April 05, 2025, 01:37:35 am *
Pages: 1 2 [3]  All
Author Topic: W10 - SQ  (Read 50224 times)
« Reply #30 on: August 07, 2015, 04:48:00 pm »
Hi Bert,
Your link leads to a strange Google page (well, here it does).
Of course, like you did it, it already works. I made it too difficult (thinking too much "program like").
« Reply #31 on: August 07, 2015, 06:16:22 pm »
The expiry date of W10 Preview is told to be October 2015 (not September).
A windows 10 key will solve this expiration?
Johan
Hi Johan,
I suppose not, because the Preview 10074 is supposed to work with a key which can be activated. And many or most people do / have done that.
But not mine (key is not accepted).
« Reply #32 on: August 07, 2015, 07:23:33 pm »
As intended... just watch the animation explaining how to do a search through Google for the subject. I should be seen as a joke but not all get the clue.  unhappy
« Reply #33 on: August 08, 2015, 08:16:06 am »
haha
Ok.
« Reply #34 on: August 08, 2015, 06:20:12 pm »
after listening for several days to W10 (build 10240) my suggestion is, this OS is a MUST for all none build 10074 users.
The sound is amazing and made another jump forward after the "switch off" of the Cortana program with the renaming procedure. I never heard the live concert from Crosby, Stills, Nash & Young with such a SQ. Unbelievable very happy very happy very happy
http://www.amazon.de/Street-Crosby-Stills-Nash-Young/dp/B000002ITW/ref=sr_1_1?s=music&ie=UTF8&qid=1439050614&sr=1-1&keywords=crosby+stills+nash+%26+young+-++4+way
Robert
« Reply #35 on: October 20, 2015, 10:18:37 pm »
I thought I should reply re Peter's new settings for XXhighend 2.02 if anyone has noticed them yet(in his signature).
I tried them last evening in my setup and found them to be a nice improvement in sound, well worth trying out even though we are about to get an upgrade. Less metallic(bright) on top end notes at volume, but this is recording dependant.
W10074 with XXhighend 2.02 in Min OS with date early September 2015 is working flawlessly for me.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #36 on: October 21, 2015, 07:51:51 am »
Thank you Robert.
Jud
« Reply #37 on: November 10, 2015, 09:28:01 pm »
As I think you remember, I'm on the "fast track" for Windows 10 updates.  Do you know if I would just be wasting my time trying to install XXHE on the latest update to see how it might sound (in other words, it would definitely not even work)?  Or it is possible that it will work, but I am doing this at my own risk (of Win 10 being screwed up or potentially horrible SQ  prankster )?
Robert
« Reply #38 on: November 10, 2015, 10:13:42 pm »
Jud may I suggest you try all things at your own risk. You can always reload it all again. Personally I wouldn't try it Peter is working on a newer version. OS updates have never been part of the plan.
I have changed my SFS to 1/60. I found HDCD files in albums would only play two tracks before stopping.
Robert
Oppo 205 UDP Dac
« Reply #39 on: November 10, 2015, 11:13:55 pm »
Hi Jud,
since 3 month XXH is running under W10 build 10240 here, and the SQ is amazing, more details, and much more timbre of all sound sources. (feet tapping sound)
XXH 2.02-MinOS is not working with build 10240, so I'm using  an other "minimizing OS program" until the next W10 build/XXH 2.03 version.
« Reply #40 on: November 11, 2015, 08:11:57 am »
Hi there Jud,
When you have been served with some "speed" you may have noticed that 10586 was handed out to the Slow Ring on November 9th. 10586 will 100% most definitely be the next ISO to download.
Do notice that using the 10586 from the upgrade over upgrade situation - and how it should be available to you at this very moment - is BAD (think "bloated" which is not good for us audio guys).
Also -and this is merely for others-, watch out with downloading any "self created" ISO of 10586 which already floats about since 5-6 days. This too is from upgrade builds (in this case from the fast ring where it (obviously) also has been provided).
N.b.: I too did not download the currently available 10586 yet (but have 10565 fully running).
I will provide a link to the official MS-created 10586 ISO when it is available. This really is "today or tomorrow".
Regarding XXHighEnd - don't. I am writing the Release Notes to 2.03 at this very moment. This should be a "today" thing when nothing else comes in between. 2.03 will allow to boot any W10 Build into MinOS without losing the OS (which will happen with 2.02).
Regards and thank you for your help,
« Reply #41 on: November 11, 2015, 08:35:31 am »
 good good good Happy Happy Happy
« Reply #42 on: November 11, 2015, 05:34:27 pm »
Well, what came in between was that topic about the OS disk I also needed to finish.
Pages: 1 2 [3]  All
