November 23, 2024, 05:16:50 pm *
Author Topic: XXHighEnd 2.01 Sample Rate Problems  (Read 9980 times)
« on: May 30, 2015, 07:27:54 am »
http://www.phasure.com/index.php?topic=3198.msg34777#msg34777
same problem with 96000Khz files under release 2.01, replay with 8xAP or Custom filter.
« Reply #1 on: May 30, 2015, 08:25:15 am »
Joachim,
Please refrain from deleting posts. Also, your deleted post in the other topic made sense to me, this one now does not much.
Anyway let me guess :
You installed 2.01 and did not rename the Driver103.tss to Driver103.tst.
How this is related to 48KHz files being OK (which you wrote almost explicitly in your deleted post) is beyond me, so maybe something else is going on after all. So let me know !
« Reply #2 on: May 30, 2015, 08:32:17 am »
PS:
Of course this was with your best intentions, but it can be highly confusing for me (because it has been up for a longer time and I (thus could) read it).
« Reply #3 on: May 30, 2015, 08:35:38 am »
Joachim,
You installed 2.01 and did not rename the Driver103.tss to Driver103.tst. -correct - bloody h...
How this is related to 48KHz files being OK (which you wrote almost explicitly in your deleted post) is beyond me, so maybe something else is going on after all. So let me know ! - I have no 48KHz files -
I will check the renaming to *.tst in the late afternoon.
Thanx
« Reply #4 on: May 30, 2015, 09:03:09 am »
Haha. But yes, I now realize that a setting in XXHighEnd for this would be overkill, but is still the way to do it because that will be remembered ...
« Reply #5 on: May 30, 2015, 07:34:16 pm »
Ha, ha,
not from my side! Happy
So, with the *.tst file XXH 2.01 works perfectly.  Happy
My problem is now, compared to 1.186-e, I don't get the same sound with identical settings.
I will have a look into the manual. ArcPrediction is identical to the previous release 1.186-e I think.
It would be a great help to see your settings (for the NOS1a) for a starting point.
« Reply #6 on: May 31, 2015, 10:15:20 am »
OK, I actualised my sig now.
« Reply #7 on: May 31, 2015, 02:03:07 pm »
perfect, thank you.
