« Reply #60 on: January 14, 2016, 03:40:04 pm » |
Ok ... SSDs go back and HDDs will be the replacement (they are 2 euros more expensive, but twice as large. For some 3 times because of "availability"  ) Of course nobody needs to pay that 2 euros and I only mention it because at first I told about the SSDs being 10 euros more expensive than the HDDs. But this was about another brand/type and if you don't mind - I now don't trust anything anymore which needs to go in "quantities"; These HDD's are the same we always ship(ped) in the XXHighEnd PC. Actually I am super glad now that yesterday that 10586.0 connection failed on me again and that I thus revisited 10565 for that reason; If that had not happened then tomorrow most of them would have gone out to you. Before I forget : Tomorrow we will receive a first bunch but not all. Monday or Tuesday the remainder will arrive. Thank you for bearing with me ! Peter PS: The person starting that discussion about the SSD losing its data when not under power must have some special senses.
« Reply #61 on: January 14, 2016, 03:53:11 pm » |
Better try a new ssd or hdd first. Meaning order just one. Will take more Time but less money and trouble.  Yes Gerard - exactly what I just said. FYI : Testing first is exactly what I did and this was the 2nd SSD I got for the purpose and I received it on December 19. So that is almost 4 weeks (using it continuously) and even that was not enough. And about permutations ... I used 10565 all right, but from RAM. Thus, the OS file is copied to RAM a run from there. Today though I booted into the BASE version because I yesterday saw that XXHighEnd was not activated any more - somehow; and only there this problem shows, hence go into that normal boot and it gets molested right away (dig deeper and messages about the Partition Table being corrupted are thrown at you). After that the RAM Boot also does not work any more. Regards, Peter
« Reply #62 on: January 14, 2016, 04:02:36 pm » |
The person starting that discussion about the SSD losing its data when not under power must have some special senses. Nah just something I read somewhere sometime seems it is not that that is causing the problem anyway. Better for this to happen now rather than after shipping - I am in no hurry. Paul
« Reply #63 on: January 14, 2016, 08:20:49 pm » |
Peter, before you send my ram disk I'd like to order another Clairixia but I'm not sure about the length I need until I return home by the 20th of this month. So please wait until l confirm with you that length. In case I'd need around 1m would be this length a problem to maintain the correct impedance or I should get a shorter one?
« Reply #64 on: January 15, 2016, 01:19:28 am » |
Important information Peter...are they 2.5" or 3.5" HDD's? Through laziness I have not yet ordered my 2.5"-3.5" hotswap adapter/box/thingamy...but if the HDD are 3.5" then I don't need to order it now. Please confirm. Cheers, Anthony
« Reply #65 on: January 15, 2016, 04:51:12 am » |
Anthony, they will be 2.5". Peter
« Reply #66 on: January 15, 2016, 04:57:50 am » |
Peter, before you send my ram disk I'd like to order another Clairixia but I'm not sure about the length I need until I return home by the 20th of this month. So please wait until l confirm with you that length. Hi Juan, For the 100 euros and your second Clairixa it is 30cm by standard. So I hope you can use that (everybody thinks he can  ) or otherwise it has to be the usual price. The 20th should be 2 days too late (maybe 1) as all will ship together (shipping is now 10 euros less). So I hope it is okay ? Peter
hbrew
Steve
« Reply #67 on: January 15, 2016, 05:33:44 am » |
No hurry here either. Take as much time as you need. I appreciate the effort to get it right and appreciate your work on this!
