« Reply #45 on: September 20, 2015, 02:47:36 pm » |
I just read the link you provide. I am unsure about the privacy and what lies behind MS "showed intentions" for the moment. That is why I prefer to wait for a time and see what others will say about standard Windows 10 before jumping into it for good with my music PC and my all purpose PC... Even it I decide to go with it, I still have backups of my previous Windows versions (Windows 7 and Windows  - just in case. Alain
« Reply #46 on: September 20, 2015, 02:55:35 pm » |
Then, the real problem it´s not only to make the final W10 to sound as good as the v10074, the problem also will be if we can or can not to stop the automatic OS updates. If we can´t stop the updates we´ll have a permanent instability for what is important to us: the XXHE sound quality.
Hi Juan, within the W10 pro (build 10240) you can stop/avoid any update. (for an audio PC not connected to the internet) Joachim Hi Joachim, You are right  As long as we stay away from internet with our music PC, we should be protected from these automatic updates Regards, Alain
« Reply #47 on: September 20, 2015, 03:33:51 pm » |
Hi Juan, within the W10 pro (build 10240) you can stop/avoid any update. (for an audio PC not connected to the internet) Joachim Joachim, then the problem would be "only" to make it sound as good as the v10074. I just read the link you provide. I am unsure about the privacy and what lies behind MS "showed intentions" for the moment. That is why I prefer to wait for a time and see what others will say about standard Windows 10 before jumping into it for good with my music PC and my all purpose PC... Even it I decide to go with it, I still have backups of my previous Windows versions (Windows 7 and Windows  - just in case. Alain Alain, I also have those W8 and W7 backups but the sound of the v10074 is so good... Hi Juan, From what I understand now, you changed the date in the BIOS and Windows was in Min OS when you booted after ? It could very well be that Windows is unable to verify the system date through that hypothetical file that I assume to exist. But like you say, we will know this when October 1st arrives  This may explain why the date change in BIOS worked for you Maybe if you go back in Normal OS mode, you will have your answer ? Then, going back to Min OS and then changing the date again in BIOS, all will work like the first time ? Even so, I would suggest to use the "date" command under the command line - that in Normal OS mode. This will ensure that the changing to the latest date will not occur. Normal OS would seem to be a stronger way, but I could be wrong of course... Regards, Alain Alain, where can I find how "to use the "date" command under the command line - that in Normal OS mode". I missed it. Regards, Juan
« Reply #48 on: September 20, 2015, 04:00:25 pm » |
Juan, On the task bar, you may see a "lens" to search. Click on it, then type this: cmd.exe A small window will appear. In that window, just type: date It will ask you to enter the desired date. You can close the window after. I will wait for your answer  Alain
« Reply #49 on: September 20, 2015, 04:03:37 pm » |
Just an additional note... You may see a message telling that it can't help you in your region, but at the right left of that window, there is another "lens" to search. Click on it. Then you will be able to type "cmd.exe"...
« Reply #50 on: September 20, 2015, 04:11:10 pm » |
Alain, I have to do it in Normal mode, right?
« Reply #51 on: September 20, 2015, 04:36:24 pm » |
Hi Juan, All I can say is that I don't know, but since we will always pass some time in Normal OS, with all the processes that are normally workng, it would be better to do it in Normal OS Alain
« Reply #52 on: September 20, 2015, 04:45:02 pm » |
I will rephrase this...
If I do something in Normal OS, it should hold when I will go in Min OS.
But if I do something in Min OS, there are chances that some of what I did will be reverted once I go back in Normal OS.
Not sure it this makes sense, but...
« Reply #53 on: September 20, 2015, 05:13:38 pm » |
Thank you Alain  Juan
« Reply #54 on: September 20, 2015, 05:17:17 pm » |
Alain,
I would say that all what can be reverted in Normal OS is the saved states from when you boot from Normal into Minimized. But this is XXHighEnd causing this. So for example, when your Network Connection is On in Normal OS and you tell to shut it off for MinOS, then the state for Normal OS is On and that will be saved; when booting back into Normal OS later, that state is re"set".
All other things you run into can not be related to MinOS itself. Yes, this too sounds vague, but it is easier to think that all what's reset is reset because I tell it to. So no mysteries there; it is only that you don't know what that all is. But example again : if you would be able to set the color of Explorer in the Registry, and you do/change that in MinOS, then at going back to Normal OS that color will NOT be set back to how it originally was. This is because I (XXHighEnd) does not Save the Registry settings (and/or Restore those at going back to Normal OS). If you think "the state of the running services" only, then you will be thinking quite well in the reality of matters. Nog 100% but the exceptions will be rare.
« Reply #55 on: September 20, 2015, 07:30:02 pm » |
Hi Juan, within the W10 pro (build 10240) you can stop/avoid any update. (for an audio PC not connected to the internet) Joachim Hi Joachim, You are right  As long as we stay away from internet with our music PC, we should be protected from these automatic updates Regards, Alain Hi Alain, we can stop the updates of W10 when connected to the internet too.  (but that's not wise due to possible malware etc.) Joachim
« Reply #56 on: September 20, 2015, 07:33:31 pm » |
Answer to Reply#47 by Juan
Hi Juan,
i can't compare the two builds.
One question: how many processes remains in build 10074 in minOS? (to be checked via the Task Manager) Thanx
« Reply #57 on: September 20, 2015, 10:33:50 pm » |
J Answer to Reply#47 by Juan
Hi Juan,
Joachim, in min OS and with Unattended there is no process on. With the XXHE Gui only XXHighEnd appears. Juan
« Reply #58 on: September 20, 2015, 11:04:52 pm » |
Hi Juan,
thank you. By opening the task manager with STRG+Alt+Delete you will see this screen, and under performance we see the amount of processes just running.
« Reply #59 on: September 20, 2015, 11:11:21 pm » |
Ok, sorry Joachim. I was using my phone to send the pictures. Let me do it as you say and I´ll post it here.
