« Reply #60 on: September 20, 2015, 11:40:26 pm » |
Ok, sorry Joachim. I was using my phone to send the pictures. Let me do it as you say and I´ll post it here.
Thank you Juan. No hurry, we have all the time. Joachim
« Reply #61 on: September 20, 2015, 11:41:34 pm » |
Joachim, there are 26 processes running in MinOS
« Reply #62 on: September 21, 2015, 12:03:30 am » |
thank you Juan. That's a pretty good result, in other words, Peter made a damn good job. The program I'm using (to minimize the OS) with build 10240 is leaving 36 processes running during replay in attended mode. Thanx again Joachim
« Reply #63 on: September 21, 2015, 10:08:53 pm » |
More processes probably shut down when you press play.
« Reply #64 on: September 21, 2015, 10:13:19 pm » |
It was playing at that moment but with Unattended off Juan
michaeljeger
Headphone Maniac
« Reply #65 on: September 23, 2015, 08:57:25 pm » |
Hi all Not sure I understand what to do now. Basically one week to go with that built.  Set back the clock, or will we get something from Peter in time? Regards, Michael
Custom Built XXHighend PC with Xeon processors and not fans -> XXHighend Player 2.02 with Win 10 10074 -> Claxius USB Cable -> Phasure NOS1a -> Blaxius Cable -> Violectric V281 Headphone Amp -> Abyss AB-1266 (best headphone in the world)
« Reply #66 on: September 23, 2015, 11:40:56 pm » |
Hi Michael,
If I recall correctly, Peter will make a version that will function with the "official" Windows 10 version, but if someone would like to keep with Windows 10 build 10074 because he is comfortable with that, he can put the date backward.
Juan was able to do so through BIOS, while his system was in Minimized OS. Going back to Normal OS indicates that the date is kept equal to the BIOS date.
For someone who would do the same but with the Normal OS state, it may work through BIOS also, but for me it did not. I had to exectute the "Date" command to overcome the OS tendency of bringing back the actual date each time.
If you wish to keep the actual build (10074), you can either try through BIOS or the "date" command from the Windows DOS command line.
Robert
« Reply #67 on: September 24, 2015, 12:48:52 am » |
You must all accept the fact that W10074 will be improved upon soundwise anyway. Nothing stays the same especially in the digital world.
I wouldn't be worrying too much about extending dates, even if Peter's new version is not quite as good as W10074 it will be improved by further innovation.
We will of course always be limited by Microsoft using Windows!!!!
Robert
« Reply #68 on: September 24, 2015, 07:46:54 am » |
Robert
Hi, did anyone has the time to compare 10074 with 10240? Joachim
« Reply #69 on: September 24, 2015, 08:00:17 am » |
II agree totally, probably a majority of us are agree with it. I wonder if Peter has decided to stay forever with Windows or, on the contrary, there is some hope to afford this issue using other OS, including the possibility to build a specific OS for XXHighEnd. Regards, Juan
« Reply #70 on: September 24, 2015, 08:14:34 am » |
All,
At this moment I refuse to do anything with 10240 because it is worse than 10074. And any not-official (of the so called "fast ring") build will expire again. So we are waiting for a next "slow ring" build.
If you don't like to set back the date (which seems to work as how things are now), then better go back to Windows 8. Or find another hobby. haha
Best regards, Peter
« Reply #71 on: September 24, 2015, 09:48:01 pm » |
Hi Peter, Today I want to set back the date by one year. First thing I did was to set back the date in the bios. After saving the bios settings, no Windows 10 but I had a blue screen with a message: "PC/Device needs to be repaired. OS couldn't be loaded because a critical driver is missing or contains errors. File:\Windows\system32\drivers\wdf01000.sys You'll need use recover tools......" I could not solve this problem. After setting the date back in the bios all was working again. Next attempt was to change the date in normal os in command promt mode via date command. After setting the date one year back I did a reboot. Guess what, the same error as before. No Windows but a blue screen. Now what? after some reboots back in the bios. I saw that the date was set back automatically in the bios by one year. I changed the date back to today and did a reboot again and all was working again. So one week to go before expiration. What is the procedure to solve this problem? PS. http://www.file.net/process/wdf01000.sys.htmlBest regards, Johan
Jud
« Reply #72 on: September 24, 2015, 11:00:39 pm » |
All,
Best regards, Peter
Though I am pining away hoping for a better "permanent" build, I did have to laugh at this.