XXHE RAM OS disk as of 2016.01.22 using Win10586
Player1: SuperMicro X11SPM-F, pre-owned Intel 6152 Gold Scalable 22 cores (set to 20), 6x8GB, Corsair GS600 ATX PS, 2.5-inch SANDISK Plus SSD for RAMOS - remains after booting, M.2 Kinston NV2 1TB NVME PCIe 4.0 Gen 4x4 3500MB/s music disk (or use external via Ethernet); cannot use M.2 NVMe SSD as boot device with CSM legacy boot so used a 2.5 inch SSD for booting; using onboard USB3.0 to DAC with good results but haven't tried my Silverstone USB card. Use KVM with 15 inch "portable" display once booted. AMAZING SENSE OF REALISM
Player2 (retired): ASRock Fatal1ty X99M Killer/3.1, was i7-5960X 8 cores changed to a pre-owned E5-2699v3 18 cores (set to 14), 48GB 2400MHz DDR4 RAM, RAMOS Win10586 on 120GB M.2 SSD, music files over LAN, ASUS GT210 Silent Graphics card, Silverstone USB 3.0 card
Music Server: ASROCK BeeBox direct Ethernet connection to player PC
XXHE 2.11 since about 4/2023 for the CPU core selection feature; arc predict; Min OS;attended or unattended; Device: Denafrips v5.0 or KS Amanero Streaming depending on DAC; KS Mode: Adaptive; Device Buffer: 2048 or 4096; tweaks - 43/1/-/1/1, Q1:14, Q3,4,5: 1; SFS 1 to 5; Straight Contiguous; Garbage Collect (sometimes can select); Clear Proxy; Denafrips Venus II DAC is 24bit/192KHz, DIY Dual ES9018 DAC is 32bits 384KHz; Cores 3-5; Player Prio:low; Thread Prio:RealTime; Clock Resolution:15ms; Stop Services (desktop, remaining, WASAPI and WIN10); Use Remote Desktop; Don't Keep LAN, PAN or WiFi; OSD Text; Show as Wall Paper
Equipment: Denafrips Venus II R2R DAC and DIY Dual ES9018 Twisted Pear Audio DAC boards using Amanero USB receiver (384KHz) with isolated buffer (ISO7640FM), preamp is DIY Lynn Olson Raven with an added Phono Preamp; Douglas Self Trimodal selectable Class A or Class AB 20W amp; Klipschorns (modified slightly); balanced mains power transformers: one for amp and one for low level equip; Alt. Speaker: ScanSpeak (2) 10" Revelator, (2) Illuminator 4", (1) Beryllium Dome Tweeter, tuned ports
Room Treatment: 4, 4 x 24 x 48 inch panels
« Reply #68 on: January 15, 2016, 08:17:07 am » |
For the 100 euros and your second Clairixa it is 30cm by standard. So I hope you can use that (everybody thinks he can  ) or otherwise it has to be the usual price. The 20th should be 2 days too late (maybe 1) as all will ship together (shipping is now 10 euros less). So I hope it is okay ? That's Okay Peter, please ship a 30cm Clairixa with the ram disk the same day as all the others. Juan
« Reply #69 on: January 15, 2016, 08:59:42 am » |
Thanks Peter...I've ordered the 3.5" - 2.5" sata hotswap adapter.
« Reply #70 on: January 15, 2016, 07:22:51 pm » |
Ahum ...
Now I don't like it anymore; Received a box today which was too heavy and too large to my idea about it. Just opened it (instead of doing that 3 hours ago) and found half of the disks to be 3.5". f*ck I guess that happens when all goes by telephone and ad-hoc is sorted out what is available.
So, now I can call about this Monday and then ... grrrrrrrrrrrrrrrrrrrrrrrrrr
« Reply #71 on: January 15, 2016, 08:28:14 pm » |
They mixed 2.5 and 3.5 ??? Someone surely smoked seomething while preparing the order...
« Reply #72 on: January 16, 2016, 10:02:28 am » |
No, I am to blame myself (at least partly). I guess that happens when all goes by telephone and ad-hoc is sorted out what is available. That 3.5" HDD is also an HDD which is shipped in the XXHighEnd PC, and I was looking in old shopping baskets and the pictures of the 2.5" and the 3.5" are exactly the same. Also, the type and specs etc. I looked for is the same for 2.5" and 3.5". Add to it that I am using such a 2.5" myself so I could easily recognize it (ahum). It is only that someone at the other end of the line could have noticed that I was (partly, because of availability) exchanging 2.5" SSDs for 3.5" HDDs. But like me, he was behind a computer screen and then things easily go like this. And as said, pictures look the same. Djeez, had I a bad mood yesterday. Peter
« Reply #73 on: January 20, 2016, 05:47:50 pm » |
  All went out today. Peter
briefremarks
« Reply #74 on: January 20, 2016, 06:07:35 pm » |
Thank you for all the effort!!! Looking forward to it. I saw the shipping notice this morning and can hardly wait.
