April 06, 2025, 12:15:10 am *
Author Topic: Win10 RDC Does Not Work in MinOS  (Read 19858 times)
« on: June 09, 2015, 07:43:37 am »
In Win10 when I go into MinOS RDC does not work - it works fine in FullOS. I have not had this problem before under win8 using the same XX settings which are below.
SQ is very promising but I need to remove the video card, keyboard mouse and screen to make a proper comparison.
« Reply #1 on: June 09, 2015, 08:10:42 am »
Hi there Paul,
Activate "Keep WiFi services".
This is only known since yesterday, and possibly related to using the RDP app from MS (so not the RDC normal program). Is that your situation too (read : what remote do you use) ?
« Reply #2 on: June 09, 2015, 08:12:44 am »
I use the standard Windows RDC
« Reply #3 on: June 09, 2015, 08:23:55 am »
I have just set "Keep Wi-Fi Direct Service" on but I still cannot get RDC connection in MinOS
« Reply #4 on: June 09, 2015, 08:48:04 am »
OK, then sort out your new IP Address of the Audio PC.
haha
And if you have done that already, then try what happens with Keep PAN services (next to WiFi-Direct).
Let me know ...
« Reply #5 on: June 09, 2015, 05:07:11 pm »
OK tried keep PAN services but no luck. I did try changing IP address and also no luck.
As you would guess when in MinOS the XX PC cannot see anything on the network. Also can't see the XX PC from anything else on the network. I can get out to the internet though
« Reply #6 on: June 09, 2015, 07:14:08 pm »
Paul, wrong work group maybe ?
What build are you using ?
« Reply #7 on: June 09, 2015, 07:30:51 pm »
Build 10074
It is in the bog standard default WORKGROUP as is this one. RDC works fine in normalOS so I would not have thought it could be a workgroup problem.
« Reply #8 on: June 09, 2015, 07:39:54 pm »
Paul,
I'm out of ideas at this moment.
Btw, don't focus on the PC ('s from mutual sides) are not seen. This is "normal".
What you can do is show me the Running services. Maybe I can see something from there ?
« Reply #9 on: June 09, 2015, 08:41:57 pm »
Attached
« Last Edit: June 10, 2015, 06:20:39 am by PeterSt » Logged
nik.d
« Reply #10 on: June 09, 2015, 11:18:32 pm »
Hi Paul,
Not sure for W10 but worth trying - solved my problem in connecting 2 PC's w/ W8: there is a small .bat file that will clear history
of all previous RDC sessions. Copy & run on both PC's. 'Music PC' was in MIN OS state with mou/kbrd/mon, all removed afterwards:
http://www.eightforums.com/tutorials/25423-remote-desktop-connection-clear-history-windows.html
Set RDP/RDC options (make taskbar or desktop icon for RDC) for W8 PC:
http://www.eightforums.com/network-sharing/5556-how-do-you-set-rdp-options-w8-seems-work-only-metro-app.html
Brgds,
George
« Reply #11 on: June 10, 2015, 07:14:19 am »
That is not how it is on my Win8 setup in minOS I can see out onto the network all other PC's but in minOS I cannot see the XXPC from any other device on the network.
« Reply #12 on: June 10, 2015, 07:37:39 am »
Check your email Paul. Thanks. Happy
« Reply #13 on: June 10, 2015, 07:41:46 am »
I was talking about W10 ...
« Reply #14 on: June 10, 2015, 05:44:05 pm »
All,
This is a bit of a pitfall ...
In the stage the OS is (Min OS) it won't "enumerate" PC Names. The pitfall is that it will in Normal OS, so you won't understand much why it doesn't work in MinOS, or easily blame something else (something not running). But MinOS (at least for W10) really needs the IP Address (I always use the IP Address, so I actually don't know the difference really).
Paul, I didn't look, but maybe now switch off WiFi-Direct and Bluetooth if that was On. Or at least try it without that.
Have a nice one ...
Page created in 0.014 seconds with 17 queries.
