April 08, 2025, 09:23:39 pm *
Author Topic: Silverstone still in use ?  (Read 7116 times)
« on: October 22, 2015, 10:58:53 pm »
-Are you guys still using the Silverstone soundcard? It lasted only 5 songs in my system back in 2014. I found it too colored and edgy in the treble. (Yes, I isolated it in both ends).
« Reply #1 on: October 23, 2015, 02:28:02 pm »
pedal ... I still use mine ...
KnB
« Reply #2 on: October 23, 2015, 03:51:11 pm »
Hi Pedal,
I am still using the card. Will recommend to try Peters USB cable.  Happy
listening
« Reply #3 on: October 23, 2015, 09:09:00 pm »
Hi pedal,
I'm using it too with Peter's USB cable.
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #4 on: October 23, 2015, 09:50:20 pm »
Hi Petter,
I am doing the same (Silverstone + Peter's USB cable, aka "Clairixa"), a formidable combination Happy
