toddn
« Reply #30 on: December 26, 2015, 02:50:18 pm » |
Understood Peter,
Makes sense to keep all the noisy PC related items together away from the NOS1a.
W10-10074 XX HighEnd 2.03 PC -> i7 3930K AS Rock MB W/ Dexa Neutron Star & linear PS supply mod. For Processor Clock, Hyperthreading On (12 cores) @430MHz (!), 16GB, Windows 10 Pro 64 bit Insider Preview build 10074 Samsun SSD, XXHE on 2GB RAMDisk (IMDisk), music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS W10 = .14(max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / W8 Scheme = Core 3-5, W10 Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive 2GB RAMDisk (IMDisk) / UnAttended (Just Start) / All Services Off / Keep LAN - *Not Persist* / WallPaper Off, W10 Running Time Off / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600* / -> USB3 (Silverstone W/Dexa Neutron Star Clock & Linear PS> *Clairixa USB* -> Uptone Regen w/ Dexa Neutron Star & linear PS -> 24/768 Phasure NOS1a 75B (BNC Out) async USB DAC, Driver v1.0.4b (*4ms*) -> Blaxius BNC interlink -> 8 channels of Hypex NCore 400's -> DYI BD Orphean Horns w/ qty-3 custom 15" open baffle bass drivers and qty-8 12" open baffle subwoofers per channel
Stanray
« Reply #31 on: December 26, 2015, 03:12:56 pm » |
If the Intona is to be placed close to the pc (Silverstone card) and weighs only 100g., then floating it between the Longer Clairixa on the DAC site and a short Cairixa on the pc site would be a solution in my case. The Intona would not be standing on a shelf then. A Clairixa of circa 15-20cm would be enough to make a 90 degrees bend.
Regards, Stanley
« Reply #32 on: December 26, 2015, 03:33:25 pm » |
Stanley, you are completely right. But somehow I don't feel good with such a solution. Look at my photo of it; I already put something under it. It is true though that I started telling about that 100 gramms because if "your reason". But I did not want to spell that out ... Maybe it is personal.
Regards, Peter
« Reply #33 on: December 26, 2015, 03:42:49 pm » |
When you mention "radiation", I suppose you mean that the Intona is not built to hold them since it is not isolated with a material that can contain it ? Hi Alain, Although I suppose it indeed is so that the "plastic" case is not really suitable for holdig the radiation inside, this was not on my mind at all. Btw, there can be a protective thin layer glued on the inside. But I think that just in general such radiation doesn't let catch itself anyway. You can guide it into a direction, but not stop it (also think like energy never getting lost (or created)). Regards, Peter
« Reply #34 on: December 26, 2015, 03:57:19 pm » |
A nice second Christmas day to you all.
Question: Did you test an “off the shelf” USB cable between the PC and Intona?
On CA (#22) suspicions are that in THIS connection the quality of the USB cable has less influence to the SQ than downstream to the DAC.
« Reply #35 on: December 26, 2015, 04:11:40 pm » |
Hi Joachim, No, I did not test that. But if you don't mind - and I said such things before - I only trust myself and sometimes you (haha). I mean, wasn't it so that half (or the whole) of CA likes the light-blue USB cable as "a best" one ? You know, that same cable I ditched in 10 seconds ? and quite some more of "us" ? It is just an example. Theories are there to be founded very well. Some times mine are or at least I try hard. The same counts for all of us, in here (at least that is my idea and the reason I listen to "you" just the same and why we listen to each other). That does not count at all for what happens on other forums ... Let me get this subject out of the way with this : If you read closely my first posts about the Intona (months ago) you have read that I had to undo a tweak and that it helped to let the Isolator work longer on the first day. With the same tweak in, it now doesn't want to work at all (Driver is not loaded into the NOS1a). The tweak is a cable. So that critical it is. Btw, you can just as well ask me to try all the other USB cables again on the output side, because someone on CA thinks (and he could be right) that it does not matter. Or it does, and now that other cable is better. Personally I have (much much) more to do when I am satisfied to begin with. So I leave those tests to you.  Best regards, Peter
« Reply #36 on: December 26, 2015, 04:30:37 pm » |
And Joachim ... I think this could be a better / more nice response from me : I honestly did not think about that, while I now imply another 100 euros of cost for you guys. Point is : this consideration really doesn't come to my mind because I just like to have it the best from all angles. Just look at this, which really happened over here : There comes my first Intona Isolator. Am I eager to try ? Yes, of course I am as I am no different from all of us. What would have been easier than taking the stock cable laying around, which is always used to test new DAC's right next to my own (I test with that cable because such a cable is provided with the NOS1(a)). But do you really think that even *that* came to my mind ? No. Instead I now saw what could be done (having the box in my hands) and "ordered" to make me that small piece which couldn't even happen that day because of someone being busy with other things first. All I want to say is : such a thing of using / trying a stock cable does not even come to my mind, no matter how logic it would seem to you. It wouldn't be the best, knowing that the Clairixa is the best (in normal circumstances). Why would I even think about wasting my time on something which maybe is not optimal for the situation. Please keep in mind my "required" 5 days ... And secret : What I am doing instead at this moment is testing 10586.0 again. So far it survived since yesterday ... And as I can't (or shouldn't) test two changes at the same time, I will continue with 10586.0 and not with USB cables. Still it would be correct that I could avoid the 100 euros for you (all). I could have done the same with buying and buying and buying stock cables until one sounds better and pass on a link to the $1 cable. But ...  Peter
tillen
« Reply #37 on: December 26, 2015, 09:54:42 pm » |
I need a 20 cm Clarixa to. Have a Nice Christmas.
