April 17, 2025, 12:37:53 pm *
Pages: 1 [2] 3 4 5  All
Author Topic: Win10 Activation Problem  (Read 61478 times)
« Reply #15 on: June 08, 2015, 09:15:11 am »
So here's the Tutorial :
Windows 10 Tutorials - Make Internet Explorer available.
What's next ? I'm eager. grazy
dsm
« Reply #16 on: June 08, 2015, 04:03:54 pm »
After re-installing 2.02 on my c drive, activation worked as it should. Now minimized W10 is up and running without any problems. (yet?)
Thanks for all your hard work!
David
« Reply #17 on: June 08, 2015, 04:25:03 pm »
Hey David, that is super !
But thank *you* for trying so hard.
« Reply #18 on: June 08, 2015, 04:30:56 pm »
HaHa,
be prepared, the week just started  Happy
So, you need this challenges.  Happy
*** But the main question will be how to proceed, when this "Insider Preview" will be shut off sometimes, or interested persons have no Insider Preview?
Diede
« Reply #19 on: June 08, 2015, 05:24:32 pm »
Thank you for the Tutorial, XXHE 2.02 and 1.04 driver are now running under W10 Min-OS! Grin
Can you share your settings in W10?
For the time being I used the W8 settings.
Diede
« Reply #20 on: June 08, 2015, 06:10:22 pm »
Hi Diede,
............I know wrong topic, but how does it sound?yahoo Happy new year !
Johan
« Reply #21 on: June 08, 2015, 06:29:45 pm »
If i can say something.  Wink
Just as Peter said totally unheard...  Happy Difference is big... I just love it.
If you have pc only for playing music than i would not waste time on W7 or W8  Happy
Happy Me  Happy Happy Happy
« Reply #22 on: June 08, 2015, 06:38:14 pm »
Hi Diede,
I changed nothing to my settings compared to the W8 ones. Internally things work different though (I am at version 2.12 by now - haha).
Anyway I adjusted my sig so it reflects W10.
Stanray
« Reply #23 on: September 04, 2015, 12:47:23 pm »
Finally I found the courage and associated time to install W10 (100074).
Starting point was W8, XXHE 2.02 and driver V1.04 that runs perfectly.
I cloned the C-drive to another drive and worked with the second drive, so I could fall back on the first drive when things screw up.
I installed W10 from a thumb drive (USB-stick) according the Tutorials (hopefully in the correct order).
All went without problems and I have XXHE2.02 now running under W10, minimized and unattended. yes
I was under the impression that I need to activate XXHE, following Tutorial 72, but all seems to work already and the line in the left hand top corner shows in red.
So no activation is necessary? I was under the impression that XXHE needs to be re-activated under a new OS?
Thanks.
Stanley
Stanray
« Reply #24 on: September 04, 2015, 01:33:31 pm »
 unhappy
Obviously, that was not the right thing to do.
Now I won't be able to go from minimized to the original OS state. XXHE freezes.
What to do now?
Stanley
« Reply #25 on: September 04, 2015, 02:07:30 pm »
Hi Stanley,
You mean : you can't go back to Normal OS because it appears that XXHighEnd is not activated at all ? (which latter would be my assumption)
That was so, ever back. Today going back from MinOS to Normal is allowed without Activation.
The "freezes" I recall far back in my mind. What about a forced reboot in this stage ?
Do pay attention to the OS state, because it can be fine (Normal OS) after the reboot. The message you may receive ("it appears that the state of the Min OS button is wrong - now it shows the proper state" or something like that) is always reliable, according to my experience.
Stanray
« Reply #26 on: September 04, 2015, 02:25:16 pm »
Yes, that's correct.
A forced reboot brings back the same situation: minimized and not be able to go to normal, because of "freezes".
Meanwhile I reinstalled W10.
But then what?
Do I activate the seemingly already activated XXHE (used under W8) or do I need to delete that and download a "fresh" XXHE and activate this?
Stanley
« Reply #27 on: September 04, 2015, 04:17:33 pm »
Hmm ...
This seems a bit difficult to judge;
Am I correct in thinking (reading) that you upgraded a W8 to this W10 ?
Stanray
« Reply #28 on: September 04, 2015, 05:13:48 pm »
Eh, yes upgraded.
« Reply #29 on: September 04, 2015, 05:21:15 pm »
I could ask you why , but why ...
But I guess that is/was my point - now I can not judge it.
Any lust to retry it from the base (clean install) ?
That's how everybody is doing it, if all is right. At least that is what I told to do (for 10074). No problem if you missed that, but ... well ...
And if you do, don't forget to make that clone again.
And Stanley, maybe it can work now too, but maybe we come to the conclusion in 3 days time that it won't ...
