April 06, 2025, 08:31:49 pm *
Pages: 1 [2] 3 4 5 6 7  All
Author Topic: Windows 10 build 10074 expiration  (Read 93554 times)
« Reply #15 on: September 11, 2015, 09:17:15 am »
Haha, of course I will try, but I can't tell yet. Maybe it takes a few rounds. Problem of course is : that 10074 is just too good (in comparison to all what was out prior to that). But for example : W8.1 was such a drag SQ wise, that I never even started working on that (and announced to better wait for the next version - which is what I did, or ? Happy).
So ... working on it.
Michel
« Reply #16 on: September 18, 2015, 05:29:50 pm »
O Dear... S.O.S. !
I know you working on it..But damn this su...!
I know you can make w10 Unattended..
But thats a hell of a job. Never done it tho..
Regards, Michel
« Reply #17 on: September 18, 2015, 06:05:51 pm »
Michel,
Yes, as expected (for one of these days).
My PC was set to Sept. 1 and I try to keep it at that (didn't do it today, so now it says Sept. 2). But no such screen here yet ...
Michel
« Reply #18 on: September 19, 2015, 12:36:39 am »
So that's the trick Happy For how long?. Do not read anything about it or maybe I read over it.
Thx for the tip.
The problem now is that Windows10 10074 is no longer working properly. This is because I installed software to remove the watermark.However, it has caused more damage .. So I can not go into min operating system anymore. And the player will see the windows as windows xp or lower. With all its consequences.
The sound that I had is completely gone. It sounds okay, but it's not what it was.
Oh yeah , and a restore point , I never made .. :-( my stupid!
I suspect that a clean install is the only option ?
Michel
« Last Edit: September 19, 2015, 11:50:21 am by Michel » Logged
coliny
« Reply #19 on: September 19, 2015, 08:21:40 am »
Michael
Your problem is probably that windows service - "Windows Management Instrumentation" is not running. This can happen when Windows does not shut down properly.
Via control panel - admin tools - services, double click "Windows Management Instrumentation" select start "Automatic" then click Apply then click Start Service. Start XXHE now it should be OK but you may need to set memory type back to "Straight Contiguous".
I have my system clock set back exactly 2 years, this should allow W10074 to keep running 2 more years.
Colin
« Reply #20 on: September 19, 2015, 10:54:08 am »
Are you sure? Did you reboot after changing the date? I did and it did not work anymore... but changing the time in BIOS cured it again.
Better set it back a few months and make a batch-file to reset the date after you reboot.
« Reply #21 on: September 19, 2015, 11:46:35 am »
I think Bert is right. 2 years back, for me gave the same problem.
To me it looks like we shouldn't attempt to run the OS prior to its birth date. Happy
Michel
« Reply #22 on: September 19, 2015, 11:52:43 am »
Colin ,
Thx for the help , but it din't work..
And i also try to go back in time :-).
System din't boot..
Michel
« Reply #23 on: September 19, 2015, 11:57:11 am »
Hi Michel,
Colin is right, but possibly you can't get it done or it does not help. Also (now start crying) : I suspect that exactly that Winmgmt service has been eliminated by that piece of software you installed, because it would be typical for that service to check for the (watermark) data you had removed by that software.
Please notice that in your XX folder there are files like OSIsW8.tss, which when renamed to .tst let your system behave like it is implied by the file name. BUT, for W10 I did not make that yet for the XXHighEnd version you all use (it's there in 2.03 - not ready yet).
In your case you can try the OSIsW81 (for Windows 8.1) which will resemble W10 the best. But I think it won't work all the way ... You'd have to try it.
« Reply #24 on: September 19, 2015, 12:01:56 pm »
I set also the date from two years back in the  bios and so far no problem at all,  even if I reboot or shut down the pc. Perhaps it is due that I always do it from XXHighEnd (right click on the stop button)
Michel
« Reply #25 on: September 19, 2015, 12:44:51 pm »
I've tried it(OSIsW81 ), but no luck for me today.
Thx for the fast respons.
Michel
« Reply #26 on: September 19, 2015, 12:52:44 pm »
But what happens ?
The empty Playlist Area should now show Windows 8.1.
Does it ?
If not, I'd say your rename didn't work out as intended. Thus, has to be :
OSIsW81.tst
And only one at the time may be in there with .tst as extension.
coliny
« Reply #27 on: September 19, 2015, 01:55:43 pm »
W10074 has been working fine for a couple of months now with date set back 2 years. Also its set not to sync with internet time although I have not connected it to internet. It survived going in and out of min OS as well. My pc is dual boot with W7 so that also picks up the date as 2013, even so W7 updated itself OK.
Just tried on another pc with w10074 but with current date set, it booted with the expiry message. I set date back 2 years, rebooted & works fine.
On these pc's w10074 has not been activated, perhaps setting date back does not worked if w10074 has been activated.
Maybe a fresh install of w10074 with system date already set back will work.
Colin
« Reply #28 on: September 19, 2015, 03:02:33 pm »
Perhaps it will work (new install W10) if you set the date of the PC a few months back before installing the OS?
It should not get any data from the internet anyhow for a minimalistic not updated OS...
« Reply #29 on: September 19, 2015, 03:34:04 pm »
My PC is not activated (it doesn't accept any of the Keys I could find).
Page created in 0.038 seconds with 16 queries.
