November 24, 2024, 04:26:15 am *
Author Topic: XXHighEnd Model 0.9t-2 (intermediate version)  (Read 7561 times)
« on: December 23, 2007, 10:41:18 am »
Here again is a version I wanted to preserve because of its (IMO) fine sound. Mind you, with *Attended* playback.
Put the XXHighEnd.exe coming from the zip in your 0.9t-0 folder.
In the mean time a few things were added/solved :
  • Cue files can now be loaded from the Library Area.
  • The problem with tracks (or path names) with diacritical marks is definitely solved (and loading of such albums/tracks won't take longer anymore opposed to not containing diacritical marks).
  • Cue files containing diacritical marks took very long to load, each track again (could be 30 seconds). This is solved per above solution.
  • Meta data (.mta) tracks as contained in Galeries now can be selected by means of Explorer (not only from within the Library Area (rightclick on the coverart - Show/Load tracks, but also directly from Explorer - drag).
  • A bug is solved causing the first Track Title of a Cue file album showing the same as the Album Title.
  • A bug is solved causing very small Track Names (like Mu) to error out with Cue files.
  • A bug is solved, not allowing Physical Copy by means of selecting without Checkboxes.
  • Once the Library Area contains a list of Albums/Tracks, it is the intention that when you Quit XX, they are reloaded there at the next startup;
    They were, but depending on what you did not in full. This is solved now.
    Remaining issue : when you quit XX with a text to search filled in the field concerned, at a next startup the "full list" comprises of that implied selection only, and a next Search with empty search field really is required.
* XXHighEnd-0.9t-2.zip (101.46 KB - downloaded 683 times.)
Page created in 0.132 seconds with 19 queries.
