April 20, 2025, 04:36:54 am *
Author Topic: XX2.02 - Once in the Settings Area I canīt go back to the Library  (Read 9938 times)
« on: June 16, 2015, 06:45:49 pm »
Peter, Iīm trying the new XXHE 2.02 in W10-10074 in demo mode and found some issues.
When I click the S buttom to go to the Settings Area a message says (traslated from Spanish):
Not possible to check the editor.ŋare you sure you want to run this software?
Name: C: \ XXHighEnd2.02 \ nircmd64.exe
Editor: Unknown
Type: Application
etc.
see picture 1 (in Spanish):
and I canīt go back to the Library or the Playlist Areas, to do it I have to restart XXHE and then, when I click in Clear and after closing XXHE and also when I click Play after starting XXHE and charging some album a message says:
Something went wrong at clearing the Proxyīs; A good reason for this is when a temporary file receive the Read Only attribute...
Error (this is just an example because it happens with all the albums): Access denied because the file "100_Black_volume_6--Frontal.jpg" itīs been used in other pro
cess.
I know that I made at least one thing wrong (probably more) when I installed XXHE for the first time, I did it too quickly and I donīt know if that errors have something to do with it. I made a mistake when several programs asked to initialize and instead click in "do not show this message again" I clicked "ok" (continue). I reinstalled again XXHE but nothing changed.
Do you think that I have to reinstall Windows 10? I rather to do it before I buy the Activation Code to avoid having to use paypal repeatedly .
« Reply #1 on: June 17, 2015, 08:08:29 am »
Thank you for that screenshot, Juan.
What happened is that you let the checkbox remain checked when the programs / popups passed by during the install process and now "Under the hood things will go wrong" as the very first larger screen promises.
So the programs must run and the checkbox must imply "do not ask for this again".
What you can do is Rightclick the "Save as" button near the top in settings, choose Reset, quit XXHighEnd and start again. I think the pograms/popups will pass by again so you have another chance.
Let me know if it helps ...
« Reply #2 on: June 17, 2015, 10:16:02 pm »
Thanks for the help Peter, it took me a while but the popups were gone. I uninstalled/reinstalled the OCX although I'm not sure if it was absolutely necessary. Later I played for a while with the Skings settings and the result looks pretty good to me. The size and resolution of my screen does not allow the perfect shape of images but I think itīs good enough.
The sound seemed great at first impression so now I go to Activate it.
« Reply #3 on: June 18, 2015, 07:59:09 am »
Hi Juan,
You may not need or want help on this but ... do you mean that the aspect ratio is not right now ?
It is a bit hard for me to imagine what could be wrong hence it should be possible to make it OK.
So is it the aspect ratio you are referring to ?
« Reply #4 on: June 18, 2015, 03:25:54 pm »
Hi Juan,
Peter, Iīm happy to help, as always, if I know how. The recommended resolution of my monitor is 1366 x 768 - 60Hz and I canīt find that resolution in W10 nor in XXHE or how to make images without lengthening or stretching it a bit. Probably it is possible to do it correctly but I donīt know how, to tell you the truth, so far I always have had clicked the "Donīt do anything with Coverart" button. It is now that Iīm experimenting with it, so Iīm a novice  Happy
« Reply #5 on: June 19, 2015, 08:05:38 am »
Juan,
W10 hardly contains drivers at the moment. However, you may put in your own. So for example, if you have an nVidia video card you can download drivers for that and install them. But possibly this is too obvious to be the problem ?
« Reply #6 on: June 19, 2015, 08:36:03 am »
Yes I  can try  some envidia driver to see what happens.  Not a big problem though
