April 05, 2025, 10:40:31 pm *
Author Topic: Doc offset  (Read 6539 times)
Shreekant Somany
« on: June 26, 2015, 04:23:55 pm »
Dear Peter,
1) I want to check the cd offset of my DAC, please sedans me the procedure and also the DC offset of my DAC. Presently it's showing
-05.0 on top screen and 0.31 on the bottom screen.
2) what is the pin configurations of the balanced XLR output.
Shreekant
shreekant
« Reply #1 on: June 26, 2015, 05:01:23 pm »
Hi there Shreekant,
DC Offset is perfect. So I can't tell you a procedure to improve it !
(is this a good answer for you ? because I am not sure about the question)
The bottom pin of XLR is ground. The other two are the "hot" pins.
OK ?
« Reply #2 on: June 26, 2015, 05:22:06 pm »
Shreekant - from an email to you on March 20, 2013 :
The DC Offset we measured here for your NOS1 is -04.2mV/-02.4mV.
... with the notice that for the normal NOS1 it can differ 1mV or so. Thus as said, "perfect".
Shreekant Somany
« Reply #3 on: June 27, 2015, 11:56:18 am »
First off all sorry for the typing error, what I also meant was DC offset,
and thanks for the pin configuration.
I have just installed my new CAT JL 5 power amp and with the phasure the sound is fantastic.
As per your suggestion I have downloaded and saved the preview version of windows10, i will be upgrading my computer to Intel 6 core processor very soon but I want to install win.8 with Xxh. 2.02 till it's fully compatible with the finally released win.10 version.
For your information I will also use the comp. for processing movies in 4k, and that's why I want to wait till you are satisfied with the Xxh 2.02.
Your comments please,
Shreekant
shreekant
