November 27, 2024, 10:13:32 am *
Author Topic: Activation on second laptop  (Read 7146 times)
DP01
« on: December 27, 2007, 09:33:46 pm »
Hi Peter
I also struggle with activation on a second computer. I have two laptops (one single core Celeron and one Dual Core) both running Vista. XXHighend was first activated on the Celeron machine. I then shared the XXHighend folder on this machine on my wireless network. I then tried to activate XXHighend on the dual core computer typing the path to the "activated" folder \\machine_name\share_name into the undemo section of the dual core laptop and pressed activate. This did not work.
Looking closer at your syntax for the path to the other computer "\\MyPC01\DRIVE_C_FromMyPC01\XXCurrentVersion\" I thought maybe for some strange reason I needed to share the complete c-drive of the first computer and then use that longer path for activation. (This path would then be: \\MyPC01\C-drive\Program Files\XXHighend\).
In connection with this I ran into problems sharing the program folder of the Celeron machine (XXHighend was installed into the Program Files folder) on this machine. I could not access it from the dual core computer. I then tried to move the XXHighend folder on the Celeron computer to a folder directly under C: (C:\XXHighend) and share it from there.
This resulted in my fully activated version turning into a demo version again clapping clapping. Moving the folder back to it's original position under C:\Program Files did not fix this problem. Re-entering the activation code did not either fix this problem.
So instead of having activated XXHighend versions installed on two laptops I now have no activated versions running.  unhappy
This very effectively stops my plans to find out the sonic differences between single and dual core playback and also to enjoy my collection of WAV's with the best possible quality. Urgent assistance is needed  Happy
And by the way... Both computers are members of the same workgroup.
HP 6720s laptop / Vista Home Basic / Q1 = 14 / Playerprio = Low / ThreadPrio = RealTime / Scheme = 3 @ Attended -> Stello DA220 Mk2 USB DAC 44.1/16 -> Dynamic Precision C1b -> Dynamic Precision A1s -> Respons Grand
« Reply #1 on: December 27, 2007, 11:02:48 pm »
At this moment I don't even start to comprehend with what's happened, but I'll help out by PM.
Sorry for the inconveniences !
datawolf
« Reply #2 on: January 20, 2008, 02:11:33 pm »
I'm also unable to activate a second systen.
I've read all the posts and I know a fair bit about networks and tried everything but no, it won't work for me
Help.
Datawolf
« Reply #3 on: January 20, 2008, 02:40:27 pm »
It isn't you ... it's me ...  unhappy
See PM. Happy
Page created in 0.185 seconds with 19 queries.
