November 23, 2024, 08:34:38 pm *
Author Topic: Win10 - playback will not start now  (Read 10920 times)
« on: June 19, 2015, 04:08:27 pm »
After installing win10, xxhe202 and nos1a 103 driver i get following message when i start xxhe "Necessary privileges have been set. Reboot to make them effective" . But after a reboot i get the same message. How do i fix this loop?
Ps Installing the new nos1 driver gives an error message during installation.
No administrator rights on the xxhe hyperlink?
Best regards Johan
« Reply #1 on: June 19, 2015, 06:25:13 pm »
Johan,
There's a tutorial for this but I first like to understand how this is possible. So, you are using the same version as we all do, is that right ?
10074
« Reply #2 on: June 19, 2015, 06:35:11 pm »
Tutorial is here : Mixed and Contiguous Memory - Get it going.
But I can't imagine that you (and not "us") suddenly need this.
What language did you choose for the OS download ?
« Reply #3 on: June 19, 2015, 06:35:56 pm »
Yes yes
« Reply #4 on: June 19, 2015, 06:37:44 pm »
English i think
« Reply #5 on: June 19, 2015, 07:16:50 pm »
Well, then I can only apologise to direct you to that tutorial. I just have no clue otherwise. sorry
PS: But I don't trust it !
« Reply #6 on: June 19, 2015, 08:27:42 pm »
Some remarks:
1 - I use the same build 10074;
2 - When i use mixed memory mode, all works and sound! This is the only modes that works;
3 - Do the xxhe shortcut needs the "run as administrater" property?
4 - I' m not sure if xxhe is activated the right way. What i see is that the name xxhighend 2.02 (c:\xxhe 202) is presented in colour blue. But I can choose core apointments. (Only possible in activated mode);
5 - In the previous version of xxhe i have always used the straight contigious memory arangement;
6 - I did not create a Windows login account and password.
Johan
« Reply #7 on: June 20, 2015, 09:11:38 am »
Hey Johan,
A great list you made there ...
Logically, because those "Privileges" are for the Contiguous Memory Modes.
No (and explicitly not).
It is not. nea
And there we'll have our little culprit.
Btw I don't even know how you can skip making that account (but I did not try either).
Anyway it passed by more often, already not using a password implies less rights. And now no account either ? no
You can try to add the account afterwards, but way (way) better would be to reinstall the OS. So what if you run into strange things again otherwise, without not really knowing ?
« Reply #8 on: June 20, 2015, 10:07:11 am »
Last night i have fixed the problems. All running no in minimized os. First impression : Sounds a lot more natural. A lot of small detaills. Nice brushes. Space. So far no complains about the bass. Bether than Win7 and 8.
First step i made a password. Yes there was an account. And did some reboots.
After some reboots I saw the orange colour of xxhighend on the screen. It's activated.
I red your tutorial about mixed and contiguous memory and did the steps in "You use another OS version lik pro or ultimate". After these steps "Straight Contiguous" works.
During the proces of minimized os i saw another message "Set state (pause) error on pin". After resetting dac / driver there was music!
Two remarks:
Every time after a reboot i need to enter a password. Can i remove that Windows password?
I'm working with the nos1 driver 103. Sometimes i see the sample freqency is changing automaticly and i can't stop that proces. But when i start the music all seems to work ok. Is there an explenation? Do you advise to install the latest Nos1 driver in a separed folder?
Best Regards Johan
