« Reply #30 on: January 04, 2016, 10:13:06 am » |
About two weeks ago I tested with an SSD Hi Peter - SSD sounds great but is there a potential problem? I understand that SSD has a limited time of about 2-3 months if it is not powered before it starts to lose bits. I would think that once installed many of us will leave our PC's on with the OS in RAM and the SSD sitting on a shelf. Paul
« Reply #31 on: January 04, 2016, 11:49:46 am » |
WHAT ? When flooded maybe. Ok, bad joke.
But Paul, I didn't start Googling for that yet, but is that really so ? Link ?
Thanks, Peter
« Reply #33 on: January 04, 2016, 12:51:38 pm » |
I am not definitive yet, but I don't think this is true ...
Arjan
« Reply #34 on: January 04, 2016, 01:03:07 pm » |
Hi Peter, There is a reaction on this statement in pcworld of 21 May 2015 stating:
It was intended to help data center and enterprise customers understand what could happen to an SSD—but only after it had reached the end of its useful life span and was then stored at abnormal temperatures. It’s not intended to be applied to an SSD in the prime of its life in either an enterprise or a consumer setting.
Maybe that will make more sense....
Regards, Arjan
« Reply #35 on: January 04, 2016, 01:13:14 pm » |
Yes. This is the full "article" : http://www.pcworld.com/article/2925173/debunked-your-ssd-wont-lose-data-if-left-unplugged-after-all.htmlOr one here, just randomly : http://www.itworld.com/article/2921047/hardware/no-you-wont-lose-data-on-your-ssd-if-you-leave-it-off-for-a-week.htmlThis is all not real proof that things will be fine after even many months, unless I am going to dig up one of my older ones ... (and then again it is no real proof). Peter
« Reply #36 on: January 04, 2016, 01:43:26 pm » |
OK, let's have some fun ... I found two old SSD's ... One is the old one of 90GB which held my Galleries of - as I see it correctly - October 2010. I inserted that in my Audio PC's OS removeable bay (haha) and ... Nothing. Empty drive. 5 minutes later I realized that I was looking at the wrong "PC" (the audio PC being accessible on that same monitor over RDC). Coincidentally I tested something with a RAM Disk in there and this was still there. So I thought it was the empty SSD, but it was an empty RAMDisk. Looked at the correct PC and ... Nothing at all. Ok, is in MinOS and that is not good for "new" devices. So ... removed it to ... Nope. Removed nothing because it is stuck. It is stuck in my removable bay that I need to boot the PC. That is, once I shut it down or when it hangs etc. I have to shut down the PC to take out the bay and (try to) fix it.   On to the other one. This says "Vista backup, December 27, 2009". Put that in a removable bay elsewhere and ... In full glory. Btw that is an OCZ Vertex. You know, those you "of course" should not use because "lolgically" they stop working after 7 days without power. I just calculated ... this has been without power for 2196 days but I did not count the leap years. I applied a chkdsk to it and no errors show up. I tell you : the risk of losing an SSD is higher when you use it. Regards, Peter
« Reply #37 on: January 04, 2016, 03:22:07 pm » |
After freeing the other one (also an OCZ Vertex, generation 2 this time) it appears that that one too is just fine.
I now can see that this was used for the last time on March 2, 2013. So this is 1035 days only.
Oh, the reason it got stuck is because it is 1.5mm thicker than normal (these days) standards.
I like to continue with the SSDs because they boot much faster ...
« Reply #38 on: January 04, 2016, 05:41:03 pm » |
You can see there is something abnormal with the SSD. The informations are unreadable Alain
« Reply #39 on: January 04, 2016, 07:23:37 pm » |
Oh ? what then ?
« Reply #40 on: January 04, 2016, 08:06:30 pm » |
You can see there is something abnormal with the SSD. The informations are unreadable  Plain English into Double Dutch in only ~1000 days! That's about as bad a deterioration as you could imagine.  Mani.
« Reply #41 on: January 05, 2016, 10:13:12 pm » |
Hi all,
I just sent everybody the invoice for the "RAM-OS". Can you please check whether I maybe forgot something for you ? You can just respond to the email, when needed.
A few remarks :
Some of you will find 72 euros for XXHighEnd 2.xx on the invoice. This will be because you did not obtain a Code for 2.xx yet (this requires a one-time 72 euros).
The shipping date has been set to Januari 14 for everybody. In practice this will vary a few days.
Please check your address on the invoice (I recall from at least one of you it has changed - but by now I forgot who it is).
Especially check for the additional cables you may have ordered and which I can have missed.
And of course ... when you did not receive the invoice, I did something wrong in the first place.
