November 23, 2024, 01:58:17 am *
Author Topic: Unattended Issue  (Read 5823 times)
« on: September 20, 2015, 03:57:04 pm »
Recently I noticed that sometimes the on screen top left hand lettering for XXHighend and the current version being used changes from red to white. Of course this lettering should be red indicating proper activation. Does this indicate a problem? Not sure if its just in my head, but when that lettering is red it does seem to sound better, but that might just be imagination playing tricks.
This changing between red and white happens totally randomly; I usually turn the pc off when not in use and the lettering changes after restarting. It has been months since I last reverted to normal OS state.
« Reply #1 on: September 20, 2015, 05:05:35 pm »
The only thing I really can imagine is that the XXHighEnd screen is not the active screen when you see the letters in white.
So just try it - e.g. open an explorer instance alongside of XXHighEnd and click on that Explorer instance. That is the active program now and the XXHighEnd letters will be white ...
Can that be it ?
« Reply #2 on: September 21, 2015, 01:35:48 pm »
When I opened XX via the the explorer button, while my ram disc version with white letters was also open,  the letters were still white. I then changed to normal OS, re-activated, went back to minimized and now all seems fine. Not sure what the problem was.
