April 06, 2025, 03:56:30 am *
Author Topic: Windows Activation Key  (Read 14258 times)
« on: June 09, 2015, 08:37:46 pm »
You said that the code wont work. But if i remember correct i have seen yesterday that there already is a code in the system info. A different one though.
« Last Edit: June 10, 2015, 08:59:20 am by PeterSt » Logged
« Reply #1 on: June 10, 2015, 07:40:08 am »
Gerard, can you post that ? No problems with that being "illegal" because it is not.
Anyway I never saw any field with a code. Or maybe some screen passed by while I wasn't watching ?
« Reply #2 on: June 10, 2015, 08:47:14 am »
I would like and i tried. But going back to normal OS mode the start button does not react. In the search field (UAC) Typing something does not work. The audio device (right Under) Stay's red.
So something is not quit right when going back to normal OS mode.
 unhappy
« Reply #3 on: June 10, 2015, 08:54:53 am »
Something ? hahahaha
You mean ALL. yes
OK, never mind.
But anyway, I said it before, don't try to actually use this OS. Only for Audio ...
Regards and thanks !
« Reply #4 on: June 10, 2015, 08:58:49 am »
PS:
I did not try it, but maybe if you put the UAC somewhat higher (and reboot) the Start Menu starts working again. But only try this if you need it for some reason because when you start XXHighEnd it will be reverted to the lowest level again and apps (including the Start Menu) won't work.
UAC you can reach by Start-RightClick (if that works Wink) - Configuration - User Accounts - User Account Control (at the bottom).
PPS:
Search I have never seen working.
« Reply #5 on: June 10, 2015, 09:06:37 am »
PS:
PPS:
The thing is I cant reach UAC anymore. Right click on start button does not work anymore and i cant type it in the search field. Keybord works but no text will show up.  unhappy
« Reply #6 on: June 10, 2015, 09:09:09 am »
Maybe an idear to Make something in XX that raise the UAC automatically. And reboot after the change has been made.??
« Reply #7 on: June 10, 2015, 09:16:13 am »
Rightclick on Start will work again in 3 days. Just watch it happening. swoon
Quite easy to do. Good idea indeed.
« Reply #8 on: June 10, 2015, 09:22:53 am »
 good
« Reply #9 on: June 10, 2015, 09:31:25 am »
 wacko wacko After a third attempt it worked.  Happy
Here it is  Happy
« Reply #10 on: June 10, 2015, 11:22:15 am »
Hi Gerard,
Super. Well, almost. So indeed your OS is activated (somehow) but what you show there is not the Activation Key (but the "product key").
I think I have seen it somewhere once, but I really don't know where, at this moment. But please, it is fine.
Well, I hope, because I really can't tell how long the not-activated will last (while it's nagging for it regularly) and even MS does not know ... Smack !
Regards and super thanks,
« Reply #11 on: June 12, 2015, 09:39:41 am »
For fun i entered the activation key on the "false HDD". Connected to the internet and the activation worked.
