April 08, 2025, 10:32:05 pm *
Pages: 1 2 [3]  All
Author Topic: My first Windows 10 experience  (Read 43957 times)
« Reply #30 on: June 04, 2015, 06:36:22 pm »
ohhh f*ck
« Reply #31 on: June 04, 2015, 08:10:48 pm »
ohhh f*ck
Good?  unhappy
« Reply #32 on: June 05, 2015, 11:30:59 am »
scare
« Reply #33 on: June 05, 2015, 11:37:14 am »
So RightClick on the Stop button now shows a third option in W10. This can be
- Stop W10 Updates
- Allow W10 Updates
- Allow W10 Updates n/a (state is MinOS)
The Stop will permenently disable the Updates (persistent at Reboots) and the Allow will allow them (also persistently).
What shows in the screen shot is the situation that we're in Minimized OS Mode and that the change of state is not possible, with the notice that in MinOS the Updates are off always anyway.
« Reply #34 on: June 05, 2015, 11:50:11 am »
What actually happened yesterday was this :
Right after announcing the "now listen" I started playback;
The quite random few tracks I put in the Playlist Area started with one which after 10 second made me startle because of the sudden blast after 10 seconds or so, I actually never heard in that track.
Parallel to playback I was firing up the BBQ so I was going in and out a couple of times. The first time I came in again I heard breaking glass. Looked around a bit, but it appeared to be coming from the speakers. Ok.
Next time I came in, a track of another album was playing and the first thing I heard was ... breaking glass. So WTF was doing this or what was now suddenly so "breaking".
But while tinkering about this our son suddenly looked around with his eyes on the glass door we have in the room. No, this doesn't really sound like breaking glass, but when closing it you sure hear that it's a glass door and not a wooden one which would be more normal. That door was open from me being through there a minute back. His message : "why did you leave open the door ?" but he was totally confused meanwhile because I was at 5 meters distance from the door and he expected me to just have closed (or opened) it.
The moral is clear - he too heard a glass sound (with headphones (always) on and through Game music).
Not that everything now sounds as glass. But there's a super snap that easily makes music exhibit this kind of sound, a bit depending on what's used for percussion. But think of it : did we never see a row of empty (or half filled) bottles (or the like) for percussion ? Yes, thinking of it, I sure did. But did I ever hear that really through the speakers that I noticed ? possibly not. And now that's even quite profound.
So something really really changed ...
And on another note ... that bass ... swoon
« Reply #35 on: June 06, 2015, 09:29:52 am »
6P99N-YF42M-TPGBG-9VMJP-YKHCF
That's the same as the NL version and probably all different language versions as well...
Bert, maybe. But I just tried it for fun (or to prepare you guys) and it does not even work ...
So notice that (as usual) after two days a screen starts to pop up (and overlays all) that encourages you to Activate. On that screen there's a button "Go to PC Settings" (implying that you will be able to enter the Key in there). Usually (for W8.1 the situation is the same) you go there (you can't go anywhere else anyway) to next select the Windows Desktop (which you can do from in there). I don't know how long that lasts (without entering the Key) ... Here though (Windows 10) this happens :
ZILCH
So you can click that button, but next you return to the Desktop. Super ? maybe. But of it doesn't last forever then we'll have to see what's next. The "grace period" as how it is called, will be 30 days for these kind of Windows versions (not Server I mean). Anyway I now tried it with this but the result you see above.
« Reply #36 on: June 06, 2015, 04:32:59 pm »
Go to the download page right now and download the version I have which hopefully is still the same (build 10074) :
10130 it is  unhappy but i have it though  Happy
Michel
« Reply #37 on: June 06, 2015, 04:44:37 pm »
Hello all
 wacko
http://getintopc.com/softwares/operating-systems/windows-10-build-10074-iso-32-64-bit-free-download/
Its a very slow...download site..
Kind Regards,
Michel
« Reply #38 on: June 07, 2015, 08:53:09 am »
Thank you Michel.
« Reply #39 on: June 07, 2015, 09:02:58 am »
I have only one expression about the sound at this moment :
Onbeschoft.
But this is Dutch and I wouldn't be able to translate that to English because one would need to be in audio circles to find a similar expression. But if I had to translate it myself it would be "indecent".
Doesn't make much sense eh ? So make it "unheard". But now it's a softy so not the right one. The "onbeschoft" again resembles some badass (bass) youngster on the roof of a building.
W10 must be badass good. Cool
Now it is up to you ...
« Reply #40 on: June 07, 2015, 03:20:50 pm »
I installed build 10074 (on a clean formatted disc) and it seems to be working OK. When I install XX 1.186a it starts by installing .net 3.5 and that installs OK but after it has installed when I try to run XX it just gives an error message "XXHighEnd has stopped working".
That's as far as I can get - any ideas would be welcome.
« Reply #41 on: June 07, 2015, 03:27:50 pm »
What about reading, Paul ? yes
1.186-a can't work.
But give it 4 minutes, then 2.02 is up. Happy
« Reply #42 on: June 07, 2015, 03:33:49 pm »
It seems the 4 minutes have passed :
XXHighEnd Model 2.02 - Official Windows 10 Support.
Now I hope everybody has some fun with it !!
Pages: 1 2 [3]  All
