April 01, 2025, 12:40:28 am *
Pages: [1] 2 3 4 5 6 7 8  All
Author Topic: Intona High Speed USB 2.0 galvanic isolation  (Read 188710 times)
listening
« on: July 28, 2015, 11:11:15 pm »
That sounds interesting and seems to be an economical solution
http://intona.eu/en/products
« Last Edit: December 24, 2015, 11:42:02 am by PeterSt » Logged
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #1 on: July 29, 2015, 07:53:37 am »
Finally ...
Thank you Georg. I am gong to try one as soon as it's available.
jhmvl
« Reply #2 on: July 29, 2015, 03:20:05 pm »
I might be mistaken, but aren't these things (just examples) supposed to do (approximately) the same:
The only problem with these things seems to be that there are severe limitations on it (only up to 96KHz/24bit) and I cannot see if this is different for the Itona device mentioned here (but that is probably because I am not hindered by too much technical knowledge Grin.)
Hans
« Reply #3 on: July 29, 2015, 04:30:44 pm »
I think that up to now, the available isolators could not work at a speed higher than 12mbit, thus explaining why they are limited to 24/96.
The new high speed USB isolator from Intona seems to allow a transfer speed of 480mbit.
So it looks quite interesting Happy
« Reply #4 on: September 21, 2015, 01:21:58 pm »
I received an email about the availability of the Intona High Speed USB isolator this morning and I suppose you have too ?
It would be very interesting Happy I intend to eventually order it...
« Reply #5 on: September 21, 2015, 01:39:07 pm »
Hey Alain,
You know ... I completely forgot about this ...
I even forgot to sneak in one in advance (I thought I would be able to manage). So I certainly did not even think of subscribing ...
But time goes fast and it is already there ?
Great.
I just ordered one.
yahoo
Thank you for the reminder !!
PS: Should be here tomorrow or the day after. Will let know the "result" !
« Reply #6 on: September 21, 2015, 01:51:33 pm »
Aren't we here to help each other Happy
I see there are 2 "levels" of the same product (the "regular" and the "industrial" one), but I suppose that the regular would be more than enough Happy
I also see that they sell "barebone" ones (without the casing) with a minimum 25 units requirement ? Just saying, because I could eventually make a nice wooden box for it Happy
I feel a little "dumb", but even so I asked them if there was a DC input for people that would prefer using a linear power supply instead of the "dirty" +5V bus coming from the PC. But since there is isolation, maybe it is not useful to think about that...
We'll see Happy
« Reply #7 on: September 21, 2015, 02:05:59 pm »
Haha ...
I just stopped tinkering about that USB powered stuff. "By the USB bus". Oh, how ? I just don't get it for this moment, because what about the DAC side ?
But possibly the power travels over the isolator as well ...
Anyway I had the same idea - people might want to self-power it.
Otoh, also notice that since there is no external power supply, there also can't spring noise from that. Btw, this is in the (now there) datasheet :
Output noise : < 60μVRMS (20Hz–22kHz)
Now THAT is a strange spec (that frequency range) for a digital USB connection. Someone has been dreaming there or I just don't get it.
The industrial one also slipped my mind ...
The only advantage I personally saw was about more firm connectors or something. Otherwise ? well, I think it will be different (different chips used in there). So it may sound different. Happy
Still I (only) ordered the consumer version.
« Reply #8 on: September 21, 2015, 03:44:12 pm »
A strange spec indeed... It looks as if there are two different domains... Power and data ? It would be nice if they provide more details about this measurements protocol...
« Reply #9 on: September 21, 2015, 04:11:44 pm »
It would also be very interesting to see a graphic of the "USB pattern eye" with and without the isolation...
Humm...
listening
« Reply #10 on: September 22, 2015, 04:28:17 pm »
Maybe something like this http://www.ti.com/lit/an/slyt211/slyt211.pdf is used.
-> SMSL SU-8 ES9038
« Reply #11 on: September 25, 2015, 11:42:31 am »
All,
Yesterday the Isolator arrived;
It even works. That it "isolates" - I'll assume that.
The first what occurred to me was the led (at both the input and the output) which blinks of a rate of I think 25 times per second. Not much "audiophile like" if I may say so. Nervous looking stuff.
But alas, audible ?
I will start with sort of the end :
After 20 seconds of the first music, music stopped. This happens more often, namelijke once per year. swoon
After this, all was fine for the next hour, until again stops occurred which I did not recognize as common. And too many of them to comfortably listen.
This caused me to remove another "resistance creating" tweak, because I know of "anynschonisation stops" after a while because of wrong too high resistance in the cable.
Now it worked again.
Today, after countless number blinks of the leds all night long, I played something, but sound stopped within 10 seconds. And again. And again and again.
It did not want to work any more.
I removed the Isolator, and all was fine.
And with relief.
The sound with Isolator - I don't know what to think of it. It can only be wrong-wrong-wrong, but how can I really know. *Everything* is emphasized and in a fashion which bytes. As if all is too fast; no difference between a low volume and the development of a blast. The blast is there too much at once (some would call it too dynamical). Bass is very very stiff, without much "feeling" in it. Woofers feel odd.
Technically very good ?
Because I was trying to get a track running for quite some times this morning, it was quite easy to hear the sudden difference without the Isolator. All now had frequency under it. Not that the sound with it was too cold, but as said, there wasn't sufficient development of the tones.
What shall I say ... Not recommended ?
« Reply #12 on: September 25, 2015, 02:47:36 pm »
Thanks for the report. I guess we will wait a while and see what others will develop around, since this seems to be the first to work under hi speed USB (480mbits).
I did not check if there is a return policy about it, but it would certainly not be bad to express to them your perception about it. That led that blinks like crazy, the stops, the alteration of the signal that seems to affect SQ... All things that could be a feedback and encouragment to refine the product...
When you have time of course, but since we are playing with dates with Win 10, maybe it will allow you some more time Wink
Thanks again !
PS: Maybe it is time (again) to think about something like the Adnaco Wink
listening
« Reply #13 on: September 25, 2015, 04:33:17 pm »
It's a pity. The device is an additional module in the chain and it seems, that it's intrusing additional interferences into the system with regard to timing and whatsoever. So there is no easy silver bullet for SQ with galvanic isolated USB ...
Georg
-> SMSL SU-8 ES9038
« Reply #14 on: September 25, 2015, 04:39:45 pm »
I am wondering if galvanic isolation is a trade-off ? If anywhere where there is *real* galvanic isolation, there is automatically a loss in SQ ?
