November 24, 2024, 12:15:13 am *
Author Topic: XX 2.02 Reboot error  (Read 11527 times)
« on: June 22, 2015, 03:09:51 pm »
When reboot (right click in Stop button) appears an error:
ChangeWP.exe. Application error.
The application failed to start properly (Oxc0000142). Click Accept to close it.
After a few seconds it disappears and the pc reboots normally. Not sure if it is important or not but just in case...
« Reply #1 on: June 22, 2015, 03:36:17 pm »
Yes Juan, thank you. I have it too and I think everybody has it.
I regard it unimportant although I wonder where it comes from (it is a W10 thing). At least you were able to make a screenshot of it. Haha.
I suppose this happens when you reboot via XXHighEnd, right ?
« Reply #2 on: June 22, 2015, 03:38:57 pm »
Too  Happy
« Reply #3 on: June 22, 2015, 03:48:01 pm »
Yes Peter, right click in the Stop button to reboot from XXHighEnd 2.02
« Reply #4 on: June 22, 2015, 04:40:48 pm »
Thank you guys.
I'm sure it is something with Windows 10, but it is also an indication that I do something there which should not be done at all. So I will look into it !
« Reply #5 on: June 22, 2015, 06:42:50 pm »
I am using Alt-F4 (RDC) and that works without error... minOS
« Reply #6 on: June 22, 2015, 06:45:03 pm »
Hi Bert, what is that Alt-F4 doing ? Reboot ?
Not sure but ... nea ??
« Reply #7 on: June 23, 2015, 09:55:24 am »
It pops up a menu where you can select to sign off, shut down or reboot...
« Reply #8 on: June 23, 2015, 10:07:32 am »
Whaaaaat ?
clapping
I just tried it on a W8.1 and there it works too (first put all the active programs to the taskbar).
Never too old to learn ...
« Reply #9 on: June 23, 2015, 12:56:33 pm »
Alt+f4 works but in my computer it makes it just faster. The error message still appears but in this case only for tenths of second.
