esimms86
« Reply #15 on: November 12, 2015, 04:05:57 am » |
Count me in. I may even spring for another XXHE PC.
Esau
2010 mac mini running Windows 7 Professional N 64bit *SP1* and XXHE on SSD in Boot camp mode, mac os x Snow Leopard with Audirvana Plus also on SSD, music on separate 2 Tb firewire La Cie HD / 8 Gb RAM/ Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *30*/0/0/0/0 (Dev.Buffer = *4096*) / ClockRes = *15ms* / Straight Contiguous / SFS = 170 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3/ *Minimize OS = On* / 24/768 Phasure/Is Phasure NOS1/ NOS1 async USB DAC, Driver v1.0.2 -> Marantz PM KI Pearl amplifier ->Gallo Strada/Gallo TR3 subwoofer
Dantana
« Reply #16 on: November 12, 2015, 11:29:01 am » |
Hi Peter
I like to re-confirm. Thanks
Daniel
XXHighEnd PC i7 3930K Hyperthreading On (12 cores) @0.43GHz, 16GB, Windows 8 Pro 64bit on SSD (ext batt. powered), XXHE on 4GB RAMDisk (IMDisk), music on OS SSD & LAN, DVD Drive power removed, USB 2 & 3 bios disabled
1.186i (Apr 15, 2015*) Engine#4 Adaptive Mode / Q1/-/3/4/5 = 6/-/1/1/1 / Q1Factor = 1, Dev.Buffer = 4096, ClockRes = 1.0ms*, Memory = Straight Contiguous, Include Garbage Collect, SFS = 0.32*,max 120 , not Invert, Phase Alignment Off, Playerprio = Low, ThreadPrio = Realtime, Scheme = Core3-5, Not Switch Processors during Playback, Playback Drive 4GB RAMDisk (IMDisk), UnAttended, All Services Off, Keep LAN - Not Persist, No WallPaper, No OSD, No Running Time, Minimize OS, XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On, Double-Octo Custom Filter with Arc Prediction Upsampling, Driver v1.0.3 (2ms) XXHighEnd PC via USB3 (Silverstone EC04-E, isolated*) > Clairixa USB cable* > 24/768 Phasure NOS1a async USB DAC > XLR > Soulution 725 Preamp* (XX vol. -6.0db)> Soulution 711 power amp > Magico M Project
Stanray
« Reply #17 on: November 12, 2015, 11:52:49 am » |
Prerequisites When you want to apply all in the meant well-fashion, you will need a 2.5" hot-swap removable hard drive bay (people with the XXHighEnd PC as povided by Phasure will have that). This needs to connect to internal SATA, preferably SATA3. Notice that you really don't need to build in the bay and that it can lay on top of the PC or anywhere else; If you can access it easily to remove the HDD from it (or insert it) then it is fine. Please notice : When you arranged for some external enclosure that connects via eSata (which often is a connection at the back of the PC) it is up to you whether you can boot from that (connection). But, you can try in advance (put in a 2.5" OS disk and see whether you can make it boot from it).
For some, those who have some space behind their pc, a 2.5" SATA Removable Hard Drive Bay for a PC Expansion slot might do the trick, f.i.: http://www.startech.com/HDD/Mobile-Racks/25in-SATA-Removable-Hard-Drive-Bay-for-PC-Expansion-Slot~S25SLOTRStanley
« Reply #18 on: November 12, 2015, 12:17:42 pm » |
Hi Peter - count me in
« Reply #19 on: November 12, 2015, 12:22:27 pm » |
Stanleyyyyyyy ...  Maybe I am wrong, but I recall that it is not the first time that you come up with something that at least to me is new. But then I'm slow. Now I have another strange hint, which nicely combines : Turn around your PC - like I do. So in my case the back is at the front side. The only inconvenience is the power button (the boot button) which is now in the "back". For visualisation see below. But what this is about is that (for me) just a tad too often I need to plug in (and out) the monitor cable, keyboard cable and mouse cable, while I by standard don't want to have them in (RDC controlled). But go figure - so many installes I perform (can't go over RDC). Btw, on top you see my removable bay thingy, this disk sticking out. Stanley, great find ! Peter PS: Never mind all the wires - I used an existing photo.
« Reply #20 on: November 12, 2015, 12:33:10 pm » |
For some, those who have some space behind their pc, a 2.5" SATA Removable Hard Drive Bay for a PC Expansion slot might do the trick, f.i.: http://www.startech.com/HDD/Mobile-Racks/25in-SATA-Removable-Hard-Drive-Bay-for-PC-Expansion-Slot~S25SLOTRStanley Good idea Stanley, this will be an easier place to put it in my PC as it has the expansion slots in the upper side  Juan
Stanray
« Reply #21 on: November 12, 2015, 01:24:45 pm » |
Haha, well Peter, I'm a tidy type of a guy, so I'll stick to the back.
And, please put me on the list. Post.nl is ok for me.
Thanks, Stanley
Arjan
« Reply #22 on: November 12, 2015, 07:28:12 pm » |
Put me on the list as well. Yes, something new......
Short question: I currently do not have a videocard in the computer. It runs via rdc from the iPad. Will it be needed for the first startup with the new drive to have the videocard in again? Because rdc will not be possible out of the box? What do you think.
Regards, Arjan
« Reply #23 on: November 13, 2015, 08:57:58 am » |
Hi there Arjan,
At this moment the answer should be Yes - needed. But this is because nothing is capable of telling what to boot into if you don't want the default. This is also what's holding up XXHighEnd 2.03 because I try to make options for this (but is not so easy).
