November 23, 2024, 09:34:42 am *
Author Topic: W10 XX2.02 / XX1.186 Bass  (Read 27786 times)
« Reply #15 on: June 13, 2015, 09:41:03 pm »
Peter hi,
I'm not interested in getting 1.186 working in W10 (unless you think this would give helpful information). I done want to end up on an unsupported software combination.
The key points regards bass are that
With 1.186 in both W8 and W10 bass is the same give or take a small amount quite exceptional.
2.02 bass is not so good in W10 at least, (I will give it a go in W8). I am just hoping that it might be possible in some way to reproduce 1.186 bass performance in 2.02.
If there is anything I can try here with my setup that might help understand this i'm happy to give it a go.
michaeljeger
Headphone Maniac
« Reply #16 on: June 13, 2015, 10:41:52 pm »
I think this is really a matter of taste. I like the more controlled bass of W10 /2.02 much better with my Abyss Headphones.
Today I decided to fully switch to the Windows Platform (from the Mac) because I like it so much.
The bass as it is with Win10 / 2.02 sounds just perfect.
I am out of my shoes.
Updated my signature.
Michael
« Reply #17 on: June 14, 2015, 08:41:09 am »
Nick,
In W10 a couple of additional things are being done. Also, a few things are NOT being done which happen in W8. In your situation, where the OS is recognized as W8, this is now "illegal".
I have made a firmware upgrade for your car. It does two things : Allow for a 1000 rpm more in general and it uncovers the always hidden 7th gear. You need methanol for the revs and a new key for the extra gear.
What you do is put in the methanol but don't use the key. Your complaint : it runs slightly slower then the promised now 230mhp but the noise is unbearable (10Krpm now instead of 9K).
The solution is clear : use that key.
The solution is not to go to the dealer and ask him what could be the matter with that noise.
I hope the example makes it sufficiently clear as I think we both know that such "sequences" may not be so easy to follow at all times.
When you have put in the proper key we can talk again, if you want. Prior to that all is moot as how I think. yes
Arjan
« Reply #18 on: June 14, 2015, 09:36:35 am »
Hi Nick,
About the bass performance, overhere we prefer the new 202. It seems to go lower and is less punchy. In other words more in balance with the overall sound. Before the bass could be a bit to much.
Last night for the first time my son listened to 202 and his first reaction was, what a good bass.
Regards, Arjan
March, 2024 (2.11)
« Reply #19 on: June 14, 2015, 10:12:25 am »
This post topic was intended to be is about the step back in bass performance (here at least) from official w8 1.186 to w10 2.02 configurations. This point seems to be getting lost in an unintended conversation on 1.186 in w10. I just get this is not valid.
If I were to started a new thread on 1.186 in w10 it would be a short,  single post to park the subject away from this thread  Happy I'm not bothered 1.186 in w10, I don't intent to use anything other than your intended configs.
I intended this thread tiopic to highlight only the change in bass moving from 1.186 (w8) to use of 2.02. Despite the supper performance of 2.02 in other respects, this change in bass performance is so significant right now I cannot see a way to move to 2.02.
I won't go on now, if I come up with any setting that help I will post otherwise I'll wait, fingers crossed, that something else comes up that can help here.
« Reply #20 on: June 14, 2015, 10:18:20 am »
Nick, I softly tried to tell you that you may have problems with "sequences". My methanol and key example apparently does not help.
Install W10 properly and try again. Period.
I hope this helps ...
« Reply #21 on: June 14, 2015, 10:30:11 am »
Hi Nick,
Regards, Arjan
Arjan hi,
That is interesting, I agree bass could be a little much with 1.186. The problem here is that with instruments like piano or chello or guitar the fundamental notes are just no longer there and the sound the body of the instruments makes cannot be heard now. Of course dance music suffers more  unhappy.
Interesting you and Michael do not seem to missing lower bass in the same way. dntknw
« Reply #22 on: June 14, 2015, 10:32:37 am »
Thanks Peter, point taken   Happy I will do the reinstall, fingers crossed
toddn
« Reply #23 on: June 14, 2015, 12:52:16 pm »
Nick,
do you ever check your p-mail here? I've been trying to reach you.
Todd
Sorry to have interjected here
« Reply #24 on: June 15, 2015, 10:57:19 pm »
Peter hi,
A result !
With the OS reinstalled and without the Windows 7 explorer utility installed Bass performance is restored. There are some differences but these are I think just better controled Bass then with 1.186.
The Subwoofers are up a couple clicks and sound quality is quite epic ! Im loving XX2.02 and W10 now.
Thank you for helping to sort this out.
« Reply #25 on: June 16, 2015, 08:00:52 am »
Glad to be of help, Nick. I hope I didn't come across too forceful. But pleasantry
Page created in 0.156 seconds with 19 queries.
