November 23, 2024, 01:25:23 am *
Pages: 1 2 3 [4] 5  All
Author Topic: Win10 Activation Problem  (Read 60301 times)
« Reply #45 on: September 08, 2015, 03:46:15 pm »
Stanley,
You didn't install XXHighEnd in \Program Files\ or something else "official" ? IOW, you made a folder somewhere yourself ? (which is how it should be - I can't check it in the log file)
Otherwise :
Can you look in your XX folder for a file name ActiveS.txt. Something is wrong with that;
I think it is empty (but let me know) and I also think it can not be deleted (try that please - shift-delete).
If you can delete it, cause your logging to be on, restart XXHighEnd, try again and send me the log file again (if it again fails).
If possible, do it this afternoon - I never do much during evenings.
And, is this now in MinOS ? (just asking, not asking to try that).
Stanray
« Reply #46 on: September 08, 2015, 09:54:46 pm »
I put XXHighEnd in its own folder I made myself.
The ActiveS.txt is empty and CAN be deleted. I deleted it, restarted XXHighEnd and pressed . This logfile I will send.
This is in maxOS, I did't try that and XXHE isn't activated yet either.
Stanley
« Reply #47 on: September 09, 2015, 12:48:20 pm »
We'll look into this further by means of TeamViewer;
Curious what the problem is ... and will let it know when found.
« Reply #48 on: September 10, 2015, 08:46:56 am »
A little crazy ... but possibly because of being too much "beta" :
A bit difficult to explain for non-programmers, so I'll do it for the ones who know a bit about it :
In the part errorring out, I use a program from the \Windows\System32\ directory. However, the program is not found. Not in Stanley's case.
The Path (environmental variable) setting is OK, but does not work in this respect. No idea why. It looks like
%systemroot%\system32
and systemroot contains c:\windows
There is a difference with my system though and with mine the Path variable contains c:\windows\system32
So what I now expect is that in the XXHighEnd program either the whole Path variable or the systemroot variable is not known.
That is not all;
When the program of concern (an .exe) is copied to the XX folder, so the path is not necessary - it's output is different. Now, since this is a part in XXHighEnd which needs to anticipate on Language differences, I suspect that exactly this part subject to a different language, is just not output by that .exe of concern. So I am looking for something in the output of the program, but a common part (shared over languages) is not there while I use that to locate a position in the "string".
*That* this language dependent part is not output will be because all that language stuff will be in the System32 directory, to which the path is not working (or maybe better : that .exe doesn't like to be run from elsewhere).
All together the program fails (I can't read/locate its output) and I can't tweak it either (that I can think of).
Why doesn't it work with Stanley, while with others there's no problem ?
I don't know. But Stanley made a bootable USB stick for the install; possibly nobody does that ...
« Reply #49 on: September 10, 2015, 10:26:55 am »
I did use a bootable USB stick... (No CDROM present here!)
« Reply #50 on: September 10, 2015, 10:35:27 am »
Hmm ... thanks.
Stanray
« Reply #51 on: September 11, 2015, 03:56:19 pm »
I'm afraid I have to let it rest for now.
Trying to activate XXHE again brought up error messages and trying to install IMDisk also gave a message that IMDisk wasn't able to install.
Must be something in my Windows10 version  wacko
Stanley
stoni
« Reply #52 on: October 10, 2015, 02:45:26 pm »
Hi, it seems like we now are caught in a catch22 situation with the Paypal-activation under W10 (but we still have the txt-file option). IE11 reports certificate error, date, I have to adjust PC-date, which is not possible without WIN10 being outdated. It seems to be no workarounds, also tried deactivating checkbox' under IE11 advanced settings.
I also noticed that it's OK to adjust the PC-date, whatever date, before having connected the PC to internet. I could also go back to an earlier restore point (at least one year back), after accidently have adjusted the PC date to 09.10.15 (started WIN8 with it's automatically date adjustment not deactivated).
However, it seems like WIN10 after internet has been contacted, do not accept this, and we are back to what you and others have reported with time adjustment issues. My PC-time is now 01.09.15 (stupid me, without noticing, this was the time I set right before connecting  to internet for the first time).
If it's not possible to activate XXhighend directly via internet (certificate issues), it might be vice to totally avoid connecting the PC to internet? Next time, this will be my install procedure.  I'm also unsure if WIN10 now will stop in some days, weeks, I don't know, because WIN10 knows from internet that my PC-time is incorrect. The final countdown might have started...
