April 01, 2025, 01:03:39 am *
Pages: 1 2 3 4 [5]  All
Author Topic: No coverart with NAS  (Read 133315 times)
« Reply #60 on: March 17, 2018, 05:08:29 pm »
Accessing the Cover art image folder from the Audio PC is not possible, a window pops up “Class not registered”. This happens in normal OS as well as Min OS.
All my rips are using dBPoweramp & the cover art image is obtained through their database.
« Reply #61 on: March 17, 2018, 06:00:58 pm »
Hi Arvind,
Ehh ... you mean when you start Explorer on the Audio PCm go to the folder where the image files reside and then "they are / have to be accessed through the DBPoweramp database ?
No. That can't be right. And if it is correct then obviously XXHighEnd can't reach for the files. Envision that XXHighEnd would do the same as you do (grab the file via Explorer).
Please keep in mind : the Coverart images reside in the same folder as the music files for an album, or perhaps in a sub folder of that. Not in any different place (like JRiver could do that, but for obvious reasons no random program not knowing about that can "find" them as such). Btw, if I start to be correct about this and thus "knowing" that this never can work like this, how is it related to FLAC ?
So what am I missing ?
(or you Happy)
« Reply #62 on: March 18, 2018, 07:45:07 am »
It seems the problem of no cover art while playback, at least in my case, was due to corrupt image files in a few of the FLAC music folders. I deleted the image files & downloaded new ones & now it’s working fine.
However starting Explorer from the Audio PC & trying to open the image files WAV or FLAC, does not open the files. From the the music server pc the image files open.
« Reply #63 on: March 18, 2018, 08:22:54 am »
Hello Arvind,
Maybe. But maybe it has been a sort of rights problem. So ever back the files got there by "a" means (copied from somewhere via some means and then especially thinking about the PC (or Mac) doing it) and now you do this again in your own environment and all is fine.
So this is a completely different issue and btw again not FLAC related. But also no problem. So in case I got you worried, my examples about Explorer were only virtual so you could understand what internally kind of happens and how you can mimic this yourself. This though, is to some degree as we now see as working really via Explorer is more formal than what happens in a program (or how the program can be manipulative regarding this).
So no problem and don't attempt to view the images on your Audio PC. AND :
Be careful, because thinking about this, you probably won't be able to view any picture on the Audio PC by normal Windows means. This is how IrfanView ended up in the XXHighEnd folder since 209 or 2.08 (but recently). This is all related to MinOS and what 14393.0 can still do (or not do).
Anyway, problem solved. For Richard too I assume, since he doesn't seem to be compelled much to (re)join the discussion Happy Haha.
Thank you very much for your help, Arvind. And it helped yourself !
Rmalits
« Reply #64 on: September 13, 2019, 07:41:04 am »
as  release 2.11 of XXHE is on the way, I would like to ask you if a solution could be found with this new release for the cover art problem when using a NAS as music storage.
I am a happy user of your excelent technology for more than three years now, but all this time without seeing the cover art when playing unattended from my Synology NAS.
Therfore I again did some testing with the same results as described above some time ago:
- playing in attended mode, cover art is always there
- playing WAVE-files unattended, cover art is always there
- playing FLAC-files cover art does not show up in unattended mode
Something maybe new to this topic, I found out:
After loading an album in FLAC format into the playlist the folder.jpg on my synology NAS obvioulsly isn‘t closed by the operation system of the NAS. In this state it is for example not possible to rename or remove folder.jpg on the NAS.
When the same album in WAVE format is loaded into the playlist, folder.jpg does not stay open. It can be handler freely.
So, I guess - or better hope - that this could be the reason that the coverart is not shown when playing FLAC- files in unattended mode, because the OS of the NAS may not allow another access to folder.jpg.
Maybe a simple „close“ command after loading folder.jpg in XXHE would solve this long lasting problem.
Peter, is it possible that you include this kind of fix into release 2.11 ?
Kind regards
Richard
« Reply #65 on: September 16, 2019, 12:29:16 pm »
Hi Richard,
That could be crucial additional information.
So I put it in the Todo and we will see what happens. I am going to try to make something of it …
Rmalits
« Reply #66 on: September 21, 2019, 09:38:19 am »
Thanks a lot, Peter!
That would be great!  Tadaaaa
Best regards
Richard
« Reply #67 on: April 01, 2020, 05:03:06 am »
Richard, does anything change to this issue when you use  Core Appointment Scheme 1-3 ?
