November 23, 2024, 01:50:14 am *
Pages: 1 [2] 3  All
Author Topic: W10 - SQ  (Read 49495 times)
Robert
« Reply #15 on: August 04, 2015, 10:58:30 pm »
One would expect Peter is comparing versions. I will once I get another SSD loaded with the current version.
I have a question if I run a second OS drive is it possible for W10 ver 10074 os to upgrade while I'm running in the latest OS W10 ver?
If I leave XXhighend in Min OS with V10074 this should negate any updates on this drive. Is what I'm hoping.
I do have a problem with the expiry date for 10074 but will do what is required to maintain SQ. It also concerns me stopping updates is a major if at all possible.
I guess time will sort these issues.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #16 on: August 05, 2015, 12:49:50 am »
Hi Robert,
with the installation of W10 build 10240 on a separate HDD/SSD (SSD with 120GB= < €100)  you will have a "dual boot system" and both OS are running independent from each other (you have to decide with the bootmanager that whether you want to work with build 10074 or build 10240). So, nothing changes your present settings in 10074 disconnected from the internet.
« Last Edit: August 05, 2015, 01:14:39 pm by christoffe » Logged
Robert
« Reply #17 on: August 05, 2015, 07:23:17 am »
Thanks good news.
Robert
Oppo 205 UDP Dac
« Reply #18 on: August 05, 2015, 05:52:46 pm »
by disabling the programs "OnDrive" and "Cortana" with the "Group Policy Editor" the SQ improved again.
P.S. Peter, did you install the W10 RTM meanwhile for a listening test?
« Reply #19 on: August 06, 2015, 05:48:37 am »
Joachim,
I did not install any W10 RTM at all. It is OF NO USE.
I gave you the link to that forum.
Did you try to follow it ? (what people all come up with)
Sorry !
« Reply #20 on: August 06, 2015, 01:09:04 pm »
It is OF NO USE.
UUH, don’t give up – the W10 (10240) SQ on my system is superior to W8.
Most sound problems with W10 are coming up in conjunction with the “Cortana” program, and that program we have to disable. There are some sites in the internet with proposals such as:
http://superuser.com/questions/949569/can-i-completely-disable-cortana-on-windows-10
(This is not working)
W10 on the AUDIO PC is stable since 5 days and I installed XXH 2.02, the NOS1 USB driver, an Intel video driver (for the embedded “video card” on the processor)  via the W10, the PRIMO ram disc, the Phasure OCX file and Firefox browser only. Deleted have been the “NVIDIA” (video driver) and “Realtec” (audio driver) programs.
The audio PC is not connected to the internet and no updates are implemented, and a lot of services are disabled (maybe not all) which we don’t need.
Peters Q1 to Q5 settings are not working with 8Gb RAM systems, it seems. I tested  Q1=14 /0/0/0 in the beginning, but the highs are a little bit too harsh.
Now I have Q1=6 and  /1/2/1/ and the SQ is smoother.
My conclusion:  W10 is running quite well on AUDIO PC’s (with audio related programs only)  with a great SQ.
P.S. Somebody simulated (via the BIOS) the behavior of build 10074 with the “expiry date” on September ?
« Reply #21 on: August 06, 2015, 01:20:26 pm »
Hi Joachim,
I don't know what you want exactly, but ...
A totally destructive 10240 build is the same to me as a simillar build of 10074. Both are as unusable for normal practice work.
And now you want me for fun to sit down for XX days to have 10240 going ?
FOR FUN ... do you receive ?
Can you explain to me what the reason is that you are using the RTM (10240) ?
Lastly, do you realize that you are removing programs one by one etc. etc. to improve SQ, which all has already been done (by me so to speak) for 10074 ?
But use MinOS.
So seriously, I am lost somewhat on what you are attempting, and why. But of course you are going to tell me ... Happy
« Reply #22 on: August 06, 2015, 02:07:01 pm »
Hi Joachim,
A totally destructive 10240 build is the same to me as a simillar build of 10074. Both are as unusable for normal practice work. correct
Can you explain to me what the reason is that you are using the RTM (10240) ? The installation of 10074 failed two times, but the 10240 installation was a piece of cake
But use MinOS. MinOS failed in W10 and I had a black screen and reinstall W10; now I would delete the NVIDIA program prior to MinOS
see my reply in red letters above.
The other concern with build 10074 is, what will happen after the expiry date in September. Did someone simulate this, or is there a solution .......... ?
« Reply #23 on: August 06, 2015, 02:14:56 pm »
Hi Joachim - not sure :
I did not read about you NOW being able to go to MinOS.
(it seems you don't dare to do it, which of course is fine)
If I am correct - still no difference with 10074. Unless :
You mean completely ? nea ... then I missed that.
After going into MinOS, yes (black screen for you). But my memory ...
The expiry date of W10 Preview is told to be October 2015 (not September). And I set back my date to 2012 (and told about that).
I can't guarantee a thing though.
What I do seem to read is that people - especially with laptops- find their laptops "bricked" (wich means : completely dead) and have to bring it to the electronics repair shop. Again, follow that forum.
I am not going to co-operate with that.
(read : encourage for it)
« Reply #24 on: August 07, 2015, 12:43:54 pm »
Hey Peter,
Did you try to reboot with the new date set to 2012?
« Reply #25 on: August 07, 2015, 12:55:02 pm »
Yes Bert.
It did not work any more.
You ?
haha
(but there's some more to tell about this)
« Reply #26 on: August 07, 2015, 02:54:22 pm »
Same here indeed.. have to try to see how far back we can go and if not then re-time every 3 months or so...
Just thinking, which DOS command changes the date? I could implement this within the batch-file I use to load XX into RAM. Or you could implement this in XX (at startup) or...
I am sure there is. ;-)
« Reply #27 on: August 07, 2015, 03:02:47 pm »
A windows 10 key will solve this expiration?
Johan
« Reply #28 on: August 07, 2015, 03:19:28 pm »
Bert, that would be the Date command.
It is a very long time ago, but something like
DATE<[the date]
would feed [the date] into the command.
« Reply #29 on: August 07, 2015, 03:29:58 pm »
Already found it... ;-)
lmgtfy.com/?q=set+date+batch+file#
DATE 07-07-2015
Pages: 1 [2] 3  All
