April 05, 2025, 12:05:31 am *
Author Topic: XXH 2.02 will not start with W10 build 10074  (Read 5946 times)
« on: July 05, 2015, 05:18:15 pm »
please see this message!
Prior every step was followed acc. the manuals.
« Reply #1 on: July 05, 2015, 05:52:41 pm »
Hi Joachim,
Nah, somewhere you deviated from 'some' path. Not sure where. But you can try this :
Change the UAC to some other level. Reboot.
Uninstall the Phasure OCX. Reboot.
Start XXHighEnd and hope that it will start with installing that OCX again. However, when it first applies the UAC change itself + reboot, then it is also fine.
If this does not help then best is to reinstall the OS.
An additional remark : When you, via all sorts of detours, have 'followed the manual', then you did NOT. I mean, the sequences of all often is crucial.
Regards and I hope it helps,
