November 23, 2024, 01:38:30 pm *
Author Topic: PC switching off and rebooting randomly... all of a sudden  (Read 25113 times)
« Reply #15 on: September 23, 2015, 02:07:50 pm »
Thank you for sharing that, Mani.
« Reply #16 on: October 01, 2015, 08:57:19 am »
Mani,
I have a Teradak ATX 350 running for 3 continuous days now, and the heatsinks are 30 Celcius. I did not measure, but noticed that when the sun is shining on the unit, it gets some warmer (estimate : 40C). Ambient is just over 20C.
During playback nothing changes but if anything it gets cooler (this is no surprise to me).
Keep in mind that my processor runs at 430MHz and that this sure can matter. When idle, this 430MHz is to be compared with 1200MHz in normal circumstances (when you never changed the processor speed in the BIOS). Do notice that when Playback is going on, this is to be regarded as "Idle" (nothing will trottle-up because of it).
What can have happened in your situation is that something got in a loop during your not being present and that one of the processor cores went to 100% - even in turbo mode. Now that core runs at 3800MHz continuously, which your cooling system may be capable of (to keep all sufficiently cool) but which draws the (thermal) 135W of the processor continuously. And *that* will make the PSU hot for (quite) sure.
If you, next time, see the PSU so hot, try to observe TaskManager - Performance Tab and see whether one of the cores is at 100% (this shows as 8.33% with 12 cores ( 100 / 8 )).
« Reply #17 on: October 02, 2015, 10:45:57 am »
Hi Peter, thanks for this.
I did take a quick look at Performance in Task Manager when the PC first started switching off, but couldn't see anything untoward. But there's obviously something not right at my end, with such high heat sink temperatures. I'm going to reduce the speed in the BIOS and also take a look at temperature readings in general (CPU, etc) whilst I'm in the BIOS. (Will need to reinstall my GPU card to do this - PITA.)
Thanks again.
« Reply #18 on: October 02, 2015, 12:36:26 pm »
Ok Mani - Don't hesitate to ask me to try something if you feel suspicious about "it". I have the unit here up to Sunday.
