« on: August 01, 2015, 10:12:01 am » |
Hi, the shortest way to install W10 is to use an ISO CD, no updates to W8.1 are necessary prior. For the activation of XXH we have to install another browers, because EDGE is not working with a low "User Account" setting. The SQ, first impressions, more details, more bass. The soundstage with the laptop is as I'm sitting very near (5m) to the performers. (with the office PC the distance is 25m away with a "wall of sound"  impression, which sounds very nice) ***There is no "WOW" effect as the others wrote about the SQ with the build 10074*** For a test I'm playing the Beady Belle song "Intermission Music", where she sings together with Jamie Cullum. It is very difficult to locate the position of the singers, until now they stood very near together and with W10 they are more seperated. http://www.amazon.co.uk/Belvedere-Beady-Belle/dp/B0012K5PX4/ref=sr_1_3?s=music&ie=UTF8&qid=1438416155&sr=1-3&keywords=beady+belleMore to come. Joachim P.S. Note to Peter: XXH is activated (with the red letters)
« Reply #1 on: August 01, 2015, 04:59:33 pm » |
attention, a "Minimized Mode" is not possible, we will see a black screen, and I had to reinstall W10.
« Reply #2 on: August 01, 2015, 05:39:18 pm » |
What ?! Well, I guess that sort of halfly could be expected. Sorry for that anyway !
But you did try with XXHighEnd 2.02 I assume ?
Regards, Peter
« Reply #3 on: August 01, 2015, 05:42:22 pm » |
For the activation of XXH we have to install another browers, because EDGE is not working with a low "User Account" setting. Joachim, As far I know, Internet Explorer is just in there as well. In System32 somewhere. I forgot at this time, but I wrote about it and how to take over the associations from Edge or whatever it is and was (10074) named. Peter
« Reply #4 on: August 01, 2015, 06:00:52 pm » |
 Do I need after the restore of the W10 installation a new activation code? It seems yes. Joachim
« Reply #5 on: August 01, 2015, 06:13:13 pm » |
Hi Joachim - Yes.
« Reply #6 on: August 01, 2015, 06:58:03 pm » |
No problem, these are important things and so I can avoid orders from my wife for some household works.  Joachim
« Reply #7 on: August 02, 2015, 11:25:52 am » |
Hi, the SQ under W10 (not minimzed) is superior to the W8 SQ due to the improved fine resolution, more details and improved timbre. The timbre of the brass instruments is amazing. https://www.highresaudio.com/artist.php?abid=104230W10 is worth a try when it is stable. Since the reinstall of W10/XXH 2.02 (on the laptop) all is running normal with XXH on a RAMdisc (with all W10 services in action) W10 is running in the "flight modus" to avoid unwanted updates. Joachim P.S. Info to Peter, when I tried to minimize the W10 a note came up, that a creation of a restore point is not possible due to ..... (I forgot the reason) yesterday, and I proceeded with the minimizing and ended up with a black screen showing the mouse pointer only.
« Reply #8 on: August 02, 2015, 12:34:22 pm » |
P.S. Info to Peter, when I tried to minimize the W10 a note came up, that a creation of a restore point is not possible due to ..... (I forgot the reason) yesterday, and I proceeded with the minimizing and ended up with a black screen showing the mouse pointer only. Joachim - strange. And I can't test it either - no RTM Windows 10 here ... Regards and thank you for the efforts and feed back, Peter
coliny
« Reply #9 on: August 02, 2015, 02:26:37 pm » |
« Reply #10 on: August 02, 2015, 03:06:45 pm » |
Thanks Colin, read your remark at that time but didn't get the "curve" for my case.  Joachim
« Reply #11 on: August 04, 2015, 03:25:38 am » |
Hi, the performance of W10 (build 10240) on the audio PC is very robust without any “hiccups” for three days until now. On this PC the only external programs are XXH 2.02 and the Primo ramdisc. I had to shut down some drivers in the device manager. (a driver for the NOS1 and the NVIDIA card) The PC is not connected to the internet. I did not risk to “minimize” the OS (due to the previous “happening” with a fresh W10 installation) and shut down some services manually as tested with Vista/W7 ( http://www.phasure.com/index.php?topic=548.0) and proposals mentioned with the link in the post "W10 tweaks". The SQ of W10 is superior to that from W8. (more bass, more details, more timbre, again a stronger right/left speaker orientation/seperation) As long as we are installing the audio/ram disc programs in W10 only, it runs very stable and we hear a great sound. W10 is now my preferred audio OS. Joachim ***I'm using W10 without "remote control, no tablet***
« Reply #12 on: August 04, 2015, 12:13:01 pm » |
Hi Joachim, thanks for your W10 test. I'm not sure if at any time you have tested also the 10074 version, if so, I would like know how you compare the two versions.
Best regards, Juan
« Reply #13 on: August 04, 2015, 12:18:27 pm » |
Best regards, Juan
Hi Juan, the installation of the build 10074 failed on my laptop, so I couldn't compare. Joachim
« Reply #14 on: August 04, 2015, 12:28:09 pm » |
Ok, thanks Joachim. Anyway, I´ll take into account your observations, we'll see if anyone can compare the two versions.
Regards, Juan
