November 23, 2024, 02:29:49 am *
Pages: [1] 2 3  All
Author Topic: W10 strange driver behavior  (Read 39503 times)
michaeljeger
Headphone Maniac
« on: June 13, 2015, 10:20:21 am »
Not sure if the title really describes what is going on.
So I installed W10 and 2.02 and all seems to work.
However, when I boot up windows before I start XXHighend the first time after reboot, Windows does not recognize the NOS1a at all.
In the control panel I see the device but the sampling rate is changing randomly 2-3 times per second.
Then when I start XXHighend and try to play something for the first time after reboot, I might get the error "Cannot set sampling rate". It usually takes 2-3 tries until I get playback.
After that, Windows also recoginzes the NOS1a and this crazy ample rate switching stops even if I quit XXHighend.
Anyone observed the same behavior?
I tried both drivers 1.04 and 1.03, no difference.
Thanks, Michael
« Reply #1 on: June 13, 2015, 10:45:48 am »
Yeh i have the same problem  sometimes.  Happy
« Reply #2 on: June 13, 2015, 12:34:12 pm »
Hi Michael,
Which W10 build are you using ?
michaeljeger
Headphone Maniac
« Reply #3 on: June 13, 2015, 01:08:45 pm »
Hi Peter
I just installed the recommended build 10074 (German version 64bit).
Regards, Michael
« Reply #4 on: June 13, 2015, 01:37:34 pm »
In that case ... I don't know. swoon
I can (very far away) imagine something like first installing 1.03 (which will install but isn't officially made for the job I'd say) and after that you install 1.04 (which avoids all officialities (the Signing)). In combination now it is W10 which messes up because it is *known* to not support any driver yet, actually.
But if this scenario is to lead to something, then Gerard must have installed 1.03 at first as well.
I sure did not and I also never saw the problem. That is, I am not going to look after a boot whether the NOS1a is recognized, but at least I never saw a problem with Playback not working unless attempted several times etc. It just works fine over here ...
« Reply #5 on: June 13, 2015, 01:46:07 pm »
My attempt was first the 1.04 driver version but after that 1.03.
michaeljeger
Headphone Maniac
« Reply #6 on: June 13, 2015, 01:56:38 pm »
I also tried 1.04 first and then when this strange sample rate changing occurred, I installed 1.03.
But 1.03 did not help to solve that.
Best, Michael
« Reply #7 on: June 13, 2015, 02:02:03 pm »
It looks like we are lucky that it works in the first place ?
Most heard complaint about Windows 10 is "no sound". yes
Ok, thanks,
« Reply #8 on: June 13, 2015, 05:33:09 pm »
I have installed 1.04 from the beginning and everything is fine here as well (so far).
« Reply #9 on: June 13, 2015, 08:22:39 pm »
As posted before I cannot install driver 1.04 and in 3 times I have installed W10 (different disks each time) I tried to load 1.04 before 1.03. I use 1.03 which works fine - I don't (except maybe some odd stuff have 48KHz material).
The first two times I installed 1.03 I had the same problem Michael had where the speaker symbol on the taskbar flickers and when you open the XX Nos driver panel the sample rate is randomly varying between different sample rates. But that has not happened on the last install so no problem now.
« Reply #10 on: June 13, 2015, 08:34:16 pm »
Hi Paul,
So you don't.
Okay. Ehm ... what ?
use ?
And if so, what about that Driver103.tss ?
scratching
michaeljeger
Headphone Maniac
« Reply #11 on: June 13, 2015, 10:09:35 pm »
Paul, what do you mean with the "last install"?
Did you do several Win10 installs?
Regards, Michael
« Reply #12 on: June 14, 2015, 12:04:58 am »
eerrmm!!! well yes I did make that change but I assumed it was to do with the varying sample rate problem - particularly as that problem disappeared after I made the change. I just checked and all sample rates play fine.
So no problem!!!!
« Reply #13 on: June 14, 2015, 12:16:16 am »
Yes I wont bore you with the details but involved problems with hardware including a DVD writer that turned out to be failing and is now in the bin. Anyway everything is OK now.
michaeljeger
Headphone Maniac
« Reply #14 on: June 14, 2015, 12:42:21 am »
Well the problem for me only occurs after a reboot.
Once XXHighEnd is running and playing, the sample rate problem is solved until the next reboot.
Michael
Pages: [1] 2 3  All
Page created in 0.121 seconds with 19 queries.