The only reason for connecting to internet might be to solve display/graphic setting issues, which was totally messed up after my WIN10 installation, the internet connection did an auto-update on that.
Stein
February 2019
W10-10074 (2.10c)
*XXHighEnd Mach III, ffrom RAM, music on LAN / Engine#4 Special Mode / Q1/-/3/4/5 = 30/-/0/2/1 / Q1Factor = 40 / Dev.Buffer = 256 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 171/ not Invert / Phase Alignment on / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / All Services Off / Keep LAN - Not Persist / WallPaper Off / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = *35* / Nervous Rate = 10/ Cool when Idle = na / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Stable / Time Stability = Off / Custom Filter off / Arc Prediction on Upsampling off/ -> USB3 *from MoBo* -> Curious USB 15cm -> Intona Isolator -> Curious USB 1m -> Ayre QB9 DSD DAC (modified) -> Jeff Rowland Continuum S2 ->B&W 803d2 (heavily modified)
« Reply #53 on: October 10, 2015, 02:58:37 pm »
Thank you for sharing this, Stein.
But do you have a clue to what certificate this was about ? Is it something from PayPal ?
If so, I can imagine that. I mean, I am not sure what exactly changed at PayPal's, but there is a new security procedure as of Oct. 1 (2015).
If that is related, it is a bad date for us indeed.
« Reply #54 on: October 10, 2015, 03:06:28 pm »
Ha !
Stein, you must be lucky in love.
... Because with your Sept. 1 you were very unlucky ...
I just tested it, and exactly prior to Sept. 2 2015, a PayPal certificate is expired.
So use a date beyond Sept. 1 (like 2 and further, but no further than Sept. 15 to avoid W10 warnings), and it will work.
Great stuff.
stoni
« Reply #55 on: October 10, 2015, 10:18:54 pm »
Peter, yes, you are right, I can confirm it works, thanks thankyou
What still concerns me is the uncertainty around the expire date, but I guess we just have to wait and see...
Stein
February 2019
W10-10074 (2.10c)
benananda
« Reply #56 on: October 11, 2015, 02:46:11 am »
Hmm....
Just as I was ready to try a fresh install with the date 'fake' on an internet-less machine, I get the message that I need .NET Framework 3.5 to launch xxhighend.
Okay, I download that elsewhere and send it over and run it...only to get the message that to run .NET Framework 3.5  I NEED .NET Framework 3.5 .
HUH?
I tried .NET Framework 3.0 and .NET Framework 2 to be sure, but every time Windows 10 wants to DOWNLOAD it's own. I...don't think there's a way around this.....
USB to Matrix Mini-i (16bit 48Khz max)  (0.9z-7)
Windows 7 Ultimate 64bit SP1 on SSD, XX on other SSD, music on SATAII spinning disk (on SATA3 port of MB!), MB is Z77 Gigabyte G1 sniper m3, Ivy Bridge i5 3570, / Engine#4 Special Mode / Q1/2/3/4/5 = 2/0/0/0/0 / Q1Factor = 2 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / SFS = 430 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Unattended playback All off especially LAN!
« Reply #57 on: October 11, 2015, 10:17:22 am »
benananda, look here :
Windows 8 Tutorials - Install .Net 3.5
Same applies to W10.
DreamOperator
« Reply #58 on: October 17, 2015, 10:33:33 pm »
Hello,
Unable to activate in W10.  I don't ever see blue or red text.
I installed 10240 recently.  Fresh, not upgrade.  Placed XXHE 2.02 in C:\XXHighEnd, ran the program, did the .net install, rebooted, applied necessary settings for playback, entered activation code, played music, quit, started, played music, quit, started, still in demo.
I tried several times, no change.  Looking at the title bar I see XXHighEnd 2.02 text in white, never changes color.  Is that supposed to be blue?  I read the tutorial as well and see it was blue text in .9z-7 but other posts on this site make me think the bar it's self is blue.
Any suggestions?
Tim
« Reply #59 on: October 18, 2015, 09:32:06 am »
Hi there Tim,
Because of the new install, the Code does not work any more. Apply the same as we talked through Sept. 21. Only the payment is not necessary. Ok ?
Small warning : XXHighEnd (2.02) is not compatible with 10240 yet. What I have over here (2.03) is, but this is not up yet. Do not - I repeat - do NOT use 10240 in MinOS mode, or you'll have to re-install Windows again (or have a Restore point ready to recover by means of the install media (DVD or USB pen)).
I hope you took good note of this !
Page created in 0.12 seconds with 19 queries.
