent Graphics card, Silverstone USB 3.0 card
Music Server: ASROCK BeeBox direct Ethernet connection to player PC
XXHE 2.11 since about 4/2023 for the CPU core selection feature; arc predict; Min OS;attended or unattended; Device: Denafrips v5.0 or KS Amanero Streaming depending on DAC; KS Mode: Adaptive; Device Buffer: 2048 or 4096; tweaks - 43/1/-/1/1, Q1:14, Q3,4,5: 1; SFS 1 to 5; Straight Contiguous; Garbage Collect (sometimes can select); Clear Proxy; Denafrips Venus II DAC is 24bit/192KHz, DIY Dual ES9018 DAC is 32bits 384KHz; Cores 3-5; Player Prio:low; Thread Prio:RealTime; Clock Resolution:15ms; Stop Services (desktop, remaining, WASAPI and WIN10); Use Remote Desktop; Don't Keep LAN, PAN or WiFi; OSD Text; Show as Wall Paper
Equipment: Denafrips Venus II R2R DAC and DIY Dual ES9018 Twisted Pear Audio DAC boards using Amanero USB receiver (384KHz) with isolated buffer (ISO7640FM), preamp is DIY Lynn Olson Raven with an added Phono Preamp; Douglas Self Trimodal selectable Class A or Class AB 20W amp; Klipschorns (modified slightly); balanced mains power transformers: one for amp and one for low level equip; Alt. Speaker: ScanSpeak (2) 10" Revelator, (2) Illuminator 4", (1) Beryllium Dome Tweeter, tuned ports
Room Treatment: 4, 4 x 24 x 48 inch panels
« Reply #89 on: January 23, 2016, 09:37:11 am » |
What am I missing? That counts for a few more in here.  Sound can be so utterly different from one setup to the other, that it seems completely impossible that all is bit perfect. Still it is ... If you got used to 10586.0 somewhat, then try 10565 with the same XXHighEnd settings; You just won't believe the difference ... Peter