Win 7 64-bit; i7-950@3.07GHz; 16GB RAM; OS on SATA 6GB/s SSD; AIFF files on external FW HDD; XXHE and Playback Drive on separate RAMdisks; no page file; Audioquest Dragonfly DAC/preamp; PSE Studio IV amp; Pioneer SP-BS22-LR bookshelf speakers or Etymotic Research ER-4P in-ear monitors. XXHE 0.9z-8-3a settings for the moment: Peak Extend; Arc Prediction; Redbook files upsampled 2x; KS Adaptive Mode; Phase Alignment off; buffer=512; Straight Contiguous; Playerprio=Low; ThreadPrio=RealTime; Unattended; OS minimized; all services off; Q1=17, factor=2; SFS=2.1; XXTweaks=Ultimate; Time Performance Index=Not the best.
« Reply #73 on: September 25, 2015, 12:53:10 am » |
Hi Peter, Today I want to set back the date by one year. First thing I did was to set back the date in the bios. After saving the bios settings, no Windows 10 but I had a blue screen with a message: "PC/Device needs to be repaired. OS couldn't be loaded because a critical driver is missing or contains errors. File:\Windows\system32\drivers\wdf01000.sys You'll need use recover tools......" I could not solve this problem. After setting the date back in the bios all was working again. Next attempt was to change the date in normal os in command promt mode via date command. After setting the date one year back I did a reboot. Guess what, the same error as before. No Windows but a blue screen. Now what? after some reboots back in the bios. I saw that the date was set back automatically in the bios by one year. I changed the date back to today and did a reboot again and all was working again. So one week to go before expiration. What is the procedure to solve this problem? PS. http://www.file.net/process/wdf01000.sys.htmlBest regards, Johan Hi Johan, Is it possible for you to go back maybe a few months from now ? Something like July, yet still in 2015 ? Maybe trying things with smaller steps will work ? Not that I have tried it, since I was in Normal OS and it worked with the date instruction... It seems to be very variable, but I can't determine a common denominator... Regards, Alain
« Reply #74 on: September 25, 2015, 07:32:56 am » |
Hi Johan,
At least you got the very same message as I received when I tried to set mine back with 2 years (this was 2 months or so ago). Thank you for that detailed description.
I started to set back my date at Sept. 14 to Sept. 1 and I try to keep it at that (but e.g. yesterday I forgot so at this moment it will be at Sept. 3).
I did it in MinOS Mode at first with the Date command and later with PowerShell, which was just in order to find something general for you all which could be build in. Btw I failed on that because it was too difficult for the time I gave it to find an automatic means of the proper format (various formats exist for various countries). I gave up on that and decided to just change the date by normal means - with mouse in the bottom right corner. I now apply this every day (if I don't forget).
A few days ago I tested all kind of reboots, because my system is more complicated, booting from RAM. Anyway, I always looked at the BIOS date meanwhile, and it always sticked. Side note : when I set back my date with two years, I did this in the RAM version, and the RAM version did not want to boot any more with the same error you described. Go figure. The normal base version (for it) booted (I only tried this a week later) and the date was back to "today". After that the RAM version (which copies from the base version) booted again as well.
Summarized ... all I did not test (I forgot it) was going to Normal OS ...
It should just work, but as was told by others ... maybe only go back a little ?
Additional problem by now could be that in your case it will already have entered the "state of expiration" that might have registered special data in the registry etc. The effect of that (if so at all) I don't know ... Similar will be when it doesn't boot any more (Oct. 15 ?) ... then I suppose it really never will because of a set "flag" somewhere.
