November 22, 2024, 09:35:17 pm *
Author Topic: Ifi USB Purifier  (Read 9070 times)
Shreekant Somany
« on: September 30, 2015, 09:09:08 am »
I have come across this usb purifier made by Ifi  audio which claims to clean the data of all noise. this attached between the comp. & the dac.
Has anyone used it?
Is it worth trying?
Details are available on Ifi audio website if anyone wants to know more.
shreekant
« Reply #1 on: October 31, 2015, 01:12:20 am »
iPurifier 2 – Active Asynch USB Purifier Hub!
Filter-packed to the nth degree
Southport, UK – 30st Oct 2015
Leading the field in USB audio technology
The iFi obsession with cleaning up the USB audio chain continues. Drawing from the knowledge pool of AMR and on the heels of the iUSB3.0 comes the iPurifier2. It is an Asynchronous Active USB Purifier Hub. It offers 100X to 100,000X [1] noise reduction for USB Power, underpinned by REclock®, REgenerate® and REbalance®. It is so intelligent, it is an active USB hub so it can extend USB lengths. Used at the end of the chain, just select the type A, B [2], C or micro USB connector version to enhance any and every USB audio device.
Features:
Active Noise Cancellation® military-grade circuit for 100X to 100,000X noise reduction
REgenerate® and REclock® asynchronous technology to eliminate jitter
REbalance® re-corrects USB signal balance to cancel DC offset noise
Compliant with USB Audio Class 2.0 for DSD/PCM/DXD formats (to 768kHz and beyond)
Aluminium aircraft-grade ‘Final’ connector (impedance 90 ohms)
4 versions – USB A, B, C and micro connections
The retail price of the iPurifier2 is US$109 (ex-tax) or Euro119 (incl VAT).
[1] Magnitude of improvement dependent upon where in the audible frequency range.
[2] Type B is available now, types A,C and micro USB to follow.
The price does not deter....
Regards, Coen
Chris V
« Reply #2 on: October 31, 2015, 09:24:04 am »
Hi Shreekant
Can you detail your PC playback system as shown here.
http://www.phasure.com/index.php?topic=124.0
That way people can better advise on improvements.
Cheers Chris
Then to SW1X Signature DAC
xp9433
« Reply #3 on: October 31, 2015, 09:44:08 am »
I suspect this new iFi iUSB 3.0 usb regenerator could be a better prospect.
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/ifi-iusb-3-0-universal-serial-bus-industry-standard-cables-connectors-and-communications-protocols-between-computers-and-electronic-devices-regenerator-xxx-pictures-25985/index3.html
Page created in 0.174 seconds with 19 queries.
