April 17, 2025, 11:44:44 am *
Author Topic: Best version for Vista  (Read 6886 times)
Chris V
« on: October 23, 2015, 10:14:26 am »
Hi Peter
Its 4 years since I was here last, hope you're keeping well.
Anyway 4 years ago I took a decision to continue using XXHighEnd because of its great sound but to avoid all the stress of trying to keep up with the updates and testing. I just wanted to listen to the music without too much aggro.
So I locked down with version 0.9W - 9b which of course has several early development glitches. I have lived with this in order to keep the sound quality, but I admit there have been moments of weakness when I have contemplated going back to a CD player.
So to my question.
I have the same dedicated Dell computer for XX HighEnd with Vista Ultimate operating system. If I wanted to come up to date with XXHighEnd, which version would be best for me?
Then to SW1X Signature DAC
« Reply #1 on: October 23, 2015, 10:31:12 am »
Wow Chris, that has been a long time indeed !
Your question is quite difficult to answer because exactly nobody that I know still uses Vista. That I know, and obviously I already did not think about you. Anyway there's no feedback about it anywhere.
And so all I can suggest is the last version. And what I can already tell is that most of the latest SQ improvements came from OS facilities, starting with Windows 7 first (RTM) version and ending with Windows 8. In Windows 10 no real extra features are used, but it sounds much better than Windows 8 anyway.
FYI : There will be "no comparison" with Vista any more because of the so many improvements over improvements (we wil all agree about that); however, what the current XXHighEnd version attributes to that when it is "just Vista" ... you should just try it. But it won't be worse, I guess.
Sorry to be vague, Chris, but it is just impossible to tell.
Chris V
« Reply #2 on: October 23, 2015, 10:39:50 am »
Thanks for the prompt reply Peter. I had guessed that the later operating systems would have allowed you to get more from XX HighEnd, so maybe one day I will upgrade my computer.
But, its good to hear that the latest version will still operate with Vista, (albeit compromised from what you can achieve now), so I will give it a go.
Some of the manufacturers of kit I bought some 4-6 years ago have gone bust so I am pleased that you are still around. It seems a tough business out there.
« Reply #3 on: October 23, 2015, 02:30:41 pm »
Chris, some will never die. Or at least don't plan to. Happy
If you need help you will anncounce yourself, right ?
Chris V
« Reply #4 on: October 23, 2015, 02:50:14 pm »
You can count on it Happy
