« Reply #15 on: June 22, 2015, 07:51:51 pm » |
Hi Rakesh, It can't be surely?... If it can't, I can. Peter
« Reply #16 on: June 22, 2015, 07:54:59 pm » |
Hey Gerard, your keyboard is broken ! hehe
Edit : Oh, deleting posts eh ? self-operating keyboard ?
« Reply #17 on: June 22, 2015, 08:00:18 pm » |
Haha i hate this tablet
« Reply #18 on: June 22, 2015, 08:16:25 pm » |
Are you guys trying get on our nerves?
Is that the famous tweak?
« Reply #19 on: June 22, 2015, 08:24:04 pm » |
Is that the famous tweak? Hey Juan ... If you mean the "tweak" I mentioned in the (I think) first post ... Yes. It is not famous YET that I know of. But maybe it makes it to be just that ?
rakeshpoorun
« Reply #20 on: June 22, 2015, 08:39:22 pm » |
Hi Juan, I am with you there. As far as I know they are speaking double dutch (pun intended for anglosaxons)! I think we should vote to introduce a method of negative scoring obscure, hidden meaning, indecipherable posts! If that is so(Windows OS being entirely run from Ramdisk), it potentially has monumental implications for our hard drive configuration. Yes, if Windows OS/XXHighend/Galleries/Playback(i.e. music files) are all running from quad-partitioned Ramdisk, then for me that means, we can throw the rulebook out of the window (the figurative real deal not the Microsoft one). How about that? Use a very fast SSD in PCIe slot that has Windows OS/XXHighend/Galleries/Playback in one place but with amazing transfer speeds to transfer everything at quicksilver speed to Ramdisk at boot-up and everything works at lightning speed from there on. Is this so? That would be most remarkable! Please say it is... Best rgds Rakesh
« Reply #21 on: June 22, 2015, 09:13:32 pm » |
Is that the famous tweak? Hey Juan ... If you mean the "tweak" I mentioned in the (I think) first post ... Yes. It is not famous YET that I know of. But maybe it makes it to be just that ?  Famous: refer to someone or something widely known. Until now it was not known by anyone, so it was known only in the imagination of those who read the forum. A kind of virtual fame. But enough speculation. If I have to see it in the bios, in my case at least, or it is not possible or I don´t know how. Or it is not in the bios? Come on Peter, you can not leave us this way! I think we should vote to introduce a method of negative scoring obscure, hidden meaning, indecipherable posts!
Rakesh, this is my vote: -0,5 I hesitate to vote worst just in case Peter gets angry and we have to wait one more week.  Juan
rakeshpoorun
« Reply #22 on: June 22, 2015, 09:57:47 pm » |
Rakesh, this is my vote: -0,5 I hesitate to vote worst just in case Peter gets angry and we have to wait one more week.  Juan Hi Juan, I fully endorse your vote, subject to the following reservations: 1. This may work! 2. It might save me money! 3. It is something I was half considering anyway, although thus far I was not completely sure as to how to make it happen. You do have something called non-volatile Ram but that's for highly specialised enterprise applications and costs a small fortune, unless you are Bill Gates. 4. I share your qualms about upsetting Peter for slightly different reasons. I still need him to upgrade my NOS1 to NOS1a next year. 5. Simple economics and undiluted timorousness really. If I negatively score him slightly less than you, you suffer the brunt of the fall-out. Now that everything has been weighted, the pros and cons carefully assessed, I will go with: -0.49999... Best rgds Rakesh
rakeshpoorun
« Reply #23 on: June 22, 2015, 10:16:33 pm » |
W8 or *W10* (both use the same settings) - June 7, 2015 (2.02) XXHighEnd PC -> i7 3930K Hyperthreading On (12 cores) @430MHz (!), 16GB, Windows 8 Pro 64bit or *Windows 10 Pro 64 bit Insider Preview build 10074* on SATAIII 2.5" 7200RPM spinning disk, XXHE on 2GB RAMDisk (IMDisk), music on LAN (*always On*) / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4* (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core3-5 / Not Switch Processors during Playback = Off/ Playback Drive 2GB RAMDisk (IMDisk) / UnAttended (Just Start) / All Services Off / Keep LAN - *Persist* / WallPaper *On* / OSD *On* /Running Time *On* (pref. as Bar but as Number sounds better) / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600* / -> USB3 (Silverstone both sides isolated = Sw#3 of NOS1a = Up) -> *Clairixa USB* -> 24/768 Phasure NOS1a 75B (BNC Out) async USB DAC, Driver v1.0.4b (*4ms*) -> Blaxius BNC interlink -> Orelo MKII Active Open Baffle Horn Speakers. Removed Switching Supplies from everywhere
Hi Peter, Can you please at least update your signature? Otherwise methinks that could be construed as misleading, as in incorrect, as in not quite true, as in likely to induce into error, as in quite deceitful really, likely to cause argument, conflict, civil disobedience, peaceful demonstrations, civil wars, insurrections (you get my drift)... Thanks Rakesh P.S. Requirements for Windows OS: "To: How big is Windows 10 on DVD and HDD? »» x32 (on the DVD ~ 2.5 GB, after installation on the hard disk drive ~ 9.0 GB) »» x64 (on the DVD ~ 3.5 GB, after installation on the hard disk drive ~11 GB) "So, Peter, even with 16GB of Ram, you may be able to pull it off, but just about....The reality being that you really need another 8-16Gb of Ram. You are a worthy hero for a twenty-fist century sequel to Mapes Dodge's 'Hans Brinker, or the Silver Skates.'
« Reply #24 on: June 22, 2015, 11:05:52 pm » |
Now I see that you used Windows Boot Device. I can get there but no idea how to put Windows in the Ram, so better I wait for your instructions.
« Reply #25 on: June 23, 2015, 12:57:33 am » |
You have my attention Peter.
rakeshpoorun
« Reply #27 on: June 23, 2015, 06:59:57 am » |
Yep, I saw that before but Grub4win seems to officially only support up to Windows 7 but maybe it works with Windows 10. Still, I do not understand why this should have implications for sound quality. XXhighend makes minimal requirements of Windows OS so I imagine both CPU draw and power consumption are negligible. I can see how this would change practical aspects of building an 'audio pc' but I doubt it ought to make any ostensible change to sound let alone make it 'scary,' presumably meaning by that "realistic." I am of course wrong but if I had to bet, I think above speculation is not quite it. There is something else afoot... Best regards Rakesh
« Reply #28 on: June 23, 2015, 07:58:28 am » |
I had a post here I didn't like and which wasn't relevant to anything anyway.
« Reply #29 on: June 23, 2015, 08:05:01 am » |
Not sure if this is what Peter is doing, but link on how to run Windows in a RAMDisk, watch the video.
Hey Dave, Yes, I investigated that one too but that is hardly something to work with for practice. Also, it implies knowledge which "we" don't have, so you won't get there with watching that video anyway. "You" ? well, that's the point; you may, depending on your experience. I, for example, from a normal ICT life would not. But then I have been researching this extensively and indeed I would get away with it (still not easy, but alas). But yes, that shows that it is possible and often it starts with such a good feeling (for the good spirit and being eager and such). Thanks, Peter
