April 05, 2025, 04:18:33 am *
Author Topic: Balanced load settings  (Read 5136 times)
Robert
« on: August 25, 2015, 11:52:48 am »
Hi I've just moved Xxhighend from Min OS to normal and back to Min OS. I had the 1st setting at 63 now it will only work at 62 or 64? Is this a problem? Or what could cause this?
Sound quality does not appear to be any different. In reading your notes on these settings I wondered how relevant they may be now that you run no fans anyway as a dedicated server.
I have never played with these settings only followed yours.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #1 on: August 25, 2015, 12:00:19 pm »
Hey Robert,
I really have no idea what can cause this. I'm inclined to say "are your sure ?!". Happy
And oh, it may matter technically somewhat, but whether audible ? doubtful. I really wouldn't worry about it and for sure not about the heat (if you go to the extremes (both ends) then it will matter).
