November 23, 2024, 01:11:52 am *
Pages: 1 2 [3] 4 5  All
Author Topic: Win10 Activation Problem  (Read 60293 times)
Stanray
« Reply #30 on: September 04, 2015, 05:28:12 pm »
I could ask you why , but why ...
But I guess that is/was my point - now I can not judge it.
Any lust to retry it from the base (clean install) ?
That's how everybody is doing it, if all is right. At least that is what I told to do (for 10074). No problem if you missed that, but ... well ...
And if you do, don't forget to make that clone again.
And Stanley, maybe it can work now too, but maybe we come to the conclusion in 3 days time that it won't ...
 blush1 blush2 blush1
I read the Tutorials and all tree times and still must have missed that. Must be my headache, or my age.
No problem to make a fresh install.
I will be back.
Stanley
« Reply #31 on: September 04, 2015, 06:11:49 pm »
I don't think that is in the Tutorials (not even sure). It's somewhere in some topic (say the same as where 10074 is introduced).
Of course I assume that everybody follows all, but obviously (and logically) this is not true ...
Now : good luck !
Stanray
« Reply #32 on: September 05, 2015, 12:42:49 pm »
After successfully installing the V1.03 driver I started up XXHE to activate. Pressing the Settings button the following errors popped up:
- Something went wrong at obtaining values 03.
Pressing OK gives:
- Something wrong at obtaining values 02; possibly a reboot is the only thing to help.
Pressing OK gives:
- Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application close immediately.
Pressing Quit and rebooting brings back the same situation.
Is this solvable?
Stanley
« Reply #33 on: September 05, 2015, 04:30:22 pm »
Stanley,
I heard this from one other person, where it suddenly started to happen. But could be kind of your situation (his was W8 IIRC) ...
Do you (want to) use XTweaks settings ?
« Reply #34 on: September 05, 2015, 04:32:54 pm »
If not (!) so, there's a file NoXTweaks.tss in your XX folder. Rename that to NoXTweaks.tst and the problem will stay away.
How the problem happens to you, I don't know. Maybe you changed Power Settings ? (in Configuration Screen - Power)
Stanray
« Reply #35 on: September 05, 2015, 05:22:24 pm »
Yes, I DO use XTweaks. . .
When closing XXHE after the last mentioned error message, another error message shows: "Something wrong with 'Copy settings to' file (see preset settings): PresetLoader.XXSI.
Then XXHE seems to freeze.
I didn't change Power settings.
Stanley
« Reply #36 on: September 05, 2015, 05:59:02 pm »
Maybe you implied something strange wih Rights. Like you did not enter a Password for your Account, could skip the whole account stuff anyway, used a Microsoft account (was connected to the Internet during install) ... I don't know.
By now you have too many strange things.
Stanray
« Reply #37 on: September 05, 2015, 06:03:37 pm »
Yes Peter, too many rocks.
I'll start again from scratch.
Thanks.
Stanley
« Reply #38 on: September 05, 2015, 06:47:08 pm »
Ok Stanley, but in the blind ?
What about this password etc. stuff ?
Maybe now you create it with a Dual Boot ? if so, that too was not advised. However, I have seen others do this too (IIRC all with problems, but not your problems as far as I can tell).
Something must be "strange" hence not what all of the others do, including me.
Put in the DVD, enter the Keyboard and Country data and let it go. Answer all the questions under way (which is very few) and/but also enter a Password for the Account (local account - disconnect the Internet cable).
There's really not more to it that I recall ...
Good luck and don't get annoyed !
Stanray
« Reply #39 on: September 06, 2015, 12:08:26 pm »
Thanks for advice and warnings.
I did the password stuff etc. and I think I followed the instructions. But maybe a bit in a rush and in between other things, so still possible to forget something.
No dual boot, I have two identical hdd's, so always save.
Let's say I now had a bit of practice and I will have a bit more time, so I will give it a try.
Stanley
Stanray
« Reply #40 on: September 06, 2015, 08:46:00 pm »
Well, I repeated the whole procedure, clean install, etc. and ended up in the same situation as yesterday:
- "Something went wrong at obtaining values 03".
Pressing OK gives:
- "Something wrong at obtaining values 02; possibly a reboot is the only thing to help".
Pressing OK gives:
- "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application close immediately".
Pressing "ignore" will cause that [P] and [L] cannot become active.
Pressing "Details" shows a long list which I mailed to you Peter.
Hopefully this gives a clue?
Stanley
« Reply #41 on: September 07, 2015, 08:01:04 am »
Hi Stanley,
Can you cause the error while Logging is on and send me the XX log file of that ?
What (kind of) PC are you doing this with ?
Thank you and sorry for your troubles ...
« Reply #42 on: September 07, 2015, 08:20:22 am »
Also :
When you go into the Power settings (Config Screen, the green battery) and to Advanced Settings and then change something in there. Say Disk - Spin off time to 5 minutes or whatever.
If you restart XXHighEnd after this change, is the problem still there ?
Stanray
« Reply #43 on: September 07, 2015, 11:13:33 pm »
I will send the logfile in a minute.
It is my audio PC: Intel i7-2600S/ Mobo: Asus P8H67-V/ RAM: Kingston DDR3 16GB/ HDD 1: WD HDD. HDD 2: WD 2Tb Caviar Green.
Stanley
Stanray
« Reply #44 on: September 07, 2015, 11:14:30 pm »
Yes, problem is still there .
Page created in 0.174 seconds with 19 queries.
