April 17, 2025, 09:50:35 am *
Author Topic: W10074 XX2.02 error msg @ start of play  (Read 7461 times)
coliny
« on: June 25, 2015, 12:53:23 pm »
I get this message when I click play in minOS:- "the counter layout for category specified is invalid.............". I click away the message, press STOP then press play again & play starts ok. The issue occurs after every reboot. This may have started after I did a refresh of "time stability(W8)" which then asked for a reboot.
« Reply #1 on: June 25, 2015, 09:02:26 pm »
Hi Colin,
Odd ... Or maybe not because it's this W10 preview. But I have not seen this and tried both the "Not so stable" etc. settings. And neither showed this issue.
But are you OK with this ? I mean, "doable" ?
« Reply #2 on: June 26, 2015, 08:33:41 am »
Colin,
By now I investigated this a bit further and I can see indeed that it must be about something in the OS which is "half cooked" so to speak.
I think you can avoid the error by means of deactivating the "Garbage Collect" button in Settings (under Memory Section). At this moment I don't know the literal name of the button, but set it so that Garbage Collection wil NOT be applied.
One other thing :
I strongly feel that this is related to that "happening" you had the other day and where you had to switch on winmgmt manually. So I now think that something else (slipstreamed) is involved here, but I can't tell what.
If you can revert to a Restore Point from before that winmgmt issue, chances are fair that the error will be out of the way. However, just guessing.
coliny
« Reply #3 on: June 26, 2015, 10:10:02 am »
Thanks Peter,
I should have said the "garbage collect" message came up before the "the counter layout for category specified is invalid............." message. As you suggest with Garbage Collect turned of I don't get either message. Not keen on going back to a restore point at moment.
Time Stability however does not display a value, it never has since installing W10074. If I click REFRESH it shows "STABLE" but restart XXHE and it goes back to no value displayed, I'll make this another Subject if you like.
« Reply #4 on: June 26, 2015, 10:50:00 am »
Colin,
Yes, why not (separate subject). But copy-paste a little and don't spend too much time on it for now. But, with the topic there I can look into something (maybe).
Regards and thanks,
