November 23, 2024, 08:42:28 am *
Author Topic: Prevent W10 Windows Updates (10074)  (Read 16098 times)
« on: October 13, 2015, 06:08:37 pm »
All,
Elsewhere it has been determined that after booting back into Normal OS (coming from MinOS) the Windows Updates in Windows 10 were turned on again; I admitted a "thinking error" and said that after booting in Normal OS it should be turned off again (Stop Button - RightClick).
This was again wrong thinking, and all it requires is turning off the Updates under Normal OS once. Thus when going to MinOS and back to Normal OS, this returns to the state the OS was in when leaving Normal OS (for MinOS).
Summarized : Just turn off in Normal OS. That's all.
I did not test it but it should just work like that.
« Reply #1 on: October 14, 2015, 09:45:11 am »
I am almost sure I did it like that but if needed to go back to normal OS then will unplug the network cable to be sure that there is NO communication with the windows server anyhow...
doublelife
« Reply #2 on: November 20, 2015, 10:27:59 am »
There will be short times when I need to connect my music laptop to the internet, e.g. for driver download, software activation etc. Do the W10 updates only get though on powering down and up again (I would always turn wi-fi off then anyway), or could they sneak in whilst switched back on after powering up and connected for say 10 mins??
PC  i7 / W10 10074 (x64) / hyperthreading ON (12 cores) / 32GB RAM / XX - OS on separate dedicated 256GB SSD - XXHighEnd: 2.03 / Engine#4 Adaptive / 4096 / Q1=14  / xQ1=10 / Q3,4,5=0/1/0 / SFS=4-120 / Straight Contiguous / Clock Resolution = 1.0  / Scheme 3-5 / 16x Custom / Peak Extend = OFF / Unattended / Minimize OS / Phase Alignment = OFF / XTweaks = 43, 100, 1, 1, 1 > 24/768 NOS1a 75B async USB DAC driver v1.0.4 1ms > KGSSHV Carbon amp > Stax SR-009
nik.d
« Reply #3 on: November 20, 2015, 11:01:00 am »
I was to write elsewhere however this is good place as well:
There's small script (bat file) on MDL site called "Windows 10 Toggle Tweaker" presently at ver. 2.8 that efficiently stops
Win Updates, removes Cortana, Project Spartan, OneDisk etc. and does not interfere with Peter's OS optimization.
I'm playing with W10074 at the moment and can say it sounds fantastic - with XXHE 2.03 of course.
As someone said (think Joachim) I'm moved from 20th (Win8) to 1st raw now.
However, I have some issues and am not quite confident on staying with 10074:
- NOS1 driver keeps toggling sampling freq. and shows FIFO and other comm errors.
- Restarting PC brings loud PLOP in speakers
- Creating Restore Point while going to MinOS not possible, XXHE reports 'No Virtual Disk Service running' or similar message
« Reply #4 on: November 20, 2015, 11:15:23 am »
George, please post that Driver Toggling in a separate topic. I am sure someone will respond to it.
Otherwise something does not seem right;
I have seen that "No Virtual Disk running" myself and I recall that it was sufficient to :
- Start Explorer;
- RightClick on MyPC or whatever it is called;
- Manage PC
- Disk Management.
Then all is fired up to make a Restore Point (mind you, as I recall but I also recall that 10074 was fine with this to begin with and 10240 is how you describe it).
« Reply #5 on: November 20, 2015, 11:16:30 am »
Paul,
In XXHighEnd RightClick the Stop Button and choose "Stop Windows Updates".
Do this in Normal OS.
PS: I realize that both George (nik.d) and me don't answer your question really ... (and I don't know either).
« Reply #6 on: November 20, 2015, 12:02:58 pm »
from my experience the updates are starting as soon as your are connected with the internet. I downloaded the 3.5 only and during that short time span 3 updates have been installed.
doublelife
« Reply #7 on: November 20, 2015, 01:14:02 pm »
Thanks. Where is the 'stop' button. I only installed 2.03 last night and haven't got into it yet.
« Reply #8 on: November 20, 2015, 01:19:45 pm »
in XXH you press the "S" button on the upper right side, than see compartment "Services and OSD"
« Reply #9 on: November 20, 2015, 03:07:17 pm »
scratching
Next to the Play button. whistle
Joachim must be talking about something I am not aware of.
haha
« Reply #10 on: November 20, 2015, 03:49:45 pm »
scratching
haha
 scratching
 unsure  so we are not talking about preventing W10 updates.
wacko
« Reply #11 on: November 20, 2015, 04:01:21 pm »
Well, I am, but you ??
Right click the Stop button :
Bottom option, obviously (shows n/a here because of being in MinOS).
PS: Maybe you are confused by George, who started to talk about something else ?
« Reply #12 on: November 20, 2015, 04:51:01 pm »
that  wacko is me, not you  Happy
Question: Stop W10 Services is what for? No tool tip appears.
« Reply #13 on: November 20, 2015, 06:40:05 pm »
Joachim,
I forgot; Must look in the ToolTip.
Eh ...
What about opening a new topic for this. It's messy as it is already. Ok ?
Meanwhile I will dig up the answer for you and post that in there.
« Reply #14 on: November 20, 2015, 07:29:41 pm »
Joachim,
Eh ...
Hi
NO, it is not messy. You wrote (with a picture) in the manual for 2.02 about "Stop Windows Updates" and i did forget, and my former advise here is not correct. This button is new and my speculation/assumption was wrong. So, nothing to worry about.