Regards Arnt
PC- Asrock X79 Extreme 4-M - i7 4930K Hyperthreading On (12 cores) 32GB, Windows 10 Pro 64 bit build 10393.0 RAM-OS, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0.05 (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive / UnAttended / All Services Off / Keep LAN - Not Persist / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable/ Custom Filter Mid 705600 / -> USB3 from MB - Sw#3 off NOS1a = Up) -> Clarixa USB-> 24/768 Phasure NOS1a async USB DAC 75B, Driver v1.0.4 (4ms) -> Blaxius BNC interlink
Diede
« Reply #38 on: December 26, 2015, 11:19:05 pm » |
I'll take take 50 and 80 cm please.
Best regards, Diede
W8 and W10 - June 8, 2015 (2.02) XXHighEnd PC (own build) -> i7 4930K Hyperthreading On (12 cores), 16GB, Windows 8 Pro 64bit or *Windows 10 Pro 64 bit Insider Preview build 10074* on separate SSD’s, XXHE on 2GB RAMDisk (IMDisk), music on internal spinning disk & LAN (*always On*) / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4* (max 60) / not Invert / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core3-5 / Playback Drive 2GB RAMDisk (IMDisk) / UnAttended / All Services Off / Keep LAN - *Persist* / WallPaper *Off* / OSD *On* /Running Time *On* / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600 or High 705600* / -> USB3 (Silverstone non isolated) Sw#3 of NOS1a = down) -> *WireWorld Ultraviolet USB Cable 1m* -> 24/768 Phasure NOS1a async USB DAC, Driver v1.0.4b (*4ms*) -> own build NCore NC1200 amps (4 mono per channel), own build of Orelo MKI Open Baffle Horn Speakers
« Reply #39 on: December 27, 2015, 12:37:18 am » |
Ordered.
Peter, please add me to the list of short USB cables.
« Reply #40 on: December 27, 2015, 07:01:40 am » |
Best regards, Diede
Hi Diede, It doesn't work like that.   I didn't announce it like that, but say that the offer for the relatively very low price is for existing customers of the Clairixa. Think like a service because people are sort of (forced) in the corner because of the Intona. So normal price is 200 euros for 1 meter and then plus or minus 3 euros per 10cm more or less. For the second one counts the 100 euros, ehm ... for 20cm. And no, let's not start adding 3 euros per 10cm. I just don't know yet. N.b.: Max I saw so far is 30cm (excluding yours) so maybe it is going to be that. Of coure you can buy the first for the normal price and the second one with the lower price in one go. I did not put you on the list (yet). And I hope you are not offended.  Peter
Diede
« Reply #41 on: December 27, 2015, 09:42:25 am » |
No problem charging me 200€ for the first one, please put me on the list for both.
Diede
Stanray
« Reply #42 on: December 28, 2015, 09:12:54 am » |
I see what you mean Peter. Because of limited/no space on the shelfs of my rack, the unit will have to be attached to the rack somehow and that will require a longer piece of cable (20-30 cm). Regards, Stanley
Mamba315
Ferrari NOS1a
« Reply #43 on: December 30, 2015, 07:13:46 pm » |
I even wonder (without trying to be negative in any means !) whether Intona explicitly "generates" the 90 Ohms (which would be 2x 45 Ohms).
Hi Peter, Don't know if you saw this post on Whats Best Forum where Daniel from Intona answers some technical questions. One thing I noticed that relates to your quote above: "Our design is completely impedance controlled, also for the tight rules of USB 2.0 which is 90 Ohms for diff/odd and 45 even. We are experts in high speed circuit design with many years of experience." Also found it interesting that they use MEMS oscillators instead of quartz crystal.
Arjan
« Reply #44 on: December 30, 2015, 11:33:11 pm » |
Hi all, Got my Intona isolator today. Running it now, at first the dac was not 'seen' anymore. But after some switching of cables that is okay now. I use a standard Phasure usb cable from audio pc to isolator and Clairixa from isolator to dac. Result? Really good, for me it is not a night and day difference but the low and highs are more beautiful. Yes I like it very much so far, but that is after only 1 hour listening.... Regards, Arjan