Example : When the disk is shipped, it *has* to come with the BASE OSes in Normal OS Mode. Why ? because else D/A converters may not install automatically (that is, their drivers). Your NOS1a is an example of that. Now, automatic boot is into one of the RAM-OSes and tell that to boot into MinOS when the DAC is installed, does not help much (because the boot always takes the BASE OS to copy to RAM). So at some stage we *have* to denote which OS to boot into and this can not be done over RDC.
If I can get XXHighEnd to prepare for the next boot (which one to choose) then all is fine with RDC. Obviously we also use this to try "the other" OS.
I hope it is clear ! Peter
brunok
« Reply #24 on: November 13, 2015, 02:10:14 pm » |
I would like to ask SinterKlaas to be put on Peter's list, and for Amerigo to please choose the faster route (HoHoHo).  Thanks, brunok
« Reply #25 on: November 13, 2015, 02:18:17 pm » |
« Reply #26 on: November 21, 2015, 09:25:32 am » |
Count me in too. Have already sent you a PM on this subject.
« Reply #27 on: November 21, 2015, 09:55:53 am » |
A short "update" :
I could not work on this the past two weeks because now first XXHighEnd 2.03 had to go out. Also there's the sort of disappointment about 10586 which I originally planned to be on the disk (to replace the 10565 which is on there now).
To be honest I am now waiting for people to judge 10586 in its real environment (MinOS) while so far there is none. Also not from myself because I didn't get around the required 11 hours (for me ! (RAM)) to install 10586. But I guess it needs to happen.
So be patient please as the disk *will* be there for sure. Peter
« Reply #28 on: December 26, 2015, 11:01:04 am » |
A small update again :
With the XXHighEnd-internal boot possibilities now (2.04) at hand, I can freely continue the testing without too much "pain". I will make the XXHighEnd software now so that it can also update further boot data, so when the disks go out we will be able to "upgrade" to another OS.
About two weeks ago I tested with an SSD and while that works better (faster) than a HDD, it was too small (I didn't pay attention on how large (GB) it has to be). Since a week now I have a larger one (240GB) and will test that soon. I expect it to be OK. It is only that the price will be 10 euros higher (the SSD is more expensive than the HDD I originally planned) but I think it is worth while : - less risk on damage with transportation; - less risk on damage with taking it out (an hdd might still spin and you need to know how to handle it to prevent damage); - booting goes in 2 minutes full cycle instead of 3 minutes.
I now have a 100mbit upload link physically ready in the main office, and it will be functionally available the upcoming week. This means that the part about "installing a new live OS" will be ready soon as well, regarding the transport of it. But that too will need the support of software (XXHighEnd) so that it can "self install" and be obtained in the Boot Menu without too much hassle.
hbrew
Steve
« Reply #29 on: January 04, 2016, 07:05:50 am » |
I want to try this out too. Put me on the list -- following behind the others.
XXHE RAM OS disk as of 2016.01.22 using Win10586
Player1: SuperMicro X11SPM-F, pre-owned Intel 6152 Gold Scalable 22 cores (set to 20), 6x8GB, Corsair GS600 ATX PS, 2.5-inch SANDISK Plus SSD for RAMOS - remains after booting, M.2 Kinston NV2 1TB NVME PCIe 4.0 Gen 4x4 3500MB/s music disk (or use external via Ethernet); cannot use M.2 NVMe SSD as boot device with CSM legacy boot so used a 2.5 inch SSD for booting; using onboard USB3.0 to DAC with good results but haven't tried my Silverstone USB card. Use KVM with 15 inch "portable" display once booted. AMAZING SENSE OF REALISM
Player2 (retired): ASRock Fatal1ty X99M Killer/3.1, was i7-5960X 8 cores changed to a pre-owned E5-2699v3 18 cores (set to 14), 48GB 2400MHz DDR4 RAM, RAMOS Win10586 on 120GB M.2 SSD, music files over LAN, ASUS GT210 Silent Graphics card, Silverstone USB 3.0 card
Music Server: ASROCK BeeBox direct Ethernet connection to player PC
XXHE 2.11 since about 4/2023 for the CPU core selection feature; arc predict; Min OS;attended or unattended; Device: Denafrips v5.0 or KS Amanero Streaming depending on DAC; KS Mode: Adaptive; Device Buffer: 2048 or 4096; tweaks - 43/1/-/1/1, Q1:14, Q3,4,5: 1; SFS 1 to 5; Straight Contiguous; Garbage Collect (sometimes can select); Clear Proxy; Denafrips Venus II DAC is 24bit/192KHz, DIY Dual ES9018 DAC is 32bits 384KHz; Cores 3-5; Player Prio:low; Thread Prio:RealTime; Clock Resolution:15ms; Stop Services (desktop, remaining, WASAPI and WIN10); Use Remote Desktop; Don't Keep LAN, PAN or WiFi; OSD Text; Show as Wall Paper
Equipment: Denafrips Venus II R2R DAC and DIY Dual ES9018 Twisted Pear Audio DAC boards using Amanero USB receiver (384KHz) with isolated buffer (ISO7640FM), preamp is DIY Lynn Olson Raven with an added Phono Preamp; Douglas Self Trimodal selectable Class A or Class AB 20W amp; Klipschorns (modified slightly); balanced mains power transformers: one for amp and one for low level equip; Alt. Speaker: ScanSpeak (2) 10" Revelator, (2) Illuminator 4", (1) Beryllium Dome Tweeter, tuned ports
Room Treatment: 4, 4 x 24 x 48 inch panels
