Robert
« Reply #75 on: September 25, 2015, 08:49:46 am » |
Oh my god you are chasing a dream.
Gosh sounds like you are trying to turn back time!!!!
Peter you need St Peter's OS!!!!!
Unless you can unravel Microsoft's Da Vinci Code!!!!
Robert not the saint
« Reply #76 on: September 25, 2015, 09:59:22 am » |
Hahaha
Maybe you are right. But "dream" = "nightmare". At least for some, it is.
« Reply #77 on: September 25, 2015, 12:18:01 pm » |
I have a most interesting addition :
I am shutting off (down) all to bring it to this weekend's show; For that I need to mount the "base file" for the Windows 10 RAM bootable OS version. This goes automatically with the Shut Down (by XXHighEnd) but it did not want to work this time. And just prior to this I set back the earlier today mentioned date of Sept. 3 to Sept. 1 ...
But I now recall that I did similar the last time, and that then too the "base file" would not mount. And after that it did not want to boot any more ...
And so I set back the date to Sept. 3 et voilá, it mounted again. Whether it still boots ? I guess so, but we will see that on the Show ... hum
« Reply #78 on: September 25, 2015, 02:41:44 pm » |
I certainly wish you the best Peter ! Hope that time travelling will not make you another "Dr Who" and all the adventures that surround him I will be in spirit with you all there  But don't talk in my back ok ? ha ha ! I will be happy to read the report you will make about it, but in the meantime, keep smiling even if things do not always turn like we hope and expect  Life is short ! Kind regards, Alain
michaeljeger
Headphone Maniac
« Reply #79 on: September 26, 2015, 09:10:57 am » |
So I set back the date 3 months. Works fine  Please note that if you set back the date one year, the system will not boot any more and will go into recovery mode. Quite strange. Anyway, very happy with the SQ, now even in minimized OS. Great stuff!!! Michael
Custom Built XXHighend PC with Xeon processors and not fans -> XXHighend Player 2.02 with Win 10 10074 -> Claxius USB Cable -> Phasure NOS1a -> Blaxius Cable -> Violectric V281 Headphone Amp -> Abyss AB-1266 (best headphone in the world)
coliny
« Reply #80 on: September 26, 2015, 09:48:30 am » |
Here's something to try if you can't get W10074 to boot with date set back. I can't test it because my pc's all boot happily in 2013. wdf01000.sys is involved with verifying hardware drivers. We have different hardware so probably different different drivers installed. One or more of these is probably failing the verification process during boot because the date is set and confusing the process. Something similar happens when I try to use a browser with date set to 2013, I get message "there is problem with website security certificate - it has expired or is not yet valid". Time travel is rather confusing isn't it" So you could try this solution to disable the Verification process, its Option 2 :- http://www.sevenforums.com/tutorials/101379-driver-verifier-enable-disable.htmlGood luck Colin
« Reply #81 on: September 28, 2015, 09:49:27 am » |
Hi Colin, I just read through that and I don't think there is anything to shut off. To me it looks like that this is to activate when wanted (check your drivers for good operation) and when all is fine, shut it off again (or otherwise huge overhead ?). If you read through the posts it also looks like that this is nothing to play with for fun, because I see people report that their systems won't boot any more. I think this is not what we want to accomplish. haha But thanks, because the idea looks good. At least it brings me to the idea of the certificates and the checking against those. And indeed, when a certificate expires, you can't use the driver. And if it is not officially active yet (you can run into that with set-back dates) - the same I suppose. Now I am not sure how this is / can be related to the Driver Signing we (as Phasure NOS1a users) disable (is a formal option in XXHighEnd). And just saying ... in my base W10 version (the one which is used to boot from RAM) I never shut off that Driver Signing (checking) - at least that is what I think (my W10 RAM version existed earlier than the Driver Signing option in XXHighEnd ?). Maybe never mind (my paragraph above), because I too get confused somewhat.  Peter
« Reply #82 on: September 30, 2015, 10:05:26 am » |
Hi all,
This morning appeared for the first time the message in the picture when I turned on the Audio Pc. It seems that the real problem starts from now on, at least for me. I hope I´m wrong as I don´t have time rigth now to look for some solution but I restarted the pc several times and the message appeared again. Never before it appeared when turned the Audio Pc on.
Traslation (aprox):
Recovery
Expired one component of the operating system.
File: Windows/system32/winload.exe Error Code: 0xc0000605
You must use the recovery tools. If you have not an installation media (such as a cd or a USB device), contact the computer administrator or the manufacturer of the computer or device.
Press enter to try again Press F8 to the startup configuration
Regards, Juan
« Reply #83 on: September 30, 2015, 10:26:02 am » |
Hi Juan,
And what is the date in your PC ?
« Reply #84 on: September 30, 2015, 10:38:38 am » |
Hi Juan,
Peter, I can't see it with that window but yesterday it was September 2012 Juan
« Reply #85 on: September 30, 2015, 11:16:25 am » |
Hmm ... Maybe you can observe the date in the BIOS ?
So actually you can't do anything now any more ?
« Reply #86 on: September 30, 2015, 11:29:49 am » |
Hi Peter, I wasn't at home and couldn't see the bios. The date there was 2019 and why has been changed there I don't know. Now changing it again to 2012 the problem is solved. Sorry for the alarm, now I cross the fingers for tomorrow as it seems to be the end date.
Regards, Juan
« Reply #87 on: September 30, 2015, 11:42:41 am » |
Hey Juan,
No ... no worries. we (can) all run into such problems and it is only good that "we" have the experience. Sharing this is nothing much about false alarms, as long as it is useful to know.
Btw, tomorrow (Oct. 1) is not the date that all stops; instead messages will appear and reboots will take place regularly (no, not nice for playing music). At Oct. 15 the system won't boot any more. At least that is what is claimed.
Regards, Peter
« Reply #88 on: September 30, 2015, 12:05:02 pm » |
Thanks Peter
Robert
« Reply #89 on: October 05, 2015, 11:40:26 pm » |
Well I have just reset the date using right hand desktop icon back to 1.9.15 and no problems with playback etc. At this point I have no warning messages.
I did this in min OS.
Robert
