« Reply #15 on: October 10, 2015, 05:30:03 pm » |
Last resort : Put a bit of music on the Audio PC, in the exact same structure (start with the root directory) and play from there without changing a single setting. Grr
Stanray
« Reply #16 on: October 10, 2015, 08:02:37 pm » |
Done. I put it on the C: drive in the same structure: Music/Music Type/Artist/Album/files.
And now the album coverart nicely does show in unattended.
So, good or bad news?
Stanley
Stanray
« Reply #17 on: October 10, 2015, 11:33:17 pm » |
 Playing and trying I found out that flac file albums don't show coverart when playing unattended, but that wav file albums do show coverart.  Furthermore, when pressing play it takes much longer (45 seconds) for an album to start playing compared to the usb external HDD. But it takes around 2 minutes (!) before a wav album starts playing (but then it does show coverart). Something wrong with the speed of the network connection (the NAS itself?)? Stanley
« Reply #18 on: October 11, 2015, 10:03:33 am » |
Hi Stanley,
Reading this, indeed my initial response would be that your network is very slow. Whether too slow for something ? Anyway, envision the size of the FLAC vs. the WAV and the difference in speed.
But it is not so easy ... In this situation you MUST use a RAMDisk for Playback Drive. Are you doing this ? N.b.: The "must" counts for FLAC (and WAV is all right with it just the same).
For your reference : A FLAC album maybe takes 3-4 seconds to start playing (Unattended and loaded over the LAN) and a WAV can take 15. This is because WAV tracks can't be dealt with in parallel; FLAC does.
Let me know when you find more, but you are on the right track (pun) now.
Stanray
« Reply #19 on: October 11, 2015, 09:25:44 pm » |
Yes, I do use a RAMDisk for Playback Drive.
Concerning the speed, I observed speeds of between 5 and 12 Mbps when an album is being loaded from the NAS.
Stanley
« Reply #20 on: October 12, 2015, 12:18:34 pm » |
 Playing and trying I found out that flac file albums don't show coverart when playing unattended, but that wav file albums do show coverart.  No, I don't get it. Sadly, the procedure for FLAC *is* a bit different, compared to WAV. But all what could come from it, is the other way around (FLAC shows them, WAV does not). By now I feel it can be a bug on my side, but how or what - no clue. There's the field (in Settings) Copy to XX Drive by srtandard (or something like that); what have you set it to ? (active or not). And what happens when you set it to the other state ? Try WAV with this as well ! I mean, I want to know whether that now maybe stops working too.  Peter
Stanray
« Reply #21 on: October 12, 2015, 09:29:36 pm » |
"Copy to XX-Drive by Standard" was not set, but when set it doesn't change the problem, either with FLAC or WAV files. But it does make the whole proces around 4 to 5 times slower.  Stanley
« Reply #22 on: October 13, 2015, 08:10:04 am » |
Hmm ... If you mean that what 2 minutes was, now is 10 minutes, then I would ditch that PC and blame it for this problem in the mean time. Also, if this happens with FLAC just the same (slower) then I can't even believe that.  Peter (out of ideas  )
Rmalits
« Reply #23 on: December 25, 2016, 09:17:51 pm » |
Hi Peter, I know, it's Christmas... So please... take your time... I don't expect any answer before all your celebration will have ended  We caught a bit of a flew during Christmas and we have to be in bed. So I took my MS Surface to find out a bit more about my wallpaper problem. When we met in Holland about 10 days ago, I told you, that I never see a wallpaper during unattended playback when playing flac files. It is like this: 1) Playing music from my Synology NAS: When I play flac files in unattended mode, what I do most of the time, no wallpaper appears at all. When I play wav files in in unattended mode, I get the wallpapers when the the first track starts to be played, but for some seconds only. Then something strange happens: XXHE starts again automatically, so if I would have pressed Ctrl_X (but I didn't). 2) Playing music from local drive (C:, D:) To test it for music from the local disk I copied some folders with flac files to the harddisk of the audio PC. Playing these files from there the behaviour of wav and flac files is the same as for wav files in 1) The wallpaper appears for some seconds only and XXHE is mystically started again automatically. As I wrote above: All this is not urgent. I am used to XXHE without wallpaper for more than half a year now. Happy hollidays! Richard
« Reply #24 on: December 26, 2016, 12:29:51 pm » |
Hi Richard, After reading your post I started to search for something unknown, but my search terms were starts automatically (no quotes) and it brought me right away where I wanted to be : http://www.phasure.com/index.php?topic=3605.msg38547#msg38547I seriously did not see the relation with this even unknown I sought, but now seeing it - I think it is related. So ... Do you use Start Playback during Conversion ? Stanley, did you already solve this ? Kind regards, Peter
« Reply #25 on: December 27, 2016, 02:23:56 pm » |
In my case too no cover art with Flac files. With Wav no problem. 2.06/2.07 both have this issue.
« Reply #26 on: December 27, 2016, 02:38:50 pm » |
Aha ... now we are getting somewhere for real ... Thank you for sharing this, Arvind !
Are you saying that 2.05 did not show this issue ? (I think you can't know really because you received the Stealth PC with 2.06 .. correct ?)
With Attended the (FLAC) Wallaper just appears as should ?
Are you (all) sure that the right coverart appears when WAV ? I mean, that you always see the correct track playing, assuming you also show the back (no real back cover being present to begin with) ?
Suppose - when just in Minimuzed OS ! - you enable all Shut Down Services (so let as much stay as possible), is there a difference to be seen ?
Thanks ! Peter
« Reply #27 on: December 27, 2016, 03:29:26 pm » |
Don't recall with 2.05, too long back & at that time no Stealth LPS.
With NAS cover art shows in attended but not in unattended. For Flac files. Wav is fine in all respect.
With hdd/Flac files cover art/wall paper shows in attended as well as unattended.
So the problem lies with Flac files on NAS, at unattended.
With NAS/Wav files no problem in unattended or attended. Shows correct track playing.
« Reply #28 on: December 27, 2016, 03:56:56 pm » |
Arvind, super. Can you also try what happens when you set all services to stay in Settings ? (just do so in MinOS so all what's needed is a sceencopy so you can revert to how you had it after the trial (just set back and no reboot orr anything needed)).
Thank you once again, Peter
« Reply #29 on: December 27, 2016, 04:22:43 pm » |
Attached a pic of the settings...is this what you wanted?
With NAS/Flac/unattended, wall paper doesn't show.
