April 05, 2025, 01:50:01 pm *
Author Topic: Restore Point Probem W10 XX202  (Read 10027 times)
« on: June 10, 2015, 09:39:31 pm »
I cannot create a restore point when going from FullOS to MinOS. The error message below is generated.
If I switch on Virtual Disk Service then I get another error message which I can post if you request. Let me know.
But for now enjoy your beer  Wink
« Reply #1 on: June 11, 2015, 07:48:31 am »
Paul, can you check this :
Start Explorer;
Right Click on This PC;
Choose Properties;
Choose System Protection;
Click Configure.
Is the slider at 0 ? If so, set it at 10GB or so.
Let me know whether this is the case and whether it helped for this message to go away (so I can make it a general guideline).
I recall that mine was at 0 but for me it is standard procedure to go in there as a first thing because the XXHighEnd PC's OSes means of setup require it. So now I don't know whether this can cause this message. Seems not, but *anyway* you wouldn't be able to make a Restore Point with that slider at 0.
« Reply #2 on: June 11, 2015, 07:27:40 pm »
OK I set the slider to 10Gb but it did not fix the problem still get the same error messages.
The error message says "Virtual Disk service is not running" so I set it running manually and tried again but I just got another error message.
So nothing changed by setting the slider to 10Gb
coliny
« Reply #3 on: June 11, 2015, 08:01:21 pm »
I had same problem but found that system protection was disabled in the System Protection window (same one that you set the disk space usage). I clicked the turn on system protection button in that window and was then able to create restore point via XXHE.
« Reply #4 on: June 11, 2015, 08:30:39 pm »
Hey Colin - nice one that worked for me also thx
KnB
« Reply #5 on: June 11, 2015, 08:59:43 pm »
And for me  Wink Tks!
« Reply #6 on: June 12, 2015, 08:06:07 am »
Ah, so you can set/change that slider position with the Protection itself being off ? That looks like a bug to me.
But OK, great that this is solved. And thank you for the feedback everybody.
