April 05, 2025, 05:37:28 am *
Author Topic: NOS1a Driver  (Read 28250 times)
« Reply #15 on: August 26, 2015, 10:45:24 am »
Notice that in the end you don't really need the 1.04 Driver (when you use XXHighEnd). Renaming the Driver103.tss to Driver103.tst will do the job ...
I am confused about which driver to use. As you say if we rename the Driver103.tss is not necessary to install the 1.04. That's what I did and that's why I never installed the 1.04 driver.
Does that mean that the 1.03tss is the same as the 1.04?
I see that almost everyone installs the 1.04 with apparent improvements in SQ...
« Reply #16 on: August 26, 2015, 11:01:57 am »
Juan, emphasis is mine and - No. I see only one, unless I include myself which would be a very wild guess. But it could be.
My remark could be about symantics only.
And the "everybody" who installs the driver, is almost everybody without knowing why. Don't ask me the why. Happy
Most part will be about confusement and how AT FIRST 1.04 was necessary for XXHighEnd 2.xx.
But with the Driver103.tst not any more.
But there sure can be a reason : using other players. Could be movie players (like I use MPC) or other audio players.
So XXHighEnd is self supporting and can do without the 1.04 Driver.
WATCH OUT :
When 1.04 is installed, the Driver103.tst MUST be renamed to Driver103.tss again, or otherwise larger ticks will be your share when the sampling rate changes.
I hope it is clear somewhat ... Wink
« Reply #17 on: August 26, 2015, 12:08:04 pm »
WATCH OUT :
Thanks Peter, then, if I understand you well, with my system configuration (I don´t use other player than XXHE), do not need to install the 1.04 driver even with regard to an improvement in SQ compared to 1.03 (103tst renamed). In other words, the only reason to change to the 1.04 driver would be in case of using other player and, talking about what matters to me personally, I understand you have tested 1.04 vs 1.03 (103tss renamed) using XXHighEnd as the only player and have not found differences in SQ. Is that correct?
« Reply #18 on: August 26, 2015, 12:24:46 pm »
Ha, ha, Grin Grin
somebody wrote on August 18, 2015, 10:40:55 am
(the 1.04 driver is a tweak to begin with)  whistle whistle
***and we like TWEAKS to squeeze ....... .***
« Reply #19 on: August 27, 2015, 07:56:37 am »
grazy
A tweak is not necesserily something which leads to better sound. Using your wife's panties to repair the broken car engine fan (etc.) belt is also a tweak.
In this case it is to avoid the Driver Signing necessity which is a pain to setup, costs quite some $$ and ... I like tweaking.
« Reply #20 on: August 27, 2015, 08:00:22 am »
Hi Juan,
No, that is not correct. I use 1.04 alright and used 1.03 prior to that, but I never watched for a possible change in SQ (which wasn't to be expected anyway). So I don't know.
« Reply #21 on: August 27, 2015, 10:25:03 am »
Hi Juan,
Ok thanks Peter, then I´ll try to test both drivers to see if there are differences in SQ. From what I've read about the installation of the 1.04 driver I think these are the steps to follow, is there anything else to consider?
http://www.phasure.com/index.php?topic=3317.msg35816#msg35816
michaeljeger
Headphone Maniac
« Reply #22 on: August 27, 2015, 12:55:20 pm »
I also installed the 1.04 drivers yesterday.
For me there was a perceived change in SQ.
Namely:
- Deeper, lower bass
- more clarity, presence in upper/midtone
But I still have the open question which is:
Only XXHighEnd produces sound, any other software player is not working.
Regards, Michael
« Reply #23 on: August 27, 2015, 01:23:47 pm »
same here Happy Happy
« Reply #24 on: November 12, 2015, 10:37:07 am »
I'm running XX2.02 with the 1.03 driver (changed .tss to .tst) and everything works fine.
Are there anymore views as to whether 1.04 sounds better? (I don't want to hassle Peter unnecessarily for the 1.04 driver if there's really no need.)
« Reply #25 on: November 12, 2015, 12:03:35 pm »
 While I was going to, in the end I haven't  compared the two drivers, so I join the same question that Mani
Page created in 0.016 seconds with 19 queries.
