November 22, 2024, 05:13:31 pm *
Pages: 1 [2] 3 4  All
Author Topic: XXHighEnd PC with Windows 10 from RAM  (Read 75607 times)
« Reply #15 on: July 27, 2015, 04:21:06 pm »
Hi there Todd,
We are all summer-slow - no worries.
But a question : Super great about the Ferrari's which grow all over you, but do you also have an XXHighEnd PC-Ferrari ?
Maybe you do and I forgot. Browsed briefly through some email titles and don't see it there either.
or
Anyway I'd like to purchase the whole package
... you don't mean the PC with that, do you ? whistle
Peter sleeping
toddn
« Reply #16 on: July 27, 2015, 04:40:31 pm »
I have the same ASROCK MOBO and all the same hardware but a full ATX case, is that doable? Hope so.
By the way did I remember a Ferrari red NOS1 pic somewhere?
Todd
« Reply #17 on: July 27, 2015, 05:37:22 pm »
OK Todd. All fine then !
Yes, obviously I was thinking about the Ferrari-NOS1 ... but must think where I put that picture.
« Reply #18 on: July 27, 2015, 05:49:52 pm »
The Ferrai-NOS1(a by now) was in here :
Active Speakers - Why ?
Also see below; different color (number) ...
Jud
« Reply #19 on: July 27, 2015, 07:08:28 pm »
Dave,
Do you plan on using the official Windows 10 version when it is released?
Difficult to say at this moment. One answer is :
I see many more reasons why *not* to do that, than do it. Anyway I myself have no single reason to do it.
Additionally, it will only mean work for me. It takes one thing only to do nothing : keep that 10074 build available (and I will take care of that anyway).
Also notice - and this may not be so obvious to everyone - that the 10074 build *really* is free, does not show nasty adds(ware) and does NOT require an existing W8(.1) or W7 license. The final build will (and you will lose the licensing right on the other one. Of course you can normally buy Windows 10 to avoid issues in this context.
Summarized : W10 is not free at all. You're hoaxed to some extent. Still, such a Preview is free, but don't ask me how long it will last. I could not find data on that (like the W8 Consumer preview worked for 15 or so months only).
http://www.pagestart.com/win10tpbuildexp041215.html
music33
« Reply #20 on: July 27, 2015, 08:16:59 pm »
The difference is that external factors now first imply the "no writes" (because we're in RAM) and that now provisions must be found/created to apply those changes after all. Just for convenience.
We maybe passing each other - agreed, by having the OS in RAM you have no writes unless other provisions are made.  So if I change settings in the Windows 10 for networking (e.g. set a static network address) how do they get saved when the OS is in RAM, hence no writes?
Also, you'll notice the link Jud sent has Windows 10 build 10074 is set to stop booting on 10/10/15.  Perhaps by changing the BIOS date, this can be verified...
Arjan
« Reply #21 on: July 28, 2015, 12:04:43 am »
Short question: why detach and re-attach the HDD? (So the hot-plug)
Just for SQ, or is there another reason?
When running OS and XXHE from RAM might the HDD be still attached?
Regards, Arjan
March, 2024 (2.11)
« Reply #22 on: July 28, 2015, 08:09:11 am »
Arjan,
Yes, for SQ.
And Yes, can just as well remain attached. But that violates the whole purpose (which is not running the OS from RAM but which is the HDD not being in there - nor anything else).
« Reply #23 on: July 28, 2015, 08:09:52 am »
Jud, Thank you !
« Reply #24 on: July 28, 2015, 08:21:11 am »
You won't do it in that sequence. Instead, again the other way around :
Set up your system to your liking and take as much time as you need for that ... operating from the normal disk boot (see earlier given screen shot of the Boot Manager, 1st option). Done ? then reboot (automatically boots into the 3rd option (RAM) and takes your disk OS version as the base).
« Reply #25 on: July 28, 2015, 08:36:01 am »
Anyway, this urges for a set up which will last longer. yes
coliny
« Reply #26 on: July 28, 2015, 09:33:48 am »
Perhaps we need a new thread for covering W10074 expiry:-
I changed system clock in a test pc installation of W10074 to 22.9.15 and immediately got message that It would expire in October 2015.
Reset it to today, rebooted and still works without the expiry message.
Changed date to 2014, rebooted and W10074 still works. So this might buy some time for finding a proper solution.
BTW - internet sync time was turned off (not that we ever need to connect to internet). Also in EVENT VIEWER - WINDOWS LOGS there are records of the date changes but these can can all be cleared.
« Reply #27 on: July 28, 2015, 10:40:55 am »
Maybe you can make something in xx that reset the date after every start. Or something  Happy
« Reply #28 on: July 28, 2015, 11:11:32 am »
Colin & Gerard,
Yes; manipulating the date is the most obvious (and still legal if you ask me). Still I like to test this first because there are also other things that are not so obvious;
Side note : Thank you Colin - now I don't need to test that part any more.
I am pretty confident that the "SxS" (Side by Side : https://en.wikipedia.org/wiki/Side-by-side_assembly) stuff may get confused by this, once we update parts of the system.
I forgot the situation(s) but when we e.g. put a newer file to the system than the current time implies, the older file won't be removed from system cache and causes anomalies. But this is outside of reboots and obviously we will reboot in such a (time lapse setting) situation.
Point is also that at least I am not used to this at all because modern IT systems will be molested right away when the attempt is made. I can tell you : 10 years back or so the Atom clock (I think in the UK) went bananas and started telling that it was 2021 or so. Now THAT messes up systems. Especially when all was fine again (back to say 2005) because things in such systems anticipate sequence numbers based upon the year etc. and that no anti-dating (set back the time) is allowed / possible etc. etc. etc.
For us and audio ? probably no problem. But still I can wonder what will happen when I set back the date to 2012 for my W10 system.
Colin, be happy to ...  Happy
But otherwise this is the obvious solution.
nik.d
« Reply #29 on: July 28, 2015, 12:26:48 pm »
The message(s) during RDC set-up (W8, have not played with W10 yet) say that time settings between 2 PC's are
very important for establishing RDC. Can someone with W10 and 2nd PC for RDC check this pls?
George
Page created in 0.128 seconds with 19 queries.
