November 23, 2024, 02:26:36 am *
Pages: 1 [2] 3  All
Author Topic: W10 strange driver behavior  (Read 39501 times)
« Reply #15 on: June 14, 2015, 08:21:38 am »
Michael,
This switching can happen in different scenarios. The only scenario I can think of is that the switching happens between the last set (previous boot session) sampling rate for the base oscillator (44.1 / 48) and the other one. Uhm, an example will be more clear : Like you see it switching between 352800 and 384000 only and nothing else.
Is this so, or do you see something else ("random" is also an answer).
« Reply #16 on: June 14, 2015, 09:58:37 am »
Random would best describe what happened for me - "flickering" between different speeds - but the flickering was fast so not easy to see which speeds but looked like quite a few for sure 44.1 was one of them. Also and perhaps understandably that seemed to give rise to error messages as XX would not always start up. But after a few attempts XX would run OK and then and thereafter the flickering stopped until the next reboot.
« Reply #17 on: June 14, 2015, 10:08:00 am »
Perhaps 2ms for the driver in combination with your PC is a bit too fast?
Perhaps not related though...  Happy
« Reply #18 on: June 14, 2015, 10:08:50 am »
Maybe this is off topic, maybe not, but I just rebooted (into Normal OS) anyway, so I thought to have a look, XXHighEnd never fired up for this session. All normal.
Well, not all, because the 16ms of buffer where the driver install defaulted to (I reported about that) - and which was set to 4ms by me back at the time ... now is at 16ms again ?
« Reply #19 on: August 24, 2015, 10:03:20 pm »
I've got the same driver "problems" here. Installed the old 1.03 first on win10 10074 and ran into the next things with an unactivated v2.02:
1) driver does not see the NOS1a after the driver installation reboot, another reboot is nesseccary to see the dac in the driver control panel. Actually i dont know if this is installation related since I ran into this twice.
2) first play after executing xxhe2.02 gives a "buffer overflow" error, restart the track and everything plays fine
3)  saw the flipping of the samplerate, but no big deal to me
4) the nos 1.04 driver will not install. "Preparation failed" error no matter what I try.
Probably all known stuff, just sharing to provide support for the courageous that dare to wander onto the win10 path.
Greets, Coen
michaeljeger
Headphone Maniac
« Reply #20 on: August 25, 2015, 08:58:19 am »
One thing I want to add here using Windows 10.
The only player that is working is XXHighEnd.
The windows sound does not work at all.
When I go to the sound settings in Windows, I cannot play any sound.
Sound currently works in XXHighend but nowhere else.
Regards, Michael
« Reply #21 on: August 25, 2015, 11:04:19 am »
Coen, did you apply that (not) Driver Signing stuff ?
« Reply #22 on: August 25, 2015, 11:30:49 am »
I don't think so. The instructions say that you may have to do something, but I cannot figure out what. Googleing did not bring any useful answers.
regards, Coen
« Reply #23 on: August 25, 2015, 11:43:35 am »
Hi Coen,
Go to the Release Notes of 2.00 :
XXHighEnd Model 2.00 - New Filters & Extended Remote Control
and in there use ctrl-f to search for :
Driver
I am not 100% confident that it will still work when you first tried without this. So please let me know.
Regards.
« Reply #24 on: August 25, 2015, 06:30:35 pm »
After reading Coens problem with installing the new driver and Driver assigning stuff, I did an atemp to asign the new driver. Now i have some big problems! No sound and installation problems with this new driver. All was working ok. All the time great sound and latest driver was working ok. It was an atemp to fix this signing stuff. I did this installation in minimized os. Probably this was wrong....Now i have problems to get out minimized os. ...first i have to make a dinner...and read the manual......grrrrrr
Regards Johan
« Reply #25 on: August 25, 2015, 09:27:38 pm »
Thanks Peter,
Changing to "Drivers need not be signed"  via XXHighEnd settings (and not Windows 10 settings...  nea) with a reboot in NORMAL OS mode allowed the 1.04 version to install.
I feel sorry for Johan, but hey it could have very well been me not noticing MinOS. I hope you will be able to solve it without a reinstallation of WIN10.
regards, Coen
« Reply #26 on: August 25, 2015, 10:15:00 pm »
Hi Coen,
Finally i succeeded to reboot in normal mode and reinstalled the 1.04 driver. So xxhe is working with sound.
Regards johan
« Reply #27 on: August 26, 2015, 07:59:03 am »
Haha Coen, yes, that happened to me quite a number of times.
Good that it is all working for you both, now.
« Reply #28 on: August 26, 2015, 08:02:21 am »
yahoo
That's what I need to do as well quite often.
Grin
Even that ...
« Reply #29 on: August 26, 2015, 08:20:09 am »
......grrrrrr
Rules
Pages: 1 [2] 3  All
Page created in 0.111 seconds with 19 queries.
