November 24, 2024, 11:39:46 am *
Author Topic: XXHighEnd Model 0.9t-5 (adds Wallpaper Track Data for Cue Files)  (Read 7487 times)
« on: January 02, 2008, 10:13:53 pm »
Or IOW it was overlooked that this needed special attention.
Furthermore :
  • It appeared that Cue File Tracks could not be moved within the Playlist Area (they could (note : by dragging), but then wrong data showed). Solved.
  • The Active Search in the Library Area worked not much conveniently when a search text was entered, left there, and XXHighEnd was Quit (Off);
    At the next startup the preloaded items (Albums or Tracks) was limited to what the search text implied.
    Currently the full list is reloaded at a next startup, and ctrl-v (paste) in the Library Area will reload the last selection (as was implied before by means of Active Search, before Quitting).
    It is obvious that there is no reason to apply this "ctrl-v" automatically, but this can't work reliably (so, a technical problem).
  • Restarting XXHighEnd after UnAttended Playback finished worked, but actually there was no reason why XX should not be brought up after Playback finished in all occasions. This is now officially arranged for.
  • When Tracks are loaded from the Library Area they could appear right across the "XXHighEnd" version data in the Playlist Area;
    This has been solved now, although variations can still exist where this is happening wrongly.
  • It could happen that a situation "ChangeWP stopped working" occurred. If all is right this is solved.
* XXHighEnd-09t-5.zip (1156.33 KB - downloaded 742 times.)