Best regards to all and thank you ! Peter
« Reply #42 on: January 06, 2016, 03:17:41 am » |
Thanks to you Peter ! Your dedication is matched only by your creativity and your sense of pushing the limits beyond our solar system ! One extra-terresttial to another: "Have you seen this guy going ? I am reasonably sure that he is not from this world..."  Alain
hbrew
Steve
« Reply #43 on: January 06, 2016, 06:53:09 am » |
Various setup options exist. May need a manual (?) so not to "break" it.
I use Amanero Combo 384; presume I install this onto the particular OS boots.
Currently using a Music Server and Audio PC which of course I can change the Music Server's TCP/IP as needed if already setup for that.
Previously written that all motherboards should work so that is good.
I believe there is a significant difference between RamDisk operation v.s. SSD and Music Server over LAN -- on minOS. Hope there is another significant improvement.
-- Anxious
XXHE RAM OS disk as of 2016.01.22 using Win10586
Player1: SuperMicro X11SPM-F, pre-owned Intel 6152 Gold Scalable 22 cores (set to 20), 6x8GB, Corsair GS600 ATX PS, 2.5-inch SANDISK Plus SSD for RAMOS - remains after booting, M.2 Kinston NV2 1TB NVME PCIe 4.0 Gen 4x4 3500MB/s music disk (or use external via Ethernet); cannot use M.2 NVMe SSD as boot device with CSM legacy boot so used a 2.5 inch SSD for booting; using onboard USB3.0 to DAC with good results but haven't tried my Silverstone USB card. Use KVM with 15 inch "portable" display once booted. AMAZING SENSE OF REALISM
Player2 (retired): ASRock Fatal1ty X99M Killer/3.1, was i7-5960X 8 cores changed to a pre-owned E5-2699v3 18 cores (set to 14), 48GB 2400MHz DDR4 RAM, RAMOS Win10586 on 120GB M.2 SSD, music files over LAN, ASUS GT210 Silent Graphics card, Silverstone USB 3.0 card
Music Server: ASROCK BeeBox direct Ethernet connection to player PC
XXHE 2.11 since about 4/2023 for the CPU core selection feature; arc predict; Min OS;attended or unattended; Device: Denafrips v5.0 or KS Amanero Streaming depending on DAC; KS Mode: Adaptive; Device Buffer: 2048 or 4096; tweaks - 43/1/-/1/1, Q1:14, Q3,4,5: 1; SFS 1 to 5; Straight Contiguous; Garbage Collect (sometimes can select); Clear Proxy; Denafrips Venus II DAC is 24bit/192KHz, DIY Dual ES9018 DAC is 32bits 384KHz; Cores 3-5; Player Prio:low; Thread Prio:RealTime; Clock Resolution:15ms; Stop Services (desktop, remaining, WASAPI and WIN10); Use Remote Desktop; Don't Keep LAN, PAN or WiFi; OSD Text; Show as Wall Paper
Equipment: Denafrips Venus II R2R DAC and DIY Dual ES9018 Twisted Pear Audio DAC boards using Amanero USB receiver (384KHz) with isolated buffer (ISO7640FM), preamp is DIY Lynn Olson Raven with an added Phono Preamp; Douglas Self Trimodal selectable Class A or Class AB 20W amp; Klipschorns (modified slightly); balanced mains power transformers: one for amp and one for low level equip; Alt. Speaker: ScanSpeak (2) 10" Revelator, (2) Illuminator 4", (1) Beryllium Dome Tweeter, tuned ports
Room Treatment: 4, 4 x 24 x 48 inch panels
« Reply #44 on: January 08, 2016, 11:26:02 am » |
Dear people,
I have been thinking about this yesterday and then decided to shut up, but I can't because formally I need to say this :
It hasn't been said so explicitly I think, but from the former (kind of) "group buys" it should be known to you that this is cheaper than when separately arranged for later. It is quite easy :
If I need to purchase an SSD for you separately, the supplier charges 10 euros for the shipment (and no, I am not going to put 20 etc. SSDs to stock, hoping some will buy them).
If we ship all together, it is about 10 euros cheaper, which is in today's shipping calculation (different per country). In other words, for this smaller and few weighing package (Netherlands not counted) it will be 10 euros more for that.
Point is : Maybe nobody is afraid of paying 20 euros more later, but I personally don't like to pay that 20 euros 20 times, later, only because 20 of you thought "oh well".
In other words, the 360 of today will be 370 after today and e.g. 38 shipping for the US of today will be 48 for the US, later (this is an extreme at the low (cost) side - the other extreme is 44 which becomes 56 (Norway, Australia) - others are in between that).
So you see, I have to tell this or otherwise later you did not know / could not know.
Regards, Peter
