April 06, 2025, 08:34:51 pm *
Pages: 1 [2] 3  All
Author Topic: My first Windows 10 experience  (Read 43929 times)
Jud
« Reply #15 on: June 03, 2015, 04:49:39 pm »
Hi Jud,
I just check it. When you are going to the link mentioned under reply#8, and go to Englisch, you still get.
Hi Joachim - right, 10074 is the last build that is available as an iso.  As Peter says, don't connect to the Internet after you've installed the iso, because if you do, Win 10 build updates will occur automatically whether you want them or not.
For myself, contrary to my usual eagerness to try anything new, I think perhaps I will wait.  Though I do indeed anticipate running XXHE on Win 10, there is no reason for Peter to chase a changing target.  So I assume the next build Peter will work with after 10074 will be the official public release.  Time enough to install XXHE once that happens.  (Of course if I am wrong and there is an XXHE 2.x that works with whatever Win10 build I have at the time, I will likely install it.)
« Reply #16 on: June 04, 2015, 10:00:56 am »
This is not really what I have in mind (at this moment); What I am afraid of is that the RTM version will be so much different that the SQ will be vanished. Of course I can't tell yet, but I see better value in explicitly NOT anticipating a next version.
Maybe people don't have experience much with W8.1 or the difference with 8.0, but for me there's no single way that W8.1 will ever play in my system - that bad. And so this is what we can be afraid of.
How long we can preserve (keep on running) such a Preview build, I don't know. Maybe forever, maybe till the end of the year, etc.
« Reply #17 on: June 04, 2015, 10:07:38 am »
Here's a super crucial matter :
At least for me it is very important that I can revert to Restore Points (had to make use of that 6 times or so by now).
Windows Defender has to be shut off or otherwise XXHighEnd won't play (Unattendedly).
A Restore Point made under the situation that Windows Defender has been Shut Off, will NOT lead to a restorable situation. Hence the Restore will fail.
So we MUST make Restore Points, but they must be taken with Windows Defender being active.
« Reply #18 on: June 04, 2015, 10:17:44 am »
Small update on the progress made :
Yesterday I was finally able to boot into Minimized OS without being left with a black screen with mouse pointer only. This, after taking the rough route of approach and which means that way too many Services are now running in order to let it (finally) work. So now it is a matter of tearing down the lot and see where it fails. This can take a few hours, but also a few days.
And each time it fails all I can do is revert to a Restore Point, which together with the required slow boot from DVD takes 30 minutes or so alone.
Anyway I played with it a whole evening as it is and to that regard we have a version right now. But of course I first like to optimize it ...
« Reply #19 on: June 04, 2015, 11:12:57 am »
I found the links below which possibly will remain to be available even if another ISO base version comes around :
For 64 bits : http://go.microsoft.com/fwlink/p/?LinkId=522144
For 32 bits : http://go.microsoft.com/fwlink/p/?LinkId=522145
Both are English-US versions.
« Reply #20 on: June 04, 2015, 11:44:52 am »
Zit daar ook een Product Key bij of heb je die niet nodig?
« Reply #21 on: June 04, 2015, 12:17:20 pm »
Good one !
It will be this Key :
6P99N-YF42M-TPGBG-9VMJP-YKHCF
But you won't be needing it that I can see. Maybe if you connect to the Internet ...
« Reply #22 on: June 04, 2015, 12:20:24 pm »
How to obtain a new XX code if connecting to the internet is not possible?
As soon if you have XX ready for W10 i give it a try.
« Reply #23 on: June 04, 2015, 12:43:40 pm »
Another good one ...
scratching
scratching
scratching
scratching
scratching
scratching
scratching
« Reply #24 on: June 04, 2015, 12:57:34 pm »
That's the same as the NL version and probably all different language versions as well...
« Reply #25 on: June 04, 2015, 01:11:06 pm »
Gerard, actually it is too difficult thinking. It is simply like this :
1. Everybody has obtained an Activation Code, so how ?
2. Currently you are hooked up to the Internet or not (during Playback). Just continue that as how it was;
3. Nobody has his Windows Updates switched on. And if you do ... it's not a wise thing to do to begin with.
So nothing needs to change anywhere.
« Reply #26 on: June 04, 2015, 01:15:48 pm »
I mean with this 10074 W10 (And where auto update cant be switched off)  Happy
« Reply #27 on: June 04, 2015, 01:18:18 pm »
Ah, shoot. It was about that, yes.
Ok, then I need to figure out how to kill that update stuff (which people need to apply themselves, if they want).
Thank you Greard,
wacko
Jud
« Reply #28 on: June 04, 2015, 05:33:01 pm »
I seem to remember several months with previous versions, or maybe until the public release.  Perhaps it will be different with this one, since it's a free upgrade.
« Reply #29 on: June 04, 2015, 05:47:37 pm »
Sorry for the size (width) ...
Minimized OS is done. Now have a listen again ...
Pages: 1 [2] 3  All
